Towing a Bassboat
Discussion in 'Towing' started by BlueTaco2011, Apr 3, 2014.
  1. Apr 3, 2014 at 1:05 PM
    BlueTaco2011
    BlueTaco2011 [OP] Member
    Georgia/Alabama Line
    11 Tacoma PreRunner SR5
    Just Purchased my first Toyota, 2011 Tacoma PreRunner SR5 Double Cab. I will be towing a 17 foot bass boat as often as possible!! Is it safer to tow in D or 4 with this model truck? My boat weight is close to 1500 pounds total.
  2. Apr 3, 2014 at 1:06 PM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    Any hills? Mine struggles pulling out 21 foot bass boat it's heavy with the trailor too. Is use 4
  3. Apr 3, 2014 at 1:13 PM
    Paleus
    Paleus Well-Known Member
    Arkansas
    '13 DCSB TSS 4x4
    1500 lbs total boat, motor, fuel, gear? or is that just dry? That seems light for a bass boat. I've got a 15 ft aluminum boat, probably 1500 lbs total, including trailer and can't even tell it is behind the truck. I just tow it in D. If I'm in a hilly area and it is shifting a bunch I will kick it down to 4.
  4. Apr 3, 2014 at 1:18 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    i pulled a 285 stratos with a 150 yammy...no problems
  5. Apr 3, 2014 at 3:06 PM
    Tacoma Mike
    Southern Maine
    You mean something like this ??????
    In D all day long.
    If you get in the hills then in 4 but flat towing on the roads I never have to.
    Let the truck talk to you. It will let you know what it needs
    1500 pounds is nothing
  6. Apr 3, 2014 at 3:47 PM
    Black Taco
    Black Taco Well-Known Member
    Rob
    WPB, FL
    TOYOTA
    No mods whatsoever!
    I towed my buddies 19 ft Triton. City/highway, OD worked fine. Fairly flat roadways. Gas mileage dropped a little, but not terrible.
  7. Apr 4, 2014 at 5:38 AM
    BlueTaco2011
    I hope I get to test it out tomorrow. My boat is small, only 17 feet with a 75 HP outboard, dry weight is 1100 pounds so maybe I under estimated the weight, maybe closer to 2000 pounds total with motor and fuel and gear everything?
  8. Apr 4, 2014 at 5:42 AM
    jake72
    jake72 Well-Known Member
    Jake
    N.E. PA
    2019 trd off-road dcsb mt
    if it shift in and out of od alot use 4th gear, if not od will be fine.
  9. Apr 4, 2014 at 5:45 AM
    Paleus
    Arkansas
    '13 DCSB TSS 4x4
    Also, sometimes I will put it in 4 when taking off from a stop to keep it out of OD while accelerating. It will sometimes shift into OD while I am still accelerating and seem like it is lugging. Once I get up to a cruise I shift back into D.
  10. Apr 4, 2014 at 6:06 AM
    LowerBost
    LowerBost Well-Known Member
    Nick
    Pittsburgh, PA
    09 Tacoma Sport
    Old Man Emu Lift w/ Dakars and Billsteins, K&N Intake, Throttle Body Space, Front Bull Bar, Side Rails, Painted Stock Rims, Bilstein 5100 Front Shocks, Third Brake Light Cover, Satoshi Grill Mod, BHLM Mod
    Never had an issue with my 18' fish and ski and it has two motors hangin off the back. Drive mine in D all day long and put in 4WD when im pulling out of steep docks.
  11. Apr 4, 2014 at 6:08 AM
    JLee
    JLee The Man! Vendor
    Jerry
    Grass valley CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    I have the same boat :thumbsup: and tow it with mt 1st gen on 37's with no problems. I have a 5 speed and can pull it over Donner summit in 5th. I think 1500lbs should feel like nothing to a 2nd gen Like Mike said above let the truck tell you what it needs if it feels sluggish drop it into 4.
