Towing a Tacoma behind an Rv
Discussion in 'Towing' started by Looter, Mar 20, 2008.
  1. Mar 27, 2015 at 5:06 PM
    gearcruncher
    Canadain bumper technician
    Remove 4 bolts on the rear driveshaft and 4 bolts on the front driveshaft and hang the shafts with a rope or bunji cord . DONE
    Sure you have to crawl under the truck and un-bolt the shafts , but its a lot cheaper than an aftermarket pump . Just sayin
  2. Oct 24, 2015 at 8:30 PM
    Skipperh
    Skipperh New Member
    Ralph
    Hainsworth
    I just bought a 2016 Tacoma RWD TRD Sport Automatic. I intended in towing it behind my motorhome. I understand that a Driveline disconnect would be preferred, having a hard time finding a place to purchase/install. Could I tow it with a dolly with the truck back onto the dolly? (rear wheels on the dolly) Leaving the steering lock with the wheels locked in the center (straight)
  3. Jan 4, 2019 at 3:53 PM
    tacitos
    tacitos Tah-Key-Toes
    16 TRDORDCLBJBL
    What's wrong with just putting the gear selector in neutral?
  4. Jan 4, 2019 at 3:57 PM
    HTeeAre
    HTeeAre Well-Known Member
    2016 Quicksand TRD OR 4x4
    You just revived a 3+ year old thread.
    Also "tacitos" is not pronounced "Tah-Key-Toes" if you were to read it in spanish. It's "taquitos."
    I guess I'm contributing to the revival of an old thread, can't really say much then.
  5. Aug 29, 2020 at 3:03 AM
    R2tacos
    R2tacos Supertaco
    Jon
    Raton, New Mexico
    09 TRD Off Road 9” lift
    Everything listed I’ve done myself to truly know my truck. It’s the only way things should be done so you know it’s right. Pro Comp 6" lift front and rear Total Chaos adjustable upper control arms Icon coil overs 3” front lift making the front a 9” lift total Pro Comp Pro Runner shocks rear Old man emu 7 leaf pack U-bolt flip kit EBC Drilled and slotted rotors with racing pads Injen tuned intake Road armor front bumper blinker mod aluminum mesh grill LED dome light LED under hood by pressure switch under body LED LED side markers LED grill lights LED dome light LED interior floor lights LED dash board radio/ gauges LED bed lights LED red rear blinkers Paint matched side steps 1200W Kicker amp 2-JL Audio 500W 12" subs behind back seat black and blue neoprene seat covers front and rear Black and blue steering wheel cover Weathertech floor mats front and rear Weathertech window vents 33x12.5" Goodyear Duratracs 18" Addict all black XD series rims w spare Flowmaster muffler dumps before tires Smoked Painted rear tail lights on outside Smoked inside front lights w clear reflectors HID 10,000K ballast/light kit Siren/mic loudspeaker Lots o green paint. Looking Inside through the grill, clevises, Calipers, drums, lift kit parts,driveline, pumpkin, lids and covers inside the engine compartment.
    Wow what was all that?? I have an automatic 2009 4x4 trd off road. 6 inch lift and I hook up a tow bar. Turn the key just shy of starting it. Put it in neutral. Hookup chain and lights and I'm out. Forget all the other stuff. Are you guys really taking out your driveshaft over and over. It was harder picking out which spike lug nuts I wanted.
  6. Apr 27, 2022 at 8:44 PM
    papamark
    papamark New Member
    MARK
    Like me Looter probably needs something to run around in once he gets to his camp site a trailer or dolly has to be put somewhere both at home and at the camp site
    when not in use, also when making camp ground reservations you have to add the trailer to the length of your motorhome so now instead of needing a 40ft spot you need 60ft which puts you out of a large number of camp grounds. This is why the preferable set up for people that do a lot of motorhome travel is to tow 4 down.
    Unfortunately Toyota dose not want any of their vehicles towed 4 down so if your vehicle is under warranty be careful. The things you need lights preferably a diod systems that allows you to use your Toyota lighting system, in most state a towed vehicle has to have a brake system that works in tandem with tow vehicle, need to either disables the locking steering column or if you put the key in a position other than locked you need a charge wire from the tow vehicle to maintain your battery.
    Etrailer has all the info and parts for most set ups.
