Towing 3500 in mountains? fair or bad?
Discussion in 'Towing' started by Tacoma Tom, Jul 8, 2010.
  1. Jul 8, 2010 at 7:49 PM
    Tacoma Tom
    Tacoma Tom [OP] Well-Known Member
    Sunny Arizona
    07 DBL TRD
    Looking at a 7X12 Enclosed trailer. Weighs approximately 2200#. RZR and gear will probably add another 1300# How is the Tacoma going to handle this weight? I look in the "What do you tow thread" and honestly think some of those guys are nuts. Maybe they tow on flat land, but I don't think they would ever make it going up the rim here in Az...........
    Anyways, any info you can offer about the V6 Tacoma going up steep inclines with rought 3500# would be great.
    Thanks
    Tom
    PS I know the mileage will suck, its not good even with the utility trailer and toy! I'm not a speed freak, just dont want to kill my truck, regardless of what Toyota says its rated at.
  2. Jul 10, 2010 at 8:35 AM
    yance
    yance Well-Known Member
    ks
    07 TRD DC offroad 4x4
    Toytec AAL, Skyjacker front lift shocks.
    My experience has been great in the mountains pulling a similar load, but don't be in a hurry and be ready for the gas bill. I pulled from SE Kansas to Gunnison CO last summer with a 16ft utility trailer hauling 2 4x4 quads and a dirt-bike plus all the gear for a weeks vacation. I am guessing around 3,000 lbs. Monarch pass was the bad pass and I had plenty of power, but I never had to slow way down for any semis. I actually got around 12-14 mpg pulling in the mountains. Just kept it around 3,000+ rpms to where it seemed to make the best power.
    The part I was disappointed in my truck was pulling across western KS. If I pulled at 70mph, I was getting between 8-10 mpg and the transmission was all over the place a few times if I tried the cruise control on level ground. If I slowed down to 60-65 mpg was around 9-11 and still couldn't use the cruise even on fairly level ground. If I pull my 6x12 enclosed I get similar results.
    For me, I love my Tacoma but its coming apparent that I should start thinking about a larger truck for the things I expect out of a truck. I dont think you will kill your truck if its not an everyday thing.
  3. Jul 10, 2010 at 11:58 AM
    Isthatahemi
    Isthatahemi Well-Known Member
    TRD OFF ROAD
    BFG AT's, Weathertechs, Hoppy's brake controller.
    Truck will handle it fine, as stated above, mileage will suck. But the mileage on these trucks is with the V6 is always weak.
  4. Jul 10, 2010 at 12:01 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    well, I was just at about 9k feet, and carrying 3 bikes in the bed I could really feel the difference even with the supercharger. Going up the hills it would downshift twice to maintain 70-75 mph. It ended up shifting around 4k. I was not pushing it that hard, but still I was on a mission. I monitored my engine with my scan gauge and my temp didn't climb over 193
  5. Jul 10, 2010 at 10:40 PM
    Tacoma Tom
    Sunny Arizona
    07 DBL TRD
    Found a single axle, so that should drop it 1000# or so. Giving it a try next weekend.
  6. Jul 22, 2010 at 7:57 PM
    Tacoma Tom
    Sunny Arizona
    07 DBL TRD
    Truck did well................ 6% grade for 6 miles = 55mph at 3k RPM.
  7. Jul 22, 2010 at 7:59 PM
    RelentlessFab
    RelentlessFab Tacoma offroad armor fabricating beast Vendor
    Eric
    Eastern side of the Sierras: Sparks, NV
    07 SR5 6mt to 03 SR5 to 08 Sport and 17 6MT TRD OR
    Yep! No problem! My truck has pulled 6500 or so up a 3 mile 6% grade and maintained 55mph. I dont do it regularly though...
  8. Jul 22, 2010 at 8:08 PM
    yance
    ks
    so what size trailer did you end up going with?
  9. Jul 22, 2010 at 9:54 PM
    Tacoma Tom
    Sunny Arizona
    07 DBL TRD
    Interior dimensions - 6'6"wide X 12'long X 6'10"height PACE single axle with a flat front. Was probably around 3300# with trailer, gear and Polaris RZR. Gas pedal was about 1/2 position on the post above, so if someone was able to hold that speed with double the weight, you must have had it pinned to the floor! Its around 80 miles to get up the hill (probably 30%+ of that is 4-6% grade) and MPG was right at 10.4
  10. Jul 22, 2010 at 9:56 PM
    achirdo
    achirdo I Weld!
    Adam
    North DFW
    06 dodge ram 3500 5.9 cummins
    do u live there by chance?
  11. Jul 23, 2010 at 2:19 PM
    yance
    ks
    Gunnison-? Sadly no. I usually go out for a weeks vacation every year.
  12. Oct 20, 2011 at 6:57 PM
    bpurdy
    bpurdy Member
    Bobby
    Duluth MN
    2011 Reg Cab Tacoma 4x4 5 speed
    Heavy Duty Tow Package, Field Logic Graphics Aries Black Grille Guard Ionic Tonneau Cover
    No problem, I tow a lawn service rig with my 2011 2.7litre I4 with a manual gearbox. I work in duluth which is full of hills and sucky roads and that trailer weighs 3500lbs. So If you have a V6, you'll be fine. Your MPG's will suck but thats part of driving a truck.
  13. Oct 20, 2011 at 9:27 PM
    lrak
    lrak Well-Known Member
    In my experience that 6'10" interior height needs more extra throttle than an extra 3000lbs. Pulling the weight up hill works the engine, but so does towing a parachute.
