Tow Package on 2.7L 4 cylinder
Discussion in '4 Cylinder' started by rickcrna, Mar 5, 2013.
  1. Mar 5, 2013 at 4:23 PM
    rickcrna
    rickcrna [OP] Well-Known Member
    Rick
    Vancouver, WA
    '13 AC SR5 4WD I4 Auto MGM
    Am still trying to narrow down my choices in purchasing a 2013/2014 Tacoma later this spring. I like the fuel economy and durability of the 4 cylinder and the space of the access cab with the SR5 package so far. Am also favoring the automatic transmission.
    However, I want to be able to occasionally tow an appropriate weight trailer and wondered if any of the new 4 cylinder models can be ordered/purchased with the tow package. If not, how difficult is it to add an aftermarket hitch? Also, how easy or difficult is installing the wiring for trailer lights/brakes?
    Any suggestions and thoughts are most welcome.
    Rick
  2. Mar 5, 2013 at 4:41 PM
    toyodajeff
    toyodajeff Well-Known Member
    jeff
    canton Ga
    06 reg cab sr5
    General lee horn mod, Bilstein 5100's and maxtrac 4 inch lift spindles. omd spring rebuild w/ s10 springs kenwood h/u and cb, warn trans4mer brush guard level 8 tracker wheels and cooper s/t 33's
    I think I may have seen a I4 with a tow package and it was a 400 dollar option at a local dealer. You could probably buy the aftermarket parts and only spend around $150 if you install it yourself.
  3. Mar 5, 2013 at 4:57 PM
    thebrick
    thebrick Well-Known Member
    Frontrange
    06 2.7L Base
    fox 2.0 remote res toytec UCA all pro add a leaf bilstein 5100 all pro standard bumper hid kit
    I installed a drawtie hitch and all the wiring myself. Cost around 270.00 total and can be done in under an hour. For the hitch, just remove the bumper, line up the holes and slap it back together. Lights all "plug'n'play" into your brake lights.
  4. Mar 5, 2013 at 5:02 PM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    Damn... you got ripped off! :eek:
    Receiver costs about $150, plug and play 4-pin wiring costs about $30 and everything can be installed in about an hour with simple hand tools.
  5. Mar 5, 2013 at 5:33 PM
    thebrick
    Frontrange
    06 2.7L Base
    You right. Maybe shoulda looked before i so grossly overestimated.
  6. Mar 5, 2013 at 6:37 PM
    toyodajeff
    jeff
    canton Ga
    06 reg cab sr5
    Normally you can find hitches for sale on craigslist for cheap to. I got a factory Toyota one still in the box for 75
  7. Mar 6, 2013 at 6:50 PM
    Tacoyota
    Tacoyota senile member
    North of Cali, South of Canada
    08 4wd
    4.56 gears, rear trutrac,DT header, 235/85r16 Duratracs, 2nd filter pulled, inter.wipers, Cruise control, Factory alum. whls/winter tires(2nd set), Afe pro Dry-S , Dumbo eared flaps cut down.
    As far as I know there is no tow pkg. available , I'd be careful of a dealer that says there is . My guess is they'd say that to up the sale $1000. I'm thinking of doing a hitch, wiring and a brake box. The tow section has tons of info in that direction
  8. Mar 6, 2013 at 6:59 PM
    toyodajeff
    jeff
    canton Ga
    06 reg cab sr5
    There is at my local dealer. Could be dealer installed or because im in the southeast. The package I saw on the i4 didn't include the brake controler
  9. Mar 6, 2013 at 7:01 PM
    Pugga
    Massachusetts
    F-150 Mod
    It's got to be dealer installed and it's not the same as Toyota's tow package. The tow package is only on the V6 models and comes with a larger alternator and supplimental oil coolers for the engine and auto transmission.
  10. Mar 7, 2013 at 5:45 AM
    Timberland Taco
    Timberland Taco Well-Known Member
    Berlin, NJ
    2013 V6 6-speed 4x4
    Bilstein 5100's set at .85, OME 885x coils w/ 1/2" top plate spacers, Total Chaos UCA's, Wheelers 1.5" HD 3 leaf progressive AAL w/ factory overload leaf, DT Pipe Bomb Ypipe, Vibrant resonator, Magnaflow pro series catback system, URD Short Throw Shift Kit, Debadged, BHLM, BTLM, 6000K BiXenon Headlights & Fogs.
