Towing 6400 with Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TuTacos2Go, Oct 25, 2019.
  1. Oct 26, 2019 at 12:25 PM
    #161
    monkeyface
    monkeyface Douchebag, or just douche if we're friends
    Colorado
    '90,'97,'12,'05 Tundra 4.7,'07 T4R 4.7,'08 T4R 4.7
    Toyota could have put a better towing engine into the 3G, but when they designed it their marketing surveys showed towing was 22nd on the list of attributes 3G owners wanted. True story.
    I've towed ~3700lbs with the '12 4.0 6MT Taco, a flat-face 8' wide travel trailer. Performance was nothing to brag about, but adequate. Floored in 2nd-3rd to pass the slowest 18-wheelers on I-70 passes, Ike and Vail.
    The 3.5 I imagine is similar, just adequate, keeping it floored in lower gears.
    2G and 3G are multi-purpose trucks. Yeah, you'll struggle hauling a TT but when you unhook at your destination they're small and nimble enough to tackle almost any offroad situation.
  2. Oct 26, 2019 at 12:37 PM
    #162
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    Well said sir! I'd just like to add I hope the Hybrid sedan owners stay the F away from our trucks. They might give their input on the next design and then you will see tacomas at the Tesla charging station. Gross.
  3. Oct 26, 2019 at 12:40 PM
    #163
    Rottencotton
    Rottencotton Well-Known Member
    Stinkin Rincon
    Superwhite 2019 Tacoma SR 4x4
    If this comes to pass you won't see me in one of those Tacoma's.
  4. Oct 26, 2019 at 12:40 PM
    #164
    melikeymy beer
    melikeymy beer Hold my beer and watch this
    2019 Tundra
    I'm part of the Toyota focus group and suggested they put the snorkel on every new PRO. You're welcome.
    boynoyce likes this.
  5. Oct 26, 2019 at 12:53 PM
    #165
    TuTacos2Go
    TuTacos2Go [OP] 2nd / 3rd Gen Hybrid
    Cincinnati, OH
    2011 RC Barcelona Red MT, 2019 DC Cement MT
    Yes it's a V nose. And its 8.5 wide. 7 foot wide ones are very cramped with a sport sxs
    DavesTaco68[QUOTED] likes this.
  6. Oct 26, 2019 at 12:55 PM
    #166
    TuTacos2Go
    Cincinnati, OH
    Bottom of tire is still full, and I meant on the ride back it was fully fluided
    I ran a rock across the valve stem and bled it out unfortunately.
    Just more cash and back at it
  7. Oct 26, 2019 at 12:59 PM
    #167
    ZR NO
    ZR NO Well-Known Member
    Andy
    2019 TRD PRO - Super White
    So far just a bed mat and a lighter wallet
    @TuTacos2Go I’m not fully understanding your concerns. I too came from a GMC 2500 diesel. I mainly bought my truck and sold the diesel because I no longer had a work vehicle and had sold my 23’ trailer. I wanted a small truck that got decent mileage and I could go wheeling with on the weekends. Where I am confused is your decision to buy another small Toyota knowing that you would be towing on a regular basis. Also towing half or 3/4 of the trucks max towing capacity. If I knew that was one of the primary reasons for purchasing the truck I am fairly sure I would have purchased a 1/2 ton truck at minimum. Your Tacoma can tow up to 6400 lbs MAX. Essentially the vehicle can maintain a slow speed in a tall gear and the hitch won’t be dragging. However, it won’t be pretty. For me I would be happy with 70 mph at 3100 rpm. Maybe that’s just me. Legally most speed laws require you to drive 55 mph where I live when towing on the frwy. So 70 mph would be a bonus. I tow my 18’ fishing boat that comes in around 3,300 lbs loaded down. I keep the truck in sport mode and primarily use 4th gear for hills and then go back to regular drive when on flats. It is not that you are expecting too much from your truck towing a 3100 lb trailer. It’s just that your expectations on how comfortably it will tow under load are more aligned with a 1/2 ton truck or better. Also you’ve had a second gen, I assume well before your third gen right? Are you implying that you second gen towed comfortably at speed under a similar load?
    GreyBaldTaco likes this.
  8. Oct 26, 2019 at 1:02 PM
    #168
    TuTacos2Go
    Cincinnati, OH
    I still own the 2nd gen. It's a 4 cyl manual and wont tow a sick whore off a barstool.
    I also own a Cummins.
    I dont expect the truck to tow like a diesel. I expect it to tow half its rated capacity with a little gusto. That's all
  9. Oct 26, 2019 at 1:10 PM
    #169
    AZBACKCOUNTRY
    AZBACKCOUNTRY Well-Known Member
    Doug
    AZ-between the hammer and the anvil
    11' AC TRD OFF-ROAD 4x4
    Pelfreybilt front aluminum bumper,AVID off road weld on sliders, RCI Offroad IFS & transmission Skid (steel), RCI LCA skids (aluminum),upper grillcraft, relentless hi clearance bumper,OEM color matched front grill color, ARE MX camper shell, wet Okole realtree seat covers,pelfreybuilt hi lift mounts,ICON 2.5 Coil-overs extended,, ICON tubular UCA's. Allpro expo leafs, SS extended brake lines.Bilstein 110 extended rear shocks.prinsu Cabrac.dwreck pod mounts OKLED 18w cubes.Baja Designs Squadron-R Sport, LED Wide Cornering, Ambers fog/driving 20" IGGY LED Single Row bar.tepui awning,rotopax 2 gallon, TREDs and mount , 100 watt renogy solar panel.victron 20 amp Bluetooth charge controller,Pro comp wheels - cooper st maxx 285/75/16 tires. Skygear bussman fuse relay smart box. ARB 12v plug hard wired for ARB fridge. Pelfreybilt gas tank skid. Smittybilt X2O 10K winch
    Towed cross country twice with TT.
