Towing a boat with a 1st Gen
Discussion in 'Towing' started by summerboy1958, Oct 6, 2010.
  1. Oct 6, 2010 at 4:27 PM
    summerboy1958
    summerboy1958 [OP] Well-Known Member
    Bruce
    Newark, De
    01 SR5 4WD, Radiant Red
    Hidden Hitch Trailer Hitch, Timbren Shock Assist System, Billy 5100's all around, Deck plate mod, AFE Pro Dry air filter, Amsoil 85W-90 Severe Gear Oil in the transmission/differentials/transfer case.
    Help!!
    I am looking at a boat that is right up to the 5,000 # limit. I have the V-6 with a 5 speed manual. Anyone out there with experience towing that much with a 5 speed? How was it? Is that weight too much? And then there is getting up and down the ramps (I guess getting down is easy). I have a 4x4 with the rear locker. I plan on that covering me.
    Comments???
  2. Oct 6, 2010 at 6:57 PM
    Avsguy33
    Avsguy33 Well-Known Member
    I used to have a 2002 Ranger 18 foot bass boat, I would assume 2800-3000 lbs with trailer and gear. It pulled it ok, needed to downshift on grades, granted Im also at mile high and power is down up here. I always put it in 4LO pulling up the ramp just mostly to save the clutch. This was back when I had my '98 ext. cab.
    Being down at sea level I do not think you will have a problem, just remember what is behind you as it may have a hard time stopping itt unless it has trailer brakes.
  3. Oct 6, 2010 at 7:19 PM
    greatfuldead
    greatfuldead Active Member
    central ohio
    2010 accesscab 5sp 4cyl
    none yet
    I pulled a 3000 lb camper with a 93 Toyota 4 Cyl 5spd. Scary, Yes! but it did the job. the clutch slipped on take off ,on flat road it did OK.
  4. Oct 21, 2010 at 5:30 AM
    redneck
    redneck Active Member
    middletown DE
    04 TRD extra cab 4x4
    K&N and a Gibson cat back
    i tow my 5000# boat with my 04 v6 but its an auto, it's plulled it out in 4 high but i usually use 4 low i use an 1,000 / 10,000lbs Equilizer weight distrubution hitch that helped but looking into some helper springs from Hellwig,probably going to get a bigger truck next year like a suburban or Armada but not getting rid toyota
    Redneck
