Tow Hook Broke
Discussion in '3rd Gen. Tacomas (2016-2023)' started by AKIO, Feb 10, 2019.
  1. Feb 10, 2019 at 1:32 PM
    AKIO
    AKIO [OP] Member
    My 2018 Tacoma was stuck on this morning. after being towed out of the trench, I found the front two hook was broken, the towing guy said he did nothing wrong but it is a manufacturing default . I wanna get helps from here before going to Toyota dealers to ask a repair, ( when the Tacoma pulling out of the trench, it was not loaded, just the weights of truck itself. Could you guys tell me if it is a manufacturing default or towing driver's fault?
  2. Feb 10, 2019 at 1:36 PM
    BigDinTexas
    BigDinTexas Well-Known Member
    2017 Blue Taco TRD Sport 4x4 V6
    you were stuck... looks like the effort to pull you out of the muck exceeded the abilities of the tow hook... doubtful you'll be able to demonstrate it was a manufacturing defect, but good luck. If the dealership can't replace (or even if they do) you may still want to find something stronger.
    AxisCab likes this.
  3. Feb 10, 2019 at 1:49 PM
    here4cake
    here4cake Well-Known Member
    That's a tie down hook, not a recovery hook.
    Get a proper recovery point from ARB, or an aftermarket, steel bumper.
  4. Feb 10, 2019 at 1:49 PM
    daddy_o
    daddy_o Well-Known Member
    Bossier City, La
    2018 TRD Sport, Inferno, w/tech package
    Factory Blackout package, Soft roll up bed cover, Cheap seat covers, Front and rear dash cam, AVS in channel vent visors
    Or the third option, the Tacoma drivers fault.
    There is no way to prove how much force or exertion was put on the particular part.
    You got stuck, you accept responsibility. The tow truck driver was just doing his job, and the part in question was doing what it was asked to do. Had you not got stuck then neither the part or tow driver would have been put in this situation. Man up and pay for the repairs.
  5. Feb 10, 2019 at 1:55 PM
    jmneill
    jmneill Well-Known Member
    SE
    2018 Tacoma Sport ACC CB Inferno
    X2
    NOT a tow hook. Be glad it gave way and not the sub frame.
    There IS a tow hook on the opposite side, for towing short distances over level ground. (It's behind your air dam.)
  6. Feb 10, 2019 at 2:09 PM
    Yetimetchkangmi
    Yetimetchkangmi Well-Known Member
    Benjamin
    Newcastle, WA
    03 Tacoma 4x4 The Yeti
    ARB front locker, Custom high clearance rear bumper, Custom plate front bumper, mile marker winch PE8, safari snorkel, Deck Plate Mod Fox 2.5 rr DSC, Camburg UCA, squeaky Dakar leafs, 5125 10" and custom 7.5" shackles, thee finest PNW pinstripes, MT-R, Nissan crew cab roof rack??? wtf is that about??? Allpro skids, Rigid duallys President McKinley CB with PA Recaro SRD with Wedge Engineering Morimoto retrofits Champion Rad - Failed Tundra brakes
    FTFY
    Yes, its YOUR fault.
    Welcome to TW by the way on your very first post....
  7. Feb 10, 2019 at 2:33 PM
    sumorus
    sumorus Get in loser, we're going hammer shopping.
    Albert
    2019 Cav blue SR5 "XP" DCSB
    TRD pro wheels Predator steps Black badges
    Ice cream machine broke
    DA3, Miami Chillin and Hootbro like this.
  8. Feb 10, 2019 at 3:36 PM
    Tacoma2020
    Tacoma2020 Well-Known Member
    https://www.bpfabricating.com/products/tacoma-recovery-tow-hook
    eurowner, helix66 and Doublecross like this.
  9. Feb 10, 2019 at 3:40 PM
    Thunder Fist
    Thunder Fist Well-Known Member
    David
    Birmingham, AL
    2017 MGM TRD OR DCSB
    Like, so many.
    Get an OR tow hook.
  10. Feb 10, 2019 at 3:43 PM
    VegasKnights
    VegasKnights Well-Known Member
    2019 TRD Off Road 4x4 Double Cab
    I like how the original post has been edited. No longer says "doing something I don't want to disclose" :rofl:
    AxisCab likes this.
  11. Feb 10, 2019 at 3:57 PM
    AKIO
    AKIO [OP] Member
    Hi, Thanks for all who had answered my question. Now, IF i leave this broken hook the way it is, does it hurt?
  12. Feb 10, 2019 at 3:59 PM
    DrFunker
    DrFunker Well-Known Member
    I appreciate your efficiency. :cheers:
  13. Feb 10, 2019 at 4:06 PM
    Big tall dave
    Big tall dave Well-Known Member
    Elora, Ontario, Canada
    2018 Tacoma TRD OR DCLB
    I did 15 years of pulling vehicles out of ditches and accident recoveries in rural Canada. I’ve used telescoping booms and lifted most models and makes pretty much off the ground using OEM transport tie downs and stock recovery hooks. In my experience, if something is hung up real bad, the tow truck cable usually breaks before the hooks. The only exceptions would be old, rusted out hooks or pulling from a severe angle on the screw in type eye bolts.
    I don’t think your hook should have broken, unless is was previously damaged from hitting something before being pulled from the ditch.
    My two cents anyway. Good luck.
    AxisCab likes this.
  14. Feb 10, 2019 at 4:24 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    It is only a tie down hook though.
    GillyLink likes this.
  15. Feb 10, 2019 at 4:29 PM
    Tacoma2020
    Yes.
  16. Feb 10, 2019 at 4:33 PM
    lucky13don
    lucky13don Well-Known Member
    Don
    Milton, fl
    R.I.P.04 tacoma prerunner, 04 sequoia 4x4
    Too many to list
    That is a transport point. Not designed for recovery.also for each wheel stuck in mud or sand add 25% of vehicle gross weight to total being pulled..I did recovery and towing for 22yrs. I can teach a class on recovery..lol
  17. Feb 10, 2019 at 4:37 PM
    lucky13don
    Don
    Milton, fl
    Too many to list
    Also the tow driver was lazy or not trained. He should know that wasn't a recovery point.
  18. Feb 10, 2019 at 4:42 PM
    Tacosrus
    Tacosrus Carpe Diem
    Northern California
    2018 Blazing Blue Pearl SR5 DCSB
  19. Feb 10, 2019 at 5:00 PM
    RocTaco
    RocTaco Free stun!
    Pete
    Green Mtns
    21' SR5 Trail AG
    If you plan on getting yanked out of places you need something like this:IMG_0531.jpg
  20. Feb 10, 2019 at 5:01 PM
    Wsteven
    Wsteven Well-Known Member
    2018 Tacoma TRD Pro
    Working on them
    Yeah you can leave it like it is won't hurt anything just look like crap and what if you need a recovery again? would you not rather have a pair of real recovery points on your truck and feel good knowing that is what they are?
