Towing a 5x8 Utility Trailer
Discussion in '3rd Gen. Tacomas (2016-2023)' started by WHITE_SR5, Sep 9, 2024.
  1. Sep 23, 2024 at 1:14 PM
    Gen3TacomaOBX
    Gen3TacomaOBX Well-Known Member
    S
    2018 Tacoma DCSB SR 4x4
    Bilstein 6112 front / 5100 rear (extended) shocks, Headstrong AAL, Firestone airbags, 4.88 gears, OME Carrier bearing drop kit, Aluminum 1/4" skids (engine to transfer). Custom sliders (1.75" HREW tube w/ 3/16" base plates). Custom front bumper and high clearance rear bumper (1/4" steel plate, 1.75" tube.) Apex 5500 winch w/synthetic line (36lbs) and required accessories for an underpowered winch (snatch blocks and extra line.) Tekonsha P3 brake controller, remote start, any-time-backup camera w/ front facing camera, Leer 100R shell (w/e-track single slot tie-down mounts for removable Yakima EasyTop.) Cat shields by CaliRaised. Husky liners, window tint, heated seat (passenger only.) Relentless bed rail brackets with QuickFists (shovel/axe/fire extinguisher.) Hondo Garage Un-holey vent mount. Anytime rear with front facing camera. Billet front seat risers. Viair 88p. 265/75r16 Goodyear Ultra-terrain tires.
    Fwiw for the OP, I've pulled a 2700 lb trailer across the mid-Atlantic states in summer without running into transmission temp issues (I've monitored the temps with an inexpensive bluetooth ODB dongle and the OBD Fusion app.) With only ~1200 lbs you don't need a monitor and you can run in overdrive gears. I wouldn't use cruise control (or at least wouldn't let it downshift and rev into the 4k rpm range as there is no need for that.. just accelerate like it's not a rental.)
    Heh.. just saw that OP finished their trip. Thanks for reporting back.
  2. Sep 23, 2024 at 2:48 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    good feedback!
    Better safe than sorry on monitoring the transmission temps! Especially with the low cost and ease.
