Towing 2016 Tacoma (4-Down) behind RV
Discussion in '3rd Gen. Tacomas (2016-2023)' started by redeye1000, Feb 14, 2016.
  1. Feb 14, 2016 at 7:19 AM
    redeye1000
    redeye1000 [OP] Member
    2012 Gray TRD Crew
    Has anybody setup their 2016 Tacoma to be towed behind an RV? I need hidden mounting information to attach a Blue OX tow bar. Either a nice hidden base plate or how to mount the adaptors is what I think I need. Maybe winch mount? Open to all advise. Thanks
  2. Feb 14, 2016 at 7:28 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    I like using tow Dolley's. You can put truck on backwards and not worry about sand blasting the front window of truck while being towed.
    Cost would be about the same as fabbing up tow bar anchors on the truck. To me it seems to be less hassle.
  3. Feb 14, 2016 at 7:54 AM
    redeye1000
    2012 Gray TRD Crew
    Yea, I guess that's another option and never thought about towing backwards. Trying avoid extra weight and hassle of having to deal with dolly. Currently I pull a 2006 behind my rig. A minor pain is having to drop the driveshaft which dollys would eliminate.
  4. Feb 14, 2016 at 7:58 AM
    koditten
    Kirk
    Central Michigan
    I build and sell trailers, yet I still prefer using a tow dolly.
    You can actually tow larger vehicles with a smaller tow vehicle quite safely using a dolley. They are just so handy to have around.
  5. Feb 14, 2016 at 9:57 AM
    Aussiek2000
    Aussiek2000 Well-Known Member
    2016 Offroad AC
    You will need to pull the rear drive shaft since the t-case doesn't have nuetral
  6. Feb 14, 2016 at 10:12 AM
    koditten
    Kirk
    Central Michigan
    Even if loaded backwards? Don't have a '16, so don't know if front diffy is disconnected.
  7. Feb 14, 2016 at 10:41 AM
    Aussiek2000
    2016 Offroad AC
    Op said all 4 down. Doesn't matter which direction it's pulled, but rear driveshaft needs pulled if rear wheels are on the ground
  8. Feb 14, 2016 at 11:17 AM
    koditten
    Kirk
    Central Michigan
    Hence, loaded backwards on a tow dolly, no DS removal needed.
  9. Feb 14, 2016 at 11:40 AM
    Aussiek2000
    2016 Offroad AC
    Hence, I didn't quote you and was referring to the OP
  10. Feb 15, 2016 at 5:57 AM
    redeye1000
    2012 Gray TRD Crew
    I'm aware of no neutral in transfer case. I already drop the drive shaft now on my 2006 taco. A dolly needs licensed registered with yearly fee in Ohio. That's probably more of a hassle for me than dropping drive shaft.
