Towing a T100 behind my Tacoma??
Discussion in 'Towing' started by nut, Jan 5, 2013.
  1. Jan 6, 2013 at 8:53 AM
    wolftree
    wolftree Well-Known Member
    Rick
    Ohio
    2011 Tacoma 4x4 Regular cab automatic trans,
    Rear Leaf TSB, Bilstein 5100s, extra leaf added
    nut,
    Rig up separate rear lights (not the T-100s) using a 30' long trailer wiring harness and two rear lamps. It will plug right into your Tacoma plug.
    I bought a magnetic mount that I can remove or install quickly. It has the rear lights and harness already put together. It is similar to what a tow company sticks on when they tow in a vehicle.
  2. Jan 6, 2013 at 9:23 AM
    nut
    nut [OP] she'll ride
    Patrick
    Arizona
    Totaled
    TRD SKEWP DCSB 4x4 Silver Mica | URD TCAI/MAF CAL | BHLM | GrillCraft | FF Sliders | LED's All Around | 12v Constant On | EGR In Channel | 15% Tint | Trimmed mud flaps | Fog Light Anytime Mod | Debadged | Tailgate Hoseclamp | DTRL Switch | Disabled Lock Beep/Seatbelt Chime | Husky Liners | HID's | BedRug | WO Seat Covers | ABS Kill Switch | Oil Catch Can | Viper 5704 | Custom Carbon Cabin Filter | Backup Camera Anytime | 400W Anytime | In Cab Outlet W/USB | Firestone Ride Rites | Ams Oil All Around | 32" LED In Lower Grill | BlackVue DR500GW-HD |
    Ive seen those at walmart and harbor freight. reviews on the magnets havent been very good. Im sure i could work something out
  3. Jan 6, 2013 at 9:36 AM
    2000GTacoma
    2000GTacoma Well-Known Member
    Snow Hill NC
    00 Tacoma Ext. 3.4L SR5
    Like other have suggested I would prefer having the vehicle on a trailer with at least brakes on one trailer axle. I know you plan on driving smart but what about the idiot thats not paying attention pulls out or something and you need to stop in a hurry. Even a tow dolly with brakes would help. I just like a trailer because drive the vehicle on it secure it and be gone. No removing anything. just my .02
  4. Jan 6, 2013 at 9:58 AM
    hetkind
    hetkind Well-Known Member
    Howard
    Johnson City
    2011 SR5 Access Cab, white with Leer Cap
    bilstein set at 1.75, Racho 5000 rear with 4 leaf kit, floor mats, high lift jack, pull hook in hitch, bed rail corner braces, severe duty brake pads and devil horns on the grill....
    I made a light bar when I needed it...a piece of 1/4" x6" x6' steel plate, trailer light kit from TSC,and the trailer light kit had the two lights and a enough wire to make a harness to the trailer socket. The kit even included the flat four plug:). Some change and "S" hooks to hang off the tailgate or bumper and you got a light bar.
    Think long and hard on how you plan to connect the tow bar to the vehicle being towed. This needs to be a structural connection with the ability to pivot up and down in a parallel fashion, and absorb both the towing load AND braking load without excessive play.
    That is why I custom made a plate at attached to 60's era dodge truck bumpers using the bumper mount bolts. I had probably 20 hours of welding and machining time into the attachment plate. Don't forget safety chains.
  5. Jan 6, 2013 at 10:43 AM
    nut
    Patrick
    Arizona
    Totaled
    Sweet, thanks for the info. Yeah I found a couple good bars on CL for under $100 ($500+ when new). Nearest TSC is a ways away, I'll look into kits and see what I can rig up. I'm not hauling the truck till the end of march so I have some time to get all this situated.
  6. Jan 6, 2013 at 10:44 AM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    2nd driver.
    The T100 is a lot to tow behind the Tacoma... possibly over 6500 depending on the trailer/dolly.
    Your gas mileage is going to suck... might actually use less gas driving both trucks.
  7. Jan 6, 2013 at 11:40 AM
    hetkind
    Howard
    Johnson City
    the trailer light kits are also available from Harbor Freight, Northern Tool or probably your local auto parts store. If you are near the shore, get the ones designed for boat trailers since they will be waterproof.