    Just installed a class III hitch and wiring myself. Very simple install. Like said before i removed the bumper and bumper bracket, bolted the 4 bottom hitch bolts supplied with the hitch up (helps to have a 2nd person to assist in holding the hitch up), bolted the bumper bracket back on, then bolted the bumper back on. Also included with the hitch is 4 spacers that go in between the bumper bracket and the bumper to compensate for the thickness of the hitch. Its easiest to to install all the bolts loosely then tighten them all down at once. Get the plug and play wiring harness all you do it remove either taillight, disconnect the in line connection in there, and plug the either end into the harness. Then just zip tie the slack line up and your done. I did the wiring before i put the bumper back on to make life simpler. Cost was $230 for everything. Hope this helps.
  11. Mar 7, 2013 at 6:18 AM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    There actually is a "Factory tow package" for the 2.7L, and like mentioned its around $400. It has the hitch and wiring, but like mentioned does not have all the "true tow package" extras like tranny coolers, etc.
    I went to my local U-haul to buy a hitch, cost me $100, plus 20 to install and 5 for a lifetime replacement coverage. Someone crashes into the rear of my truck, free hitch. 125 total. Then, I bought a clean, plug and play, no splicing, 4 pin wiring harness for about 35 online. Total, 160 for everything. :cool:
  12. Mar 7, 2013 at 6:35 AM
    Pugga
    Massachusetts
    F-150 Mod
    Don't confuse a dealer-installed receiver for the factory tow package... They are definitely different. A dealer-installed class 3 receiver is not the factory tow package.
  13. Mar 7, 2013 at 6:46 AM
    bash42
    bash42 Well-Known Member
    Eastern PA
    '13 Tacoma Access Cab 2.7L 4x4 5spd
    agreed. Any dealer can add a hitch to the truck and put it on the sticker. it typically doesnt come with the wiring.
  14. Mar 12, 2013 at 11:33 AM
    Papa K
    Papa K Well-Known Member
    Aurora, CO
    2013 Access Cab 4x4 4 cyl
    Just F.Y.I. - I just purchased a 2013 4x4 Access cab 2.7 lt. and it came with the 'Factory Tow Package'. The cost was $550.00
  15. Mar 12, 2013 at 12:26 PM
    bash42
    Eastern PA
    Wiring set up already installed?
  16. Mar 12, 2013 at 12:51 PM
    2004TacomaSR5
    2004TacomaSR5 Sentinel Prime
    Jon
    Montana
    2004 Tacoma DCSB & '79 Toyota Pickup 4WD
    I just bought the stuff aftermarket, the hitch and wiring harness for the trailer lights. Took half a day to install everything.
  17. Mar 13, 2013 at 4:46 AM
    Papa K
    Aurora, CO
    That is correct.
  18. Mar 13, 2013 at 9:16 AM
    bash42
    Eastern PA
    wow, that is a very rare bird. As far as I have ever seen them, they usually only have the hitch and no wires. Maybe dealer installed that?
    I need some more info, lol
  19. Mar 13, 2013 at 10:54 AM
    Papa K
    Aurora, CO
    I will double check the purchase paperwork this evening. Truck is currently resting in the garage.
    I did quite an extensive search for a 4 cyl 4x4 - access cab from 2011 to current. Was hoping for a deal on a used one. Ended up getting a new one for about the same cost as used. The V6 tacomas are a lot more plentiful to choose from (here anyways). I worked through a broker via the Credit Union and had 3 to choose from. This one came from about 150 miles away and had the tow package included. Cost was the same for all 3. included.
  20. Mar 13, 2013 at 11:02 AM
    Pugga
    Massachusetts
    F-150 Mod
    Does the truck have an OEM receiver or an aftermarket? Flat 4 wiring or 7-pin wiring? I would bet that is a dealer installed receiver and wiring.
