Tow vehicle, tacoma or 4runner?
Discussion in 'Towing' started by 68dave, Dec 19, 2013.
  1. Dec 19, 2013 at 5:36 PM
    68dave
    68dave [OP] Well-Known Member
    Dave
    Baltimore/WV mountains
    $500.00 project 04 TRD 4x4 Lifted 4runner Stock Tacoma TRD Lifted 94 FZJ80 Stock 95 FZJ80
    Toytec Boss kit & OME leafs, 231mm tundra brakes SCS wheels...
    I have 2 toyota's, a 04 taco 4x4 3.4L manual trans and a 00 4runner 4x4 3.4L auto trans. I am undecided on which truck would make a better tow vehicle. I ordered a new Casita 17ft fiberglass camper, it weighs 2450lbs. I'm picking it up in Texas on march 17th and towing it home to Baltimore. The runner has 180k miles, 3" toytec suspension lift, tundra front brakes and a external trans cooler. The taco was a project truck that i picked up with a blown motor for $500. I recently installed a used engine with 69k miles, 147k on the truck. Taco has stock suspension. Taco has a new Aisin clutch kit. Both trucks have new t. belts and related compoments, rad hoses, tune ups, and tires. Both run great. Will the manual trans tow better than a heavier auto trans equipped 4runner? Will the taco's stock suspension handle the weight? I have to install a brake controller and 7 pin connector and i'm not sure what truck to use. Thanks.
  2. Dec 20, 2013 at 8:15 AM
    jethro
    jethro Master Baiter
    Geoff
    Southern NH
    2020 Ford F-150 Lariat 5.0L V8
    I tow a lot and would NEVER consider a manual transmission for an ideal tow vehicle. Especially for a long distance. Either vehicle will handle that little trailer no problem, but personally I would opt for the automatic.
  3. Dec 20, 2013 at 8:18 AM
    2000GTacoma
    2000GTacoma Well-Known Member
    Snow Hill NC
    00 Tacoma Ext. 3.4L SR5
    Just curious why you would never consider a manual?
  4. Dec 23, 2013 at 5:48 AM
    Timberland Taco
    Timberland Taco Well-Known Member
    Berlin, NJ
    2013 V6 6-speed 4x4
    Bilstein 5100's set at .85, OME 885x coils w/ 1/2" top plate spacers, Total Chaos UCA's, Wheelers 1.5" HD 3 leaf progressive AAL w/ factory overload leaf, DT Pipe Bomb Ypipe, Vibrant resonator, Magnaflow pro series catback system, URD Short Throw Shift Kit, Debadged, BHLM, BTLM, 6000K BiXenon Headlights & Fogs.
    Yea to each their own on this one. Me personally i prefer a manual towing for the total gear control. Im not a towing expert but i would have to guess that the 4runner would be a little nicer towing. Its 6 in one half dozen in the other as far as im concerned.
  5. Dec 23, 2013 at 6:01 AM
    2stroketrush
    2stroketrush Well-Known Member
    Tyler Addison Rush
    Baltimore
    Built 97 ExtraCab
    Overland Purpose Built 97 going on 190K.
    Yep i like my manual for towing as well. Where in Baltimore are you??
  6. Dec 23, 2013 at 3:31 PM
    68dave
    Dave
    I was raised in canton, near fells point but i'm in dundalk now. I wanted a single family home with a large grass yard, garage and driveway. And i'm only 10mins. from canton/fells point, i work in canton. I'm leaning towards the tacoma, i like the idea of controlling the gears especially when i'm in the mountains traveling up I-81.
  7. Dec 23, 2013 at 3:43 PM
    JLee50
    JLee50 Well-Known Member
    Phoenix
    Stockish 99 4x4 TRD
    ToyTec coilovers
    I would use the 4Runner mainly because of the Tundra brakes. A heavier tow vehicle will also get pushed around less by a trailer.
  8. Dec 24, 2013 at 5:45 AM
    2stroketrush
    Tyler Addison Rush
    Baltimore
    Built 97 ExtraCab
    sweet! I'm right down the road in Sparrows Point, i will have to keep a eye out for you!
  9. Dec 24, 2013 at 7:17 PM
    68dave
    Dave
    My parents live in sparrows point on Lincoln ave.
  10. Dec 26, 2013 at 11:10 AM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    Very good points Nate :thumbsup: the coils do bounce more and sag more than leafs. Also I agree with the longer wheel base as well
  11. Dec 26, 2013 at 11:13 AM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    I'd use the taco. Better power transfer with the manual and no transmission overheat issues with a Manual. Plus the longer wheelbase will give better control, as will the stiffer leaf sprung rear over the link/coil rear on the 4runner.
    My $.02
    BTW- nice looking 'runner. :)
  12. Dec 26, 2013 at 2:47 PM
    68dave
    Dave
    Thanks for the replies. I never considered the difference in wheelbase. I was leaning towards the taco because of its man. trans. I need a class 3 frame hitch for the taco and since i wanted to replace the damaged rear bumper anyway i was wondering if anybody offers a rear bumper {plate or tube style} with a class 3 hitch built into it?
