Towing 2 horses with tacoma
Discussion in 'Towing' started by gallopping girl, Jan 20, 2014.
  1. Jan 20, 2014 at 8:20 AM
    gallopping girl
    gallopping girl [OP] New Member
    arroyo grande CA
    none yet
    Hi Guys and Girls,
    I want to buy a tacoma for towing a horse trailer and 2 horses, total weight 3500lbs. So I am looking at a V6 with tow package. Can afford about 20K to spend on it. This would be a 2006 or 2007 with about 90K miles in my area. My question is: Is that mileage too high to be safe to use for towing? I would only use it about once a week locally so wouldnt put a lot of additional miles on it..
    Thanks!
  2. Jan 20, 2014 at 11:28 AM
    jethro
    jethro Master Baiter
    Geoff
    Southern NH
    2020 Ford F-150 Lariat 5.0L V8
    Absolutely no problem whatsoever.
  3. Jan 20, 2014 at 11:31 AM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    x2.
    nothing wrong with towing frequently with a rig that has around 100k.
    just of course keep up on the regular maintenance like fluids and brakes because they will see more wear from the frequent towing
    welcome to the forum :wave:
  4. Jan 20, 2014 at 11:32 AM
    jake72
    jake72 Well-Known Member
    Jake
    N.E. PA
    2019 trd off-road dcsb mt
    make sure they have the tow package and you will be fine.
  5. Jan 20, 2014 at 4:03 PM
    gallopping girl
    arroyo grande CA
    none yet
    Wow, thanks guys. Really appreciate the feedback! Will do as advised:)
  6. Sep 4, 2014 at 5:47 AM
    Spindifferent
    Spindifferent Well-Known Member
    Central Texas
    2013 PreRunner 4.0 v6
    OP - what brand horse trailer are you using? Looking for one for our two horses.
    Thanks.
  7. Sep 7, 2014 at 7:25 PM
    Smar969905
    Smar969905 ToyotaLover
    Zach
    Deer Park, WA
    96 Dodge 12valve cummins- mine, 16 T4R - wife's, 11 Taco - totalled
    3500 lbs on 2 horses and trailer? That seems light unless you are using mini horses. I pull my 2 horse trailer with my 4 cylinder, but only 1 horse at a time.
    Just be prepared to add the brake controller yourself. They don't come with one, but they do have the 7 pin round harness from the factory.
  8. Sep 8, 2014 at 5:54 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    I tow a three horse trailer at 2991# w/ my two horses and it does great. Get a good brake controller and remember that you are driving a different vehicle than your unloaded truck and you'll be all set with a Tacoma.
  9. Sep 8, 2014 at 5:59 AM
    Spindifferent
    Central Texas
    Thanks Brunes. Do you have a link to the brand and model of your trailer? Most trailer websites don't list the trailer gross trailer weight (GTW).
  10. Sep 8, 2014 at 6:24 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    I have a Shadow Select 3 Horse slant load. All Alum and trailer brakes on every axle were my two requirements and this one nailed it.
    I found it from a dealer in MS, where it had been slightly damaged so they were willing to deal in order to not have to send it back. And TBH, if the GTW isn't listed, that's not a dealer I'd want to buy from. Everywhere I shopped for this trailer and all the places I looked for the enclosed I wanted to buy had it pretty clearly listed cause it matters.
