Towing a car
Discussion in 'Towing' started by hoepuncher, Jul 31, 2009.
  1. Jul 31, 2009 at 8:17 PM
    hoepuncher
    hoepuncher [OP] Well-Known Member
    Hi Guys -
    I thought i'd ask you guys for some advice before I make my trip. I am planning on going to Las Vegas tomorrow to tow my sisters 1996 Acura Integra back to Los Angeles (300 miles). I am planning to rent a tow dolly from U-Haul where the rear tires will be rolling on the street. Will my truck be okay for this whole trip? Am I suppose to leave the gear in 4 instead of D? I have a 08 TRD Tacoma V6 Access cab automatic, TSB springs, and towing package. (This will be my first time towing anything...any advice will be appreciated. Thanks!
  2. Jul 31, 2009 at 8:19 PM
    SamSter0077
    SamSter0077 Happy Camper
    Katy, TX
    09 Tacoma 4x4 TRD OR
    OME 886 Coils, and Struts, Rear Toytec TSB AAL/ OME shock absorbers, Fog Lamp anytime mod, Voyager Brake Controller.
    Give yourself plenty of time to stop.. Truck will tow it no no problem.
    -Sam
  3. Jul 31, 2009 at 8:21 PM
    hoepuncher
    When I load up the car, do I drive all the way home in 4th gear?
  4. Jul 31, 2009 at 8:27 PM
    senna
    senna Well-Known Member
    San Jose CA.
    09 DBL CAB TRD-OR OME shocks 885 and AAL
    Check with U-HAUL ASAP, they have restrictions on what size truck can hook up to a tow dolly, the thing is they don't know what size car you are really going to tow and they want to make sure and cover their (rear)end. Heck you might be fine, but find out as early as possible, so you know what you are getting into.
  5. Jul 31, 2009 at 8:28 PM
    SamSter0077
    Katy, TX
    going by the book, yes (tow in 4th gear).. I live in Texas, it's pretty flat.. I leave it in 4, unless I am cruising on the highway, once I am up to speed.. I will go into 5th. You HAVE to make sure the truck is in the Torque Converter Clutch mode.. 4 and 5 gear have a clutch that prevents the Fluid from rotating in the Torque converter (which is what makes it HOT). The Torque converter generates the greatest amount of heat in the transmission, when it is spining (TCC clutch not engaged).
    I am not very good at explaining it, but do you understand what I am saying?
    Torque Converter Info
    http://auto.howstuffworks.com/auto-parts/towing/towing-capacity/information/torque-converter.htm
    -Sam
  6. Aug 2, 2009 at 11:43 AM
    hoepuncher
    Yes - I understand. Thanks for your help Sam!
  7. Aug 2, 2009 at 11:56 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    PLENTY PLENTY of time to stop...
    Those tow dolly's don't have brakes (atleast, I'd be amazed if they did)
  8. Aug 2, 2009 at 12:00 PM
    JKD
    JKD Well-Known Member
    I'm new to this, but this is the first I've heard of the torque converter clutch locking up in 4th. Are you sure about that?
  9. May 26, 2012 at 4:01 PM
    leo858
    leo858 Well-Known Member
    Leo
    Chesapeake, Virginia
    06 PreRunner TRD Sport
    3" Pro Comp Suspension Lift, Light Racing UCA's, Grille Guard, OEM Side steps, Pop & Lock Tailgate, Shorty Antenna, TRD So-Cal bedside decal, TRD cat back exhaust
    I will be doing the same thing but will be driving from Chicago to Virginia. Will my truck be ok? I have a 06 Tacoma prerunner w/ 3 in lift
  10. May 26, 2012 at 4:29 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    They don't back up real well either.
  11. May 26, 2012 at 4:31 PM
    skidooman
    skidooman I'm your huckleberry
    TJ
    Northern Nevada
    19 Taco
    Kings, JBA, BAMF, C4, Deaver, Prinsu, TJM, SnugTop, 5.29s
    I think they do. Ill double check on my way home, and update in about an hour.
    On the backing up, if this is your first time towing, make sure where ever you pull in, you'll be able to pull through when you leave. Backing doubles is hard enough if you're experienced. Being a noob you will probably cause damage.
    Also like said above, make sure you can rent the dolly with the tacoma. I showed up to rent a full sized trailer in my old 89 Toyota and they had a fit. My grandpa was on his way with his 1 ton chevy to trade me for a bit. They still hesitated even after my gpa was gone in my truck and it was hooked to his truck.
  12. May 26, 2012 at 5:45 PM
    skidooman
    TJ
    Northern Nevada
    19 Taco
    Yes. The converter will lock in 4th.
  13. May 26, 2012 at 6:10 PM
    Rupp1
    Rupp1 "If you can dodge a wrench, you can dodge a ball."
    NC
    2024 Nissan Titan Pro4X
    I towed a 73 Firebird on a dolly about 250 miles with my 06 auto 4x4. No problem at all. I did leave it in 4th 90% of the time. Slow and steady, and give yourself a bit extra time to stop. You'll be fine.
