Towing a 4x4 Auto Trans
Discussion in 'Technical Chat' started by JnJnKatiebug, Nov 21, 2009.
  1. Nov 21, 2009 at 3:59 PM
    JnJnKatiebug
    JnJnKatiebug [OP] New Member
    Jim
    Arkansas
    SR5
    Tow bar, driveshaft disconnect, kayak rack
    I am looking for answers concerning towing my Tacoma. It is an 04 SR5 4x4 Auto Trans with a manual shift transfer case. I have the towbar mounted and installed a driveshaft disconnect from a company called Remco and have towed it behind a motorhome several thousand miles. The driveshaft disconnect is a piece of junk and I would like to remove it but I do not want to destroy my tranny. According to the owners manual the Taco is not towable.
    I have towed a GM product with the same setup and according to the owners manual you just put the transfer case in netural and the trans in park and tow away. I asked the local Toyota shop dude what was the difference in the GM and the Toyota transmission and he said "they are just different". Wow, I was impressed.
    My question is this, why can't the Tacoma be towed with the transfer case in neutral and tranny in park like a GM.
    If it is a liability problem with Toyota I am not worried about that.
  2. Nov 21, 2009 at 4:41 PM
    Tacoyota
    Tacoyota senile member
    North of Cali, South of Canada
    08 4wd
    4.56 gears, rear trutrac,DT header, 235/85r16 Duratracs, 2nd filter pulled, inter.wipers, Cruise control, Factory alum. whls/winter tires(2nd set), Afe pro Dry-S , Dumbo eared flaps cut down.
    Mine is electronic, no neutral. Cant speak for yours though.
  3. Nov 21, 2009 at 5:15 PM
    JnJnKatiebug
    Jim
    Arkansas
    SR5
    Mine is manual transfer case with neutral. It does have a 4x4 shift on the fly button on the side of the transfer case shifter.
  4. Nov 21, 2009 at 5:23 PM
    Tacoyota
    08 4wd
    Ahh,ok.
    My only guess then is maybe something to do with the transmission or x'fer case.
    Could using a dolly to raise the front work? Think my manual shows that.... I'll check.
  5. Nov 21, 2009 at 5:29 PM
    Tacoyota
    08 4wd
    Mine can't be dinghy towed either, could be the front isn't re-enforced enough for that, maybe axle windmilling from the front axle, someone said why here or on T.N. , but I just don't recall.
