Towing a 2 horse trailer with 2004 tacoma
Discussion in 'Towing' started by Horselover1, Jun 2, 2016.
  1. Jun 2, 2016 at 3:12 PM
    Horselover1
    Horselover1 [OP] Member
    Megan
    2004 Toyota Tacoma 4wd
    6 in Lift
    Does anybody have experience towing a horse trailer with a tacoma? Is it safe?
  2. Jun 2, 2016 at 3:16 PM
    eon_blue
    Azusa, CA
    Do you know the total weight of the trailer + horses? As long as you don't exceed the 5,000lb weight limit (3500 if you have the 2.7l) you should be fine.
  3. Jun 2, 2016 at 3:18 PM
    eon_blue
    Azusa, CA
    tcBob likes this.
  4. Jun 2, 2016 at 3:43 PM
    Horselover1
    Megan
    6 in Lift
    Ok thank you! I have the 3.4 liter with the towing package, the trailer is like 2000 lbs and the horse is 1000, do I need to have a trailer brake controller?
  5. Jun 2, 2016 at 6:10 PM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    Good horse?
    I'd go whole hog then and set it up right.
    I pulled a '28 travel trailer once with mine at highway speed and swore never to do THAT again.
    Also nearly lost a compact tractor coming down a bridge so I'm never doing THAT again either.
    brakes are a no brainer. Sway control a probably and dist. hitch a possible.
    read that tow primer. these trucks aren't really for towing.
    because_wumbo-truck likes this.
  6. Jun 3, 2016 at 1:16 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Having installed more Hitches and rebuilt more horse trailers then I care to think about for crazy Horse Women.
    Seems most of the Women in my life belong to the crazy Horse Women group
    There is no way no how I would use a Tacoma to pull a horse trailer with only one horse .
    Mine was not bad for backing trailers into the shop and pulling them out.
    Yes you could build your Tacoma in a very Expensive Custom way to handle the towing duties .
    A 6" lift kit makes it even worse .
    Not knowing just what sub group you fit in look at the trucks at the next show or rodeo you go to doubtful you will see a Tacoma Maybe some Tundra`s
    Upgrade to a Tundra if your a die hard Toyota Girl.
    For my Serious Towing I have a Ford F250 7.3
    I would not want to see you or your Horse hurt
  7. Jun 3, 2016 at 8:43 AM
    Northern Taco
    Northern Taco Well-Known Member
    2022 Tacoma trd off road premium 2023 tundra trd off road
    2000 lb trailer +1000 lbs of moving cargo + Tacoma at highway speeds, turns, etc = scary!
    Even a half ton you know horses are back there and can feel them moving around.
    theredofshaw likes this.
  8. Jun 3, 2016 at 11:56 AM
    Horselover1
    Megan
    6 in Lift
    Thank you for your feedback! I definitely want to be safe for my horse, so im selling my tacoma and getting a diesel f250!
    DustStorm4x4 likes this.
  9. Jun 3, 2016 at 1:40 PM
    Northern Taco
    It'll be far superior in every way for towing horses.
  10. Jun 3, 2016 at 1:50 PM
    eon_blue
    Azusa, CA
    You should list your Tacoma for sale here on this forum, lots of people out there looking for nice first gens (1995-2004)
    theredofshaw and tcBob like this.
  11. Jun 3, 2016 at 4:11 PM
    Wyoming09
    New Tripoli Pa
    Super Springs
    The truth is even though you should no better sooner rather then later for some stupid reason you will end up with 2 horses.
    Always happens that is when things go south in a bad way real fast .
  12. Jun 6, 2016 at 8:15 PM
    deckeda
    deckeda Well-Known Member
    '04 Double Cab PreRunner SR5
    The truck's suspension sounds like it was lifted way beyond the 3" or so design. I wouldn't tow with it. Other than that, it can be adapted to pull a 2-horse trailer without the world (or the hoses) coming to an end.
  13. Jun 7, 2016 at 1:58 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    Please tell me just how I can build my Tacoma
    To pull a Two horse trailer and all the gear that goes with two horses most likely Tops out at @ 6000 pounds
  14. Jun 7, 2016 at 7:30 AM
    deckeda
    6K pounds? That's a stretch, for any Tacoma. Still, people here on this forum have done it of course. Braking, power, suspension, and circumstances all matter. So you'll get no "recipe" from me.
  15. Jun 7, 2016 at 6:29 PM
    Northern Taco
    Accross town maybe, but never safely at any amount of speed
