Tow Rope or Strap
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jcman01, Aug 28, 2013.
  1. Aug 28, 2013 at 11:51 AM
    jcman01
    jcman01 [OP] Well-Known Member
    Buck
    Colorado
    2015 Offroad, 6-manual, Blue Ribbon Metallic
    Can anyone recommend a tow rope or strap to carry along in my Tacoma? I am looking for one strong enough for someone to pull me out of a ditch or other bad spot, or for me to pull someone out (hopefully she'll be nice looking...)
    I have some heavy duty climbing-style rope that I bought at Home Depot, and it worked well once when I got in a jam. But I don't want to push my luck with it.
    Thanks.
  2. Aug 28, 2013 at 11:54 AM
    MrGrimm
    MrGrimm Mall Crawler
    Dean
    Wisconsin
    2006 Toyota Tacoma 4WD w/TRD Sport Package
    See build page
    ARB, viking, wheelers are all good.
  3. Aug 28, 2013 at 11:56 AM
    Punkindrublic
    Punkindrublic Well-Known Member
    Greensboro, NC
    2007 Double-Cab TRD Off-Road
    We (Southeast Overland) sell some too.
    Recovery Straps
    We also sell the ARBs too if you call us at 864-280-4238
  4. Aug 28, 2013 at 12:00 PM
    KingKoda
    KingKoda Never Satisfied
    Palmetto
    '12 TRD.S DCSB 4x4
    Boosted TRD/URD All Terrain Sleeper w/ Sockmonkey Decals Worth +666HP
    anything wrong with using a heavy chain? I have some 1.5/2 inch chain I have always carried around. I did use it once to get a buddy out of a ditch. Just got it taught and then slow pulled.
    I've thought about getting a recovery strap, but is it any better than my chain? The chain is similar to what is used to strap down front loaders, earth moving equipment on flatbeds.
  5. Aug 28, 2013 at 12:29 PM
    Derfus
    Derfus Active Member
    Chains have their uses but I prefer straps since you can really yank and the strap will stretch a little and buffer the force. I've seen chains break and shatter windshields, and snap sapling trees like they were nothing. From my misadventures ill also say a strap is less likely to damage either vehicle.
  6. Aug 28, 2013 at 12:31 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    I have one of these as well as the small Ironman recovery kit
  7. Aug 28, 2013 at 12:48 PM
    stump jumper
    stump jumper Well-Known Member
    Bill
    Texas
    2017 Tundra 4x4 CM TSS
    chains are ok for tie downs and stump pulling but not vehicle recovery. Chains are ok when used with a strap. Straps absorb the shock while chains have a tendency to break things. I am on my 3rd strap. Fortunately I am normally on the pulling end.
  8. Aug 28, 2013 at 1:54 PM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    Wheeler's, everything else is overpriced.
  9. Aug 28, 2013 at 1:59 PM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    this...
    Dan gave me a great deal because he had overstock on a 20' and 10' 3" 30k strap bundle. I already had a 30' 3" 30k strap.
    OP get yourself at least 30' of 3" strap and some shackles.
    Next get yourself a front recovery point because your truck doesn't have a safe one.
  10. Aug 28, 2013 at 4:39 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Chains are for tractors that's a lot of useless weight to haul a round when a strap will do just as well. You haven't got enough traction to break either one. (unless you take a running start)
  11. Aug 28, 2013 at 4:43 PM
    Oowen
    Oowen Well-Known Member
    Owen
    Reno, NV
    '22 Cummins
    I use aircraft cable and it works great. You can get it in almost any length, I have 75ft in the taco and 300ft in a diesel. The only downside is it can't be jerked.
  12. Aug 28, 2013 at 4:59 PM
    CalTacoma09
    CalTacoma09 Well-Known Member
    Manteca, CA
    09 TRD Sport DCLB 4x4 Barcelona Red
    A lot of crap and too much money spent
    This is great I was looking into getting myself a recovery strap but wasn't sure which brand or length to get. This helps a lot thanks.
  13. Aug 28, 2013 at 5:08 PM
    Rupp1
    Rupp1 "If you can dodge a wrench, you can dodge a ball."
    NC
    2024 Nissan Titan Pro4X
    I carry a 30' 30,000# 3" strap, and I never go off road.
  14. Aug 28, 2013 at 5:20 PM
    romafern
    romafern Hug diz nuts
    Rob
    80918 Let's meet!
    Paid for and saving a shit ton of $$$$$
    Thinking of adding a second battery...
    at least you have it when you might need it on the highway....
    got flares?
  15. Aug 28, 2013 at 5:26 PM
    AaronArf
    AaronArf Well-Known Member
    Aaron
    VA Beach
    2023 LR OR DCSB
    Arb recovery strap... not something you want to cheap out on. Go on YouTube and look at videos of lines snapping...
    Edit: 'rope' for you normal guys... navy terminology :)
  16. Aug 28, 2013 at 5:33 PM
    lockman
    lockman Member
    Brian
    Virginia Beach
    2013 trd 4x4
    lift and 33
    I bought a bubba rope
  17. Jan 12, 2014 at 11:39 AM
    Silence9
    Silence9 Solve et Coagula
    Alberta, Canada
  18. Jan 12, 2014 at 11:57 AM
    MrGrimm
    Dean
    Wisconsin
    See build page
    And that is why when conducting recovery operations, all bystanders back away and get some distance.
  19. Jan 12, 2014 at 4:12 PM
    RogerRZ
    RogerRZ Well-Known Member
    New Brunswick, Canada
    White '14 DCLB TRD Sport
    If the vehicle towing you out is big enough, a chain will do the job. If it isn't, you want something with "bungee" like capability.
  20. Jan 13, 2014 at 6:12 PM
    stump jumper
    Bill
    Texas
    Also do hook to a hitch ball. A friend knew a girl that was killed by a ball that broke loose and came through the back window of the truck.
