Tow Straps
Discussion in 'Towing' started by Menametony, May 4, 2009.
  1. May 4, 2009 at 4:53 PM
    Menametony
    Menametony [OP] Well-Known Member
    Tony
    Oahu
    09 Black 4x4 DC Offroad
    Flow Master 40 Series, TRD CAI, Kings 2.5 remote res front and back, All Pro Front bumper, All Pro Skid Plate, PIAA 4" 510 XT SMR, TC UCA's, 265/75/16 WildPeak AT3 on ATX Artillery, LightForce 240 Blitz HID's, WeatherTech Vents and FloorMats, Cobra 19 CB & PA, Maglite mod both driver and passenger, safari snorkel, TRD supercharger, warn 10k winch, PRINSU CabRack, Cali Raised 42" Light Bar, OEM bed mat, softtopper. WeatherTech Mudflaps On order dissent bed rack and retrofits.
    Is there really anything to look in to when buying a tow strap? and what about a tow hook to fit into my hitch?
    Thanks
    Tony
  2. May 4, 2009 at 9:05 PM
    johnecon2001
    johnecon2001 Well-Known Member
    Phoenix, AZ
    2005 TRD Sport 4x4 Access Cab
    Downey front skid, Trail Gear U-Bolt flip, Toytec AAL, Total Chaos UCA's, Bilstein 5100's x4 + Eibach adjustable coils, Doug Thorley Long Tube Headers, Custom Rear bumper, TRD OffRoad front tow hook, TRD Trail Team wheels, Federal Couragia M/T 265's, ARB rear locker + on board air (CKMA12), TRD shift knob, Alpine W205, TRD seat covers, Tom Woods 1 Piece drive shaft, Powermaster D2700, Stubbs HD-SKO Sliders.
    The 30' strap and the receiver shackle on this page are what you're gonna want. Or something similar.
  3. May 4, 2009 at 9:11 PM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    make sure theres no metal hooks attached to the strap
  4. May 4, 2009 at 10:00 PM
    MJonaGS32
    MJonaGS32 MJ on a GS
    MJ
    SF Bay Area (East)
    07 LT 4x4 DCSB 6spd Vagabond
    Drifter wedge camper, Dual battery, OBA, ARB locker, 4.56 gears
    then that would be a recovery strap, not a tow strap.
  5. May 4, 2009 at 10:08 PM
    Stillfly199
    Stillfly199 ( . )( . )
    J.D.
    Bro Capital of the word
    2010 FJ Cruiser
    So if it has the hooks its no good? I just got one with hooks on it. What is it used for? I dont really know what "recovery" means.
  6. May 4, 2009 at 10:42 PM
    MJonaGS32
    MJ
    SF Bay Area (East)
    when you are out 4x4ing, and another truck gets stuck, then you want to use a RECOVERY strap to pull the other truck out.
    The best way to do this, is to hook up the strap to the other vehicle, then hook it up to a receiver shackle from your hitch.
    THEN PULL!!!
    If you use a TOW strap (one with the hooks) to try and get someone out, then you risk the strap breaking, and having a metal hook launching back in your direction. If you google tow strap accidents, you will find horrible stories of tow straps breaking and the hook killing people, etc.
    Check out this link
    TOW straps are literally for just towing (on road, etc). The hooks make for easy access of attaching the strap
    So to the OP, depending on what you are using the straps, for take your pick :D
  7. May 5, 2009 at 12:07 AM
    johnecon2001
    Phoenix, AZ
    Recovery straps typically have a little stretch to them to provide you with a little more pull.
    What happens in muddy situations and one truck is stuck: You use the recovery vehicle to give the strap a good yank, the strap stretches and then recoils tugging the stuck vehicle out. Makes it easier on the truck doing the recovering.
  8. May 5, 2009 at 4:07 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Get a *Stretch-n-Snatch* by Keeper. They're AWESOME!!
    JC Whitney carries 'em.
    They allow for A LOT of stretch so you can actually - get a run at it - and the recoil helps with the recovery.
    http://www.jcwhitney.com/KEEPER-STRETCH-N-SNATCH-STRAPS/GP_2004417_N_111+10201+600002398_10101.jcw
    The reason why you don't want metal hooks, is in case the hook slips OFF the recovery point or the strap breaks.... With all that mementum behind it, you'd get killed if you got hit by a flying metal hook.
    Get a strap that's atleast 20' long (or longer) and has a minimum 15,000lb rating.
    Get some D-rings with enclosed loops - similar to this:
    http://www.tellico4x4.com/images/products/superwinch/2538.jpg
    And again, the D-rings will have a RATING. Make sure you get 15,000lb PLUS rated D-rings to match the tow strap you buy.