  8. Jan 7, 2013 at 7:48 AM
    nut
    Patrick
    Arizona
    Totaled
    I think it is (well) under the 6500 lbs if I just attach the tow bar. Ive seen tacos on here pulling car haulers with quad cab 2nd gens on them and they dont seem to have a problem, granted they have brakes most likely, but way more weight i believe.
    Just did a search, my tacoma appears to be 4300 pounds at the curb, the t100 just shy of 3500 (probably over that with my tires, but an empty tank of gas will help). Im guess I wont see over 13mpg on the highway, anything over 10 and I'll be happy
  9. Jan 7, 2013 at 7:04 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    If it's an automatic, don't forget to pull the driveshaft and plug the tranny tailshaft.
    Flat-towing in neutral will kill the Toyota trans.
  10. Jan 7, 2013 at 7:31 PM
    2000GTacoma
    Snow Hill NC
    Rich you seem to be knowledgable in this area. I have always wondered why towing a Tacoma flat or with the rearend turning and the tranning in neutral is a problem. Obviously there is a reason I have heard others say it before just always wondered. Sorry to get off topic op.
  11. Jan 7, 2013 at 7:38 PM
    Strautins
    Strautins Well-Known Member
    Nick
    SL,UT
    2019 TRD OR; 2011 TRD OffRoad TX Pro
    2019- 265/70R17 on methods, GFC to be installed: Yukon 5.29, ARB oba, snorkel. (Lift tires armor TBD) 2011- Retired:OME lift, Light Racing UCA, Demello Front, Demello sliders, Brute force rear, TX pro wheels, 285/75s, snorkel, M8000, ARB OBA, Century shell, Relentless skids, Cobra 75
    Why is that specifically bad on an auto but not a manual?
  12. Jan 7, 2013 at 7:41 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    3500 lb trailer without brakes will be potentially unsafe and illegal in some of the states you are driving through. The mountains won't be an issue, because you can use engine braking. Sudden stops for road debris, people cutting you off, etc. will be very difficult.
  13. Jan 7, 2013 at 7:51 PM
    KenLyns
    Belly of the Beast
    Out of curiosity, since the T100 has a stick-shift transfer case, why can't the truck be flat towed as-is with the transfer case in N?
  14. Jan 7, 2013 at 8:38 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Manual transfer case should be okay as they are usually splash-lubed (I'd verify with a Toyota tech to be sure)
    To the above questions, manual trans are splash-lubed just like the diff. There is no pump. If any of the shafts are spinning, lube is getting where it needs to go.
    On autos, the fluid is primarily a hydraulic fluid to operate the clutches, but it is also the only lubrication that the rotating assembly gets.
    The fluid is circulated by the pump, which is driven by the input shaft. They are not splash-lubed... that would cause aeration of the fluid and it would not work in the high pressure circuits.
    Put the trans in neutral and coast downhill with the engine off or at idle and you're spinning your trans either without, or with insufficient lubrication.
    SOME autos can be safely flat-towed in neutral, but not Toyotas.
  15. Jan 7, 2013 at 8:51 PM
    #35
    KenLyns
    Belly of the Beast
    Answered my own question after some digging:
    http://www.pirate4x4.com/forum/toyota-truck-4runner/775780-toyota-bible-faq-2-0-a.html
  16. Jan 7, 2013 at 10:50 PM
    #36
    TACORIDER
    TACORIDER Just another statistic
    JAKE
    EAST TAWAKONI TEXAS
    12 TACO and some other Toyota’s
    Tow bar, but read the manual for proper towing and what gear it needs to be in. Also just be sure to the vehicles hitch that will be towing it about an inch higher then the towbar, incase of heavy braking it wont roll over the bar and rearend yourself. Pulling the driveshafts would make it easy so you dont starve the tranny of fluid and less for something to go wrong with that long a tow, or puT the t case in N. Also be sure and get the tow lights and put on the bumper of your T100 as im guessing it isnt wired in the front for being towed
  17. Jan 8, 2013 at 5:18 PM
    #37
    2000GTacoma
    Snow Hill NC
    thanks makes perfect sense.
