Towing - 2nd gen vs 3rd
Discussion in '3rd Gen. Tacomas (2016-2023)' started by NH Tacoma, Nov 16, 2023.
  1. Nov 16, 2023 at 5:16 AM
    NH Tacoma
    NH Tacoma [OP] Member
    Goodmorning, searched on this site for previous discussions but couldn't find any. My beloved 17 year old 2nd gen with 250K miles may be ready to retire. I tow a lot, both a utility trailer and a 4,000 lb camper. Has anyone gone from a 2nd to 3rd gen who also tows, and what has your experience been? I've concerned with the 3.5 liter engine, and more gears in the transmission. Thanks for any feedback!
  2. Nov 16, 2023 at 5:25 AM
    airforceb2cc
    airforceb2cc Well-Known Member
    Don
    KCMO
    2021 DCSB Nightshade
    Ironman FCP; 315/75R16; KDMAX; Skids; Sliders
    Don't worry about having more gears in the trans...you won't use all of them when towing. I've towed with both...the 4.0 was much better at providing better torque off the line but the 3.5 maintained speed better when in 4th gear. Got better gas mileage with the 4.0 but not by much...10mpg in the 2nd gen and 8mpg in the 3rd gen (towing a 5,000lb sail). These trucks weren't meant for towing really. You might be better off with a Tundra.
    ScrippsRanch67 likes this.
  3. Nov 16, 2023 at 6:17 AM
    BirdBrain
    BirdBrain Well-Known Member
    2021 4wd Off-Road
    There are eight years of towing threads in this forum. Plenty of info there.
  4. Nov 16, 2023 at 7:05 AM
    NH Tacoma
    Yeah, nothing related to my question. Thanks for your attempt at...whatever that was.
  5. Nov 16, 2023 at 7:11 AM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    It will tow fine as long as you follow the procedure of towing from the owner’s manual which is shifter in S4, ECT Power on for the auto trans. As others said you’ll probably notice a bit more pull down low on 2nd gen but more power up top. In 4th gear you’ll be in the 3000 range at 65-70 which generates a bit of good power out of the 3.5.
    I personally have a regeared manual and kept it in 5th towing about 4000 lbs. 3200 rpm at 65, it ran great. Downshift to 4th at 4000 rpm anytime I needed and it really pulled well in those cases. I think you’ll be fine.
    Hobart94 and 02Duck like this.
  6. Nov 16, 2023 at 7:19 AM
    BirdBrain
    2021 4wd Off-Road
    You didn't look very hard. The advice BLtheP posted has been posted literally hundreds, if not thousands of time in those threads.
    Chew and SmoothTRD like this.
  7. Nov 16, 2023 at 7:39 AM
    airforceb2cc
    Don
    KCMO
    Except the question wasn't "how to tow with a 3rd gen" which is what @BLtheP answered very well, it was asking who has gone from a 2nd gen to a 3rd gen and what lessons were learned. Yes, it has been discussed here before...but using the search function including the word "towing" will take days to sort through.
    LooneytuneSR5, brigsby99 and 02Duck like this.
  8. Nov 16, 2023 at 7:42 AM
    BirdBrain
    2021 4wd Off-Road
    When in doubt, RTFM.
    Squirt likes this.
  9. Nov 16, 2023 at 7:45 AM
    BLtheP
    Plano, TX
    Only reason I included that info was didn’t want him to go and buy a 3rd gen and then complain it towed poorly after not having towed correctly. I agree that they tow fine if kept within their limits and executed properly and their towing performance is certainly not a reason to NOT buy a 3rd gen (IMO).
    Chew likes this.
  10. Nov 16, 2023 at 7:46 AM
    airforceb2cc
    Don
    KCMO
    Where in the manual does it compare towing with a 2nd gen to a 3rd gen?
  11. Nov 16, 2023 at 9:48 AM
    NH Tacoma
    Dude, maybe sit this one out.
  12. Nov 16, 2023 at 9:51 AM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    Here we go! Gonna be a good one:)
    2nd genners coming soon and will be discussing stump pulling power of the 4.0
    23MGM, oconnor, Koolbreeze7 and 7 others like this.
  13. Nov 16, 2023 at 9:55 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    My 3rd Gen pulled a shrubbery once.
    Koolbreeze7, rmorse, YF_Ryan and 2 others like this.
  14. Nov 16, 2023 at 10:01 AM
    RichochetRabbit
    RichochetRabbit Bing Bing Bing
    How much work did the transmission cooler need to do?
  15. Nov 16, 2023 at 10:05 AM
    BirdBrain
    2021 4wd Off-Road
    Dude, do a little research.
  16. Nov 16, 2023 at 10:40 AM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    Um what? I’m sorry but that’s impossible. It’s either photoshop or you’ve got the 1GR under the hood.
    :p
    Rock Lobster[QUOTED] likes this.
  17. Nov 16, 2023 at 10:45 AM
    545
    545 Well-Known Member
    2015 Access Cab
    Wonder if any rentals have a tow hitch
    I’d call around, pretty cheap way to form your own opinion
  18. Nov 16, 2023 at 10:48 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    If I were to do a lot of towing with a 4k lbs camper,,,, I'd say neither, I'd be looking to get a full size.
  19. Nov 16, 2023 at 10:55 AM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    Only if he had an additional transmission cooler his spare wouldn’t fall out…
  20. Nov 16, 2023 at 10:55 AM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    /thread.
    Chew[QUOTED] and YF_Ryan like this.
