Tow vehicle - what do you prefer and why
Discussion in 'Towing' started by 02hilux, Jan 21, 2022.
  1. Jan 21, 2022 at 10:36 AM
    02hilux
    02hilux [OP] What do you mean there’s no road, I’m here
    Planet: EARTH
    Which truck do you prefer and why.
    2022 model:
    Ford F250 6.7
    Ram 2500HD
    Silverado 2500HD
    six5crèéd likes this.
  2. Jan 21, 2022 at 10:37 AM
    six5crèéd
    six5crèéd Be the light
    Southern Virginia
    8 lugs no plugs
    I prefer the Duramax but they are all good trucks.
    Trout365 likes this.
  3. Jan 21, 2022 at 10:39 AM
    jake72
    jake72 Well-Known Member
    Jake
    N.E. PA
    2019 trd off-road dcsb mt
    Ford
    1996landcruiser likes this.
  4. Jan 21, 2022 at 10:41 AM
    02hilux
    Planet: EARTH
    Been eyeballing one for some time now
  5. Jan 21, 2022 at 10:43 AM
    jake72
    Jake
    N.E. PA
    Insane prices, new or used
  6. Jan 21, 2022 at 10:47 AM
    Snowy
    Snowy Is neither here nor there
    Connor
    Winnebago, IL
    3 linked 98 Xtra cab
    Stock-ish
    Test drive and pick what you like. They’re all pretty darn solid. Far cry from 15 years ago when there were some pretty massive gaps. How much are you pulling?
    My personal tow rig is a 2012 6.7 F350.
    ovrlndkull likes this.
  7. Jan 21, 2022 at 10:56 AM
    Gamma11
    Gamma11 ((‘)) yea, i like the taste
    Andrew
    Northeast
    2024 DCLB OR Bronze Oxide, 2022 T4R ORP Super White
    You’re missing the second part of his question, why are you picking!!
  8. Jan 22, 2022 at 8:34 AM
    lock
    lock Well-Known Member
    greg
    N.W.OHIO
    tacoma
    GM 3/4 ton
    I towed a fishing rig 4-6 thousand miles a year for about twenty years mostly with a Ford F-150. Near the end I tried a Tacoma and a GM 3/4.
    The Taco was too small and light for me, just not comfortable on long pulls.
    Then I tried a GMC 3/4 and I'll never go back to a Ford.
    The GM rode better, better fuel economy, and the 4x4 GM would turn circles inside the 2x4 Ford.
    No truck is perfect, just wish I'd tried the GMC sooner.
  9. Jan 23, 2022 at 2:54 PM
    Jimiller5
    Jimiller5 Well-Known Member
    Jim
    East TN
    '15 TRD Sport
    Tonneau cover running boards Lance 1475
    Ford F-150. I towed my Lance 1475 (4000lbs) with a Taco for a year, then traded it for the Ford. I get better gas mileage, has a bigger gas tank for more range, plus it’s much more comfortable on long trips.
  10. Jan 30, 2022 at 3:16 PM
    02hilux
    Planet: EARTH
    F150 can't towed what I planned on towing..
    Will be getting a 2020 or newer f250 6.7 with a 10 speed vs the older 6 speed.
  11. Feb 19, 2022 at 7:20 AM
    Jimiller5
    Jim
    East TN
    '15 TRD Sport
    What are you wanting to tow?
  12. Feb 19, 2022 at 7:36 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    Look hard at the specs and options. I have a friend that just went through this. Ram has a certain transmission/engine combo that will pull a mountain inside out, but it was insanely difficult for him to find.
    For him it was down between the Duramax and the Cummins. He wound up with a used Ram 3500 with 40k on the clock, I think he talked them down to $65k for it. :eek:
    Our work trucks have all been F250s and F350s- they're solid towers but every single one has developed electrical problems after they reach 8 years of age or so. I've had one or two leave me stranded. Granted, they're work trucks which means no employee will treat them gently, but still. I love the F150, despise the F250.
  13. Feb 19, 2022 at 7:39 AM
    OpeCity
    OpeCity Well-Known Member
    Long Beach, CA
    Ford because the GM trucks are ugly as hell and I wouldn’t touch a dodge with someone else’s dick
    Hooligans likes this.
  14. Feb 19, 2022 at 12:27 PM
    02hilux
    Planet: EARTH
    Looking at a camper with roughly 7-10k lbs. I also have an 18' 2500lbs metal car trailer and when loaded, it's roughly 7-8k lbs. A few guys I know have the f250 and I like them as well but been eyeballing the new tundra as another option.
  15. Feb 20, 2022 at 10:42 PM
    napstermike
    napstermike Well-Known Member
    the 2021 ram got a new injection pump, they won't have the failures of the past.
  16. Feb 20, 2022 at 11:00 PM
    Hooligans
    Hooligans Well-Known Member
    Fairbanks, Alaska
    2015 4x4 2.7/5spd.
    Still thinking about it.
    Ford seems to be the only real truck left that’s not a bunch of cheap compromise…Speaking of the big three anyway. I could be wrong…
  17. Feb 21, 2022 at 5:54 AM
    02hilux
    Planet: EARTH
    Not sure about elsewhere but local and surrounding areas fire department use F250. Plus, most commercial business that do a lot of heavy towing/hualing use F250/F350.
  18. Feb 21, 2022 at 6:05 AM
    boston23
    boston23 Well-Known Member
    Adam
    Eastie
    2019 SR5 DCSB 4x4
    All the rancher dudes I see out west towing heavy are usually in a Dodge so that says something
  19. Feb 21, 2022 at 6:33 AM
    batacoma
    batacoma Truck Wars
    2012 Regular Cab 4spd
    Ford 6.7 I like the mirrors better. I'd also get the 7.3 gas motor, but I wouldn't be towing with it. The diesel would be better for towing.
    The Ram diesel would probably be the better truck for towing. I like Fords more than Ram, and I think Ford has better numbers when it comes to towing.
    GM, I not a fan of. No good reason, plus Ford and Ram build trucks that produce more capable numbers. Not that it matters for the 3/4 tons but GM does not offer a 4/550 or a 45/5500 chassis.
  20. Feb 21, 2022 at 2:42 PM
    Snowy
    Connor
    Winnebago, IL
    Stock-ish
    They do again as of MY2019(?). Uses a Navistar chassis and a GM cab/engine/trans. GM hooked up with Navistar after Ford and Navistar dissolved the Blue Diamond joint venture for MD trucks.
    batacoma[QUOTED] likes this.
