Towing a rental hilo Trailer Rookie Towing q's
Discussion in 'Towing' started by samhmbz, Jun 6, 2009.
  1. Jun 6, 2009 at 9:28 PM
    samhmbz
    samhmbz [OP] Member
    so.cal
    08/dc/sr52/pr/lsd
    panasonic strada double din,raytell bluetooth,toytec leveling kit,rear spring tsb
    Thanks for all the great info the bible and other threads are great!.
    Just have a couple questions and looking for some reassurance.
    This is the unit I will be renting to take a trip from so.cal(Disneyland area) to Yosemite.
    http://www.inlandrvrental.com/08 HI-LO.htm
    http://www.hilotrailer.com/Trailers/2008/2008_17T.html
    I have towed a 23ft. upright camper with a gmc envoy and a 25ft. camper with a Denali also to Yosemite, I just drove did not set up anything.
    Weight should be ok?
    I will be purchasing a trailer brake from what I have researched a prodigy or p3.
    Do I need mirrors for this 17ft. trailer?
    I will need a receiver, I have 265/75/16's the rear spring tsb done and have a coil spacer from toytec just the coil one not the top plate. Do I need drop down hitch if so how do I measure?
    I will be driving about 40 minutes to pick up this rental then back home to load up ect...
    Any opinions or advise on brake set/leveling or my set up in general would be appreciated. Like I said I am a rookie @ this and am depending on this rental place to set me up, but I would like to be aware of what I doing?
    Thanks and sorry if any questions are repeats.
    The rental will include a weight dist. Hitch do I need to bring anything else with me to pick up?
    Sam
  2. Jun 7, 2009 at 3:50 AM
    JDCPA
    JDCPA Well-Known Member
    Jim
    SW FL
    09 5 Lug Access Cab SR5
    Curt Hitch and etrailer.com wiring harness.
    With a class 3 receiver and a trailer brake controller you should be good to go. You may want to consider load equalizing bars to keep things level and I'd be careful about loading up too much stuff in the trailer. Without the trailer towing package your vehicle is only rated to 3500 pounds.
    As for mirrors, if you can see vehicles right behind you in the stock mirrors you'll be good without extension mirrors. If you can't, get the extension mirrors. There are models that clamp on your stock mirrors and others that clip on to the front fender and stick much farther out.
  3. Jun 7, 2009 at 10:52 AM
    samhmbz
    samhmbz [OP] Member
    so.cal
    08/dc/sr52/pr/lsd
    Thanks for the response, I didnt mention my truck also has the towing package.
  4. Aug 12, 2009 at 3:49 PM
    JKD
    JKD Well-Known Member
    You said you need a receiver...but you say you have the towing package?
  5. Aug 12, 2009 at 6:39 PM
    samhmbz
    samhmbz [OP] Member
    so.cal
    08/dc/sr52/pr/lsd
    Yes I have the tow package, I meant the ball portion. Unfortunately the trailer I reserved was involved in a accident and is not available. I now have reserved this one http://www.ocrv.com/RentalUnitDetail.aspx?vId=13
    thanks for the response.
    Sam
  6. Aug 13, 2009 at 6:41 AM
    bb609
    bb609 O.F.
    NH
    '09 TRD Sport Access Cab
    Icon Coilovers - Icon UCA's - TSB Rear w/Bilstein 5100's - Air Lift System - Leer 550 Bedcover - Ventshades - Yota Bed Mat - Sheepskins!!! - Weathertechs
    You need to measure the trailer at the coupler to determine drop. Rental Co. may have the info.
  7. Sep 17, 2009 at 1:48 PM
    samhmbz
    samhmbz [OP] Member
    so.cal
    08/dc/sr52/pr/lsd
    Just picked up my rental trailer heading to Yosemite valley from O.C in a couple hours. Trying to set up the p3 trailer brake now I have it set at 6.0.?
  8. Sep 17, 2009 at 3:23 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Setting the prodigy is just a matter of 'playing with it'. With the trailer loaded up and ready to go in front of your house (or parking lot), pick a setting and move slightly and hit the brakes softly. If the brakes lock up too soon (and the tires skid), then you'll know you have it set too hard. Back it off.
    It's probably better off to set it high and test it to find out where & when it'll lock the brakes easily and then back off to find a 'happy medium'.
    You also have 3 boost settings. The boost (from what I remember) is how hard & fast the brakes come on. Boost 3 would be for really heavy loads, as the boost will come on hard and pretty quick. Boost 1 would be for lighter loads as the brakes will come on slowly at first and but as you step on the brakes harder...the brakes will also come on harder.
    Obviously, you don't want the trailer brakes to lock the tires up when you use the brakes softly.
  9. Sep 19, 2009 at 9:10 AM
    Isthatahemi
    Isthatahemi Well-Known Member
    TRD OFF ROAD
    BFG AT's, Weathertechs, Hoppy's brake controller.
    The proper way to set it up is determine under max braking setting; what setting will be just shy of trailer wheel lockup under full brake application. That is your first setting, the second setting is how aggressivly the controller applies the brakes. Basically this second setting is a comfort thing, and should be set so that you cannot feel the trailer behind you under braking.
  10. Sep 20, 2009 at 5:51 PM
    SamSter0077
    SamSter0077 Happy Camper
    Katy, TX
    09 Tacoma 4x4 TRD OR
    OME 886 Coils, and Struts, Rear Toytec TSB AAL/ OME shock absorbers, Fog Lamp anytime mod, Voyager Brake Controller.
    Let us know how the trips goes with your setup. Everyone loves a good story!
