Towing 6X12 over Siskiyou Summit (4200 ft)
Discussion in 'Towing' started by Brian W, May 12, 2018.
  1. May 12, 2018 at 10:55 AM
    Brian W
    Brian W [OP] New Member
    Tacoma 2105 SBDC V6
    No modifications. Has factory installed tow package, tires, and such
    Hello. I am new to the Tacoma World and hope to get some advice about towing over Siskiyou Pass with a 6X12 U-Haul Trailer. I am driving from Central Cal to Portland, OR and considering trailering over Siskiyou Pass which is about 4200 ft elevation. I am driving a V6, factory tow package, SBDC. Good idea, bad idea, make a new will?
    Thanks
    Brian
    lil_buddy likes this.
  2. May 12, 2018 at 11:33 AM
    Cnasianfire
    Cnasianfire Well-Known Member
    Charles
    Wilmington, NC
    2015 Tacoma TRD off road DCSB
    BFG KO2 285/75/16 ~2" lift (5100s and block)
    I have towed the same trailer, but not through a pass. That being said, on flat land I hardly knew it was back there. So I can imagine that up a hill would work with a little work. I have read on here that it is doable, but you may have to take it easy and shift down to 3rd. Definitely stay in 4th at the most. If you don't have it already, get torque pro and a Bluetooth obdc2 adapter to monitor trans temp. Both are cheap to get. Like less than $30 for both
  3. May 12, 2018 at 12:37 PM
    airsavage
    airsavage Well-Known Member
    Butch
    2020 Tundra Sport 4x4 MGM, 2000 Prerunner
    Welcome aboard:hattip:. Your truck should be able to handle that but you will know the trailer is back there. My camper weighs in at just over 2 tons and the truck does fine:thumbsup:. As stated above make sure you say in 4th gear. It keeps the tranny from gear hunting and heating up too much.:cheers:
  4. May 12, 2018 at 11:30 PM
    Sprig
    Sprig Well-Known Member
    Ken
    N. Calif. The Twilight Zone
    Tacoma TRD double cab 4x4, Barcelona Red
    It shouldn’t be a problem but it’s all about how much it weighs loaded. 6x12 is a good sized trailer and you can load a lot of shit in there. But I’m thinking you probably won’t load more then 1000 or 2000 lbs in it so you should have no problem. And 4200 ft ain’t that high. As someone else said tow in 4 not D.
  5. May 13, 2018 at 9:31 AM
    Brian W
    Tacoma 2105 SBDC V6
    Thank you for the welcome and thanks for the helpful information. I feel confident about the drive now.
    Sprig likes this.
  6. May 27, 2018 at 7:01 PM
    strictlys
    strictlys Well-Known Member
    2016 Super White Tacoma DC TRD OR SB
    Let us know how it works out. I am planning to do the same drive. How much weight were you planning to load? I was planning to put 2 beds and bunch of random crap. Only difference is I have a 16 with a 3.5 not a 4 liter.