    About 3100 pounds . It does it ,Arizona and the entire west towing is a game of patience.( climbing the hills)
    With that said - taco is going up for sale.
    I bought a Tundra and that will be a change.
    Tow safe !
  10. Oct 26, 2019 at 1:18 PM
    #170
    FishinCrzy
    FishinCrzy Well-Known Member
    Rob
    South Carolina
    '17 4WD Limited Taco
    3" Lift, BFG LT275/70R 18, Frt. Hitch, Diamondback cover and Rack, RTT, 52 qt.freezer, House Batt.
    I tow a 21' Bay Boat that must be at least 3500 lbs. (probably more) loaded with '17 4WD. It does fairly well I think. Just doesn't get much gas mileage...but it never has. Stopping with inertia brakes on trailer works well also.
  11. Oct 26, 2019 at 1:28 PM
    #171
    DavesTaco68
    DavesTaco68 Well-Known Member
    North Thompson, BC
    2013 Tacoma TRD
    - ICON UCAs, BP51/Kings, SCS wheels, 285s, Leer 100XR canopy. Greenlane aluminum winch bumper, Smittybilt X20 winch. Trying Falken AT3w now, Really like BF KO2s.
    I was looking at something like this as well, I have a Can-am atv and thought about having some room for camping in the front of the trailer. The 8.5 wide sticking out past the sides of our trucks is going to be an anchor.
  12. Oct 26, 2019 at 1:38 PM
    #172
    ZR NO
    Andy
    I see but again we are still talking about towing. These light trucks were designed for light truck use, dump runs, moving, and light towing. If the expectation is to tow half the max with “gusto” why not buy the 1/2 ton? I’m sure I am not telling you anything new but you could have easily purchased a half ton with an 18mpg rating on Frwy for a similar price to your Tacoma. When I researched my truck I never found a single post saying “tows like a beast.” Most post read “tows my light trailer and or boat just fine.” I understand the destain your feeling towards your truck’s towing characteristics. However, it has more to do with your lack of experience towing with a light duty truck and maybe not enough research imo. And don’t get me wrong I understand your frustration, but having experience with both when towing I knew what to expect. I got a buddy who has a Chevy Colorado with the v6 and he thinks his tows more comfortably than mine. However they both still tow like light duty trucks. There are options to make your truck tow with more gusto to help offset the factory’s efforts for better mpg. AAL, re gearing, and the ov tune to name a few
    auskip07 and melikeymy beer like this.
  13. Oct 26, 2019 at 1:53 PM
    #173
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    Don't worry, the 4runner will likely get the 3.5 in the next few years.
    Malvolio likes this.
  14. Oct 26, 2019 at 3:00 PM
    #174
    Phich
    Phich Porkchop Express
    San Antonio
    2017 TRD Off Road tuned to KDMax perfection
    Six Demon Bag
    :rofl:
    Malvolio and AZBACKCOUNTRY like this.
  15. Oct 26, 2019 at 3:49 PM
    #175
    ColoradoTJ
    ColoradoTJ Retired cat herder Moderator
    Colorado
    3500 Duramax, Roush Mustang, Jeep Crawler
    Still one of my favorite TW members on name alone and of course @Dirk Diggler.
  16. Oct 26, 2019 at 5:39 PM
    #176
    Dirk Diggler
    Dirk Diggler Under the Stun Gun
    Columbus, GA
    2017 MGM OR DCSB
    I wanna beer n I wanna see somethin' naked
  17. Oct 26, 2019 at 5:42 PM
    #177
    auskip07
    auskip07 Well-Known Member
    Skip
    Atlanta, Ga
    2019 TACOMA SR V6 SC , 4X4, AUTO, 4.88, 265/75 r16
    be careful what you wish for.
    ColoradoTJ likes this.
  18. Oct 26, 2019 at 5:43 PM
    #178
    computeruser6
    computeruser6 Nuclear Janitor
    Dirk
    Escondido
    2008 Regular Cab Tundra
    King 2.5 coilovers Nitto Exo Grapplers
  19. Oct 26, 2019 at 5:44 PM
    #179
    Dirk Diggler
    Columbus, GA
    2017 MGM OR DCSB
    Ugh thanks...now I have Goodbye Horses by Q Lazarus stuck in my head. Then again thank you for reminding me to use lotion
  20. Oct 26, 2019 at 5:45 PM
    #180
    auskip07
    Skip
    Atlanta, Ga
    or else it gets the hose again.
