Tow package and trim
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Arek, Jun 1, 2018.
  1. Jun 1, 2018 at 11:44 AM
    Arek
    Arek [OP] Member
    I am about to buy 2016 Tacoma.
    The stickers on the side say TRD Sport, but.....how can I verify which model it actually is?
    I was told that it is the TRD Upgrade model with Tow package.
    It has the hitch and wiring, but does it have the oil cooler and large alternator?
    With all the aftermarket stickers, emblems, grills etc. it is possible to turn SR to TRD with some work.
    Sounds paranoic? I know.....
  2. Jun 1, 2018 at 11:46 AM
    dnlskier
    dnlskier Well-Known Member
    17' TRD SPORT MT
    Easy, run the VIN
  3. Jun 1, 2018 at 11:47 AM
    Arek
    Arek [OP] Member
    Is there a web site where I can „run” it?
  4. Jun 1, 2018 at 11:50 AM
    Ruggybuggy
    Ruggybuggy Well-Known Member
    NW ONT, CANADA
    2020 Tundra SX
    What colour are the shocks/struts. Yellow and it's an OR. Blue it's a Sport.
  5. Jun 1, 2018 at 11:50 AM
    mrretep
    mrretep Well-Known Member
    CA
    2017 TRD OR DCLB
  6. Jun 1, 2018 at 11:50 AM
    robie_0n3
    robie_0n3 Well-Known Member
    David
    Scott AFB, IL
    2018 Tacoma TRD Off Road
  7. Jun 1, 2018 at 11:51 AM
    dnlskier
    17' TRD SPORT MT
    Anyhoo - if it is a Sport w/ tox package it has the cooler etc... I think you are good to go!
  8. Jun 1, 2018 at 11:54 AM
    707tothe907
    707tothe907 Superior Member
    Jake
    Chico NorCal
    05 DCSB Off Road
    You’re overthinking it. No one is going to buy a 2016 and upgrade it from a base to a sport.
    The fenders should be color matched, there should be a hood scoop... you’ve already seen the hitch and trailer wiring... If you open up the hood you can see the cooler below the radiator mounted to the frame.
    If you’re buying from a dealer they should easily be able to give you a vin print out. Buying private party you can run a car fax.
    shakerhood likes this.
  9. Jun 1, 2018 at 12:40 PM
    Arek
    Arek [OP] Member
    I run the VIN and it shows as V6 6A.
    It does not say anything about towing or blind spot monitoring.
    It says Interior TRD cloth and TRD decals factory installed.
  10. Jun 1, 2018 at 12:43 PM
    toyotatacomaTRD
    toyotatacomaTRD Senior Member
    You could throw a hood scoop, wheels and a sticker on an sr5 and I'm guessing 9 out of ten people wouldn't be able to tell.
    synaps3 likes this.
  11. Jun 1, 2018 at 12:47 PM
    Comb
    Comb Known Member
    2017 TRD Sport 4x4 DCSB 6MT BBP ABCDEFG
    OVTune Verified Purchase
    If you look under the section titled "Port or Factory Installed Equipment", there should be a line that says "TO V6 Tow Package" - "Factory".
  12. Jun 1, 2018 at 12:47 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Are the gauges or stereo any different between the 2?
  13. Jun 1, 2018 at 12:48 PM
    Raistlen0
    Raistlen0 Well-Known Member
    PA
    2017 TRD Sport DCLB AT QS
    Look through the grille you can see the extra radiators.
  14. Jun 1, 2018 at 12:48 PM
    toyotatacomaTRD
    I think the radio knobs are different. But I imagine if you haven't had one before, you're not going to know.
    shakerhood[QUOTED] likes this.
  15. Jun 1, 2018 at 12:57 PM
    dnlskier
    17' TRD SPORT MT
    Sport has the "big" entune screen - I believe the SR5 does not.
  16. Jun 1, 2018 at 12:58 PM
    jmauvais
    jmauvais Received 2 votes in a poll one time.
    NorCal
    2018 TRD OR 4x4 DCSB
    ...stuff
    Google pictures of 2016 TRD sport and 2016 SR5. The differences are obvious.
    Sport has hood scoop
    Sport has turn signals in mirrors
    Sport has LED daytime running lights
    Sport has those black seats with the disco ball color light patterns
    Sport has blue shocks/struts
    Sport has a TRD grill
    Sport has color matched fender flares and chin
  17. Jun 1, 2018 at 1:32 PM
    Victory
    Victory Well-Known Member
    St. Pete, FL
    2016 White Tacoma TRD Off Road
    TRD models have push button start with the automatic transmission, Anything lower (SR5, SR) has Key start.
    Installing that push button start in a base model would be more work than it is worth. If you see the hood scoop and push button start you have yourself a Sport.
  18. Jun 1, 2018 at 1:34 PM
    Doggman
    Doggman Well-Known Member
    Alabama
    2017 TRD OR MT
    Just post the VIN here
  19. Jun 1, 2018 at 4:02 PM
    Arek
    Arek [OP] Member
    Thank you for all the info.
    Based on the above I am at peace that it is TRD Sport. Scoop, push start, blind spot monitor etc.
    I will have to look at the radiator tomorrow morning.
    The seller said that it has class 4 hitch with sway control.
    Why would I doubt the car salesman? ;-)
    Victory likes this.
  20. Jun 1, 2018 at 4:12 PM
    shakerhood
    Southern Ohio
    It has not been suggested yet, but have you checked out a new Tacoma? Prices are usually only a few grand more for new and should be something you check out.
