Towing a Boat
Discussion in 'Towing' started by 04 TRD taco, Aug 23, 2009.
  1. Aug 23, 2009 at 3:29 PM
    04 TRD taco
    04 TRD taco [OP] Member
    Jax, FL
    04 Prerunner SR5 Double Cab
    So I my be about to pull the trigger on a Super Air and I am curious about towing it behind my SR5 04 Taco. Anyone have any experience towing 19-21 ft boats? Any weight problems or issues I need to consider? I used the search function already BTW. TIA
  2. Aug 23, 2009 at 3:32 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    As long as its within the towing capacity of the truck, you should be fine.
  3. Aug 23, 2009 at 3:40 PM
    genxer36
    genxer36 Lord of Tomfoolery
    Sean
    Bethlehem,GA
    Tow package, XM Satellite radio, K & N Air filter, & Channel Vent Visors
    Make sure the trailer has brakes. I had trouble stopping my 18' bass boat with my 03 Tacoma. The trailer does not have brakes. My 05 tows & stops fine.
    Plus with shifting into 4 & 3 for last minute stops helps.
  4. Aug 23, 2009 at 3:47 PM
    shootermcgavinyo
    shootermcgavinyo Well-Known Member
    Rockford, IL
    '08 double cab 4x4 v6 trd off road
    I tow my 19' bowrider no problem.
  5. Aug 23, 2009 at 3:54 PM
    TacoNut
    TacoNut IgnoringChrisWatchingEdLi veVicariouslyThroughMJP2
    Adam
    Denver, Co
    16 TRD OR DCSB Quicksand
    you should be fine as long as it's within the towing capacity.
    I've towed a 18ft. ranger behind a 1st gen for years, no real problems.
  6. Sep 6, 2009 at 12:52 PM
    04 TRD taco
    Jax, FL
    OK so I think I have found the boat that I am going to buy. It is a 21 ft Super Air Nautique that weighs 3190 dry. Loaded with gear and fuel I understand that it pushes 5500 lbs. My '04 2wd SR5 double cab is rated at 5000 lb capacity. Will 500 or 750 extra lbs present a safety concern? The drive to the boat ramp is only about 3 miles w/ no real highway driving. Will I be able to pull the boat out of the water w/o risking damage to the boat or my truck? If this will create a problem, are there any upgrades that would allow me to tow the boat w/o buying a beefier truck? Thanks for the replys.
    BTW i read the bible on towing but it seemed more geared towards 2nd gen.
  7. Sep 18, 2009 at 5:25 PM
    Voos
    Voos Well-Known Member
    Eric
    Albuquerque, NM
    Dbl Cab SB TRD Off Road
    Icon CO's, Total Chaos UCA's All-Pro 3" leaf packs w/ U bolt flip +Timbren, Rear Bilstein 5100's, Dick Cepek DC1's Black, 285/70R17 BFG ATko, ProDryS drop in, Dynomax Super Turbo
    I used to pull a 21 ft. Sea Ray with my 04.. a little tricky pulling it up the ramp(4 low to avoid clutch damage)but otherwise it did great.. I would highly recommend a trailer with brakes
  8. Sep 18, 2009 at 7:42 PM
    Jason'sLawnCare
    Jason'sLawnCare Prepared for Bambi
    Jacksonville Florida
    08 4x4 Double Cab TRD Rugged Trail
    CBI Moab 2.0, CBI Trail Rider 2.0, CBI sliders w/kickout, Superwinch EPi9.0S, OME sport shocks w/886 coils, OME n182, 1.5" aal, JasonBuilt 3/16th full belly skid, BuiltRight uca, Body Mount Chop, 285/75/16 km2's, Rear cat delete, exhaust crossover rerouted, Fog light anytime, Locker mod, Rear leaf tsb, Debadged, Uws Tool Box, Electric Exhaust Cutout, AFE Pro Dry S, Kiwi Wifi, Diff Breather Relocated, Grom Ipod Adapter, Dual Diehard platinum batteries isolated by BlueSea marine switch
    If you have the locker it would help you pull it out on a slippery ramp. A buddy of mine used to pull an 18 ft Bayliner with his 2004 double cab and it seeme to do fine.
    I wouldn't think you can hurt it. Just drive slow and cautiously due to not being able to stop as quick and to save the tranny.
  9. Sep 19, 2009 at 9:26 AM
    Isthatahemi
    Isthatahemi Well-Known Member
    TRD OFF ROAD
    BFG AT's, Weathertechs, Hoppy's brake controller.
    The 5000# tow rating is good for highway, hills and whatever....You should have no problems at all, even on the launch.
