Towing 2WD Manual Transmission Tacoma with Dolly
Discussion in 'Towing' started by TacoMonkey98, May 30, 2014.
  1. May 30, 2014 at 5:52 AM
    TacoMonkey98
    TacoMonkey98 [OP] New Member
    1998 Tacoma 2.4L 5sp 2WD
    I'm planning a 1300 mile drive and would like to know if I need to disconnect the drive shaft on my 1998 Tacoma 2WD 5sp manual transmission. I already searched for my question on this forum but could only find information about flat towing and 4wd vehicles. Is there an engine-driven pump that lubricates the transmission when the engine is running or is this only on newer models?
    Thanks!
  2. May 30, 2014 at 6:00 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    I would remove it for a trip that long. There is a small bearing in the head gear that the main shaft turns in that may starve for oil in a long distance run because the counter gears are not turning to slosh oil around. All the rest of the stuff (diff and such) will get lube while turning.
  3. May 30, 2014 at 10:54 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Pull the driveshaft. It will save wear on the trans. The rear diff is self lubricating.
