towing a tacoma
Discussion in 'Towing' started by durobs, May 14, 2019.
  1. May 14, 2019 at 5:27 PM
    durobs
    durobs [OP] Member
    Paul
    2006 Silver Tacoma TRD SPORT
    none
    Towing my tacoma TRD OFF ROAD 2018 behind my RV.
    Crodell6 likes this.
  2. May 14, 2019 at 5:29 PM
    verynearlypure
    verynearlypure Clean & Decent
    Ernest
    The Buckeye State
    2015 BRM DCSB TRD OR
    Ray 10’s & Basic Bastard Goodies
    Sounds like gas $$$$
  3. May 14, 2019 at 8:06 PM
    Sprig
    Sprig Well-Known Member
    Ken
    N. Calif. The Twilight Zone
    Tacoma TRD double cab 4x4, Barcelona Red
    Is there a question here? Is there some point you are trying to make?
    PackCon and Crodell6 like this.
  4. May 17, 2019 at 8:59 AM
    Indy
    Indy Master of all I survey.
    Sitting on the couch, watching tv.
  5. May 19, 2019 at 5:15 AM
    Cnasianfire
    Cnasianfire Well-Known Member
    Charles
    Wilmington, NC
    2015 Tacoma TRD off road DCSB
    BFG KO2 285/75/16 ~2" lift (5100s and block)
    You can't flat tow a Tacoma, right?
  6. May 19, 2019 at 7:17 AM
    Groan Old
    Groan Old Well-Known Member
    Ken
    Newton NC
    Black 2011 SR5 4X4,Double Cab, V6/auto
    Stick or auto? In either case, I'd drop the rear driveshaft at the differential end if it were mine and I had no other choices other than flat towing. I hope you have a big RV and deep pockets. Best option would be to get a low-boy car trailer.
  7. May 19, 2019 at 7:19 AM
    windsor
    windsor Just a guy
    Homeless in Oregon
    2008 Tacoma Super Duty aka Tundra
    Canopy, fitted seat covers, OBA with self leveling air bags, 100w solar, dual Rhino Rack Pioneer platforms, side & rear LED work/FU lights, CB, cell booster. 7x16 cargo conversion, 3" lift, 7'x6.5' fold down aluminum rear deck.
    Flat, dolly, or trailer?
  8. May 19, 2019 at 11:10 AM
    Cnasianfire
    Charles
    Wilmington, NC
    Why drop the rear? Wouldn't you have to drop the front one? Just asking because I don't know. Still learning
  9. May 19, 2019 at 3:43 PM
    Groan Old
    Ken
    Newton NC
    Because the front axle is disengaged from the wheels via an auto engagement/auto locking, so the front diff and driveshaft aren't turning when in 2WD. At least I suppose the Taco is like my GMC truck was.
    On vehicles where the front drive requires locking hubs to disengage the wheels, I've seen people add locking hubs to the rear as well for towing purposes. It requires a full-floating rear axle, though, like 3/4 and one-ton trucks have.
  10. May 19, 2019 at 4:23 PM
    Indy
    Some transmissions will lube themselves as they're towed and some won't. Those that won't fail in spectacular ways. Im not sure which way the taco goes. When in doubt the shaft comes out.
    Beretta4x4 likes this.
  11. May 19, 2019 at 4:27 PM
    Clearwater Bill
    Billy
    Largo Florida
    Ok.
    Just use caution if you try to tow the RV with the Tacoma.
  12. May 19, 2019 at 4:34 PM
    Cnasianfire
    Charles
    Wilmington, NC
    Ah, that makes sense. Yes, when in 2wd, you can actually turn the front shaft with your hands.
  13. May 19, 2019 at 6:12 PM
    Indy
    Parasitic drag has to be considered when you have something spinning, even though you can spin it by hand doesn't mean the wheels won't be making the shafts turn in a dry bearing.
    whatstcp likes this.
  14. May 19, 2019 at 6:18 PM
    Cudgel
    Cudgel “Tonka”
    Live in: An Ocean of Plastic Trash
    2017 OR DCLB
    ICON8 Lift -285s. upTOPoverland rack.
    The owners manual addresses this.
    If it were mine, I’d get a really good cover and put it completely on a low trailer.
  15. May 22, 2019 at 9:40 AM
    durobs
    durobs [OP] Member
    Paul
    none
    I am aiming for a trailer. I am just thinking about the future Tacomas and making them towable as an added feature.
  16. May 22, 2019 at 10:06 AM
    Cnasianfire
    Charles
    Wilmington, NC
    So what's the difference between towing it and having it in 2wd (for the front axle). I don't see difference. Would like to know
  17. May 22, 2019 at 10:50 AM
    Indy
    When the engine is running and driving normally everything that needs lube gets it. When the engine is off, no lube. A dry bearing doesnt last long.
    The front axle will be fine, the damage be tcase and tranny.
  18. May 22, 2019 at 10:51 AM
    Cnasianfire
    Charles
    Wilmington, NC
    Not to argue, just don't know. But I don't see how an engine lubs the front axle. Please explain
  19. May 22, 2019 at 10:56 AM
    Indy
    Your diff gears and axles are submerged in oil. They lube themselves. Depending on the transmission if the engine isn't running, there's no lubrication. If you have something spinning dry it will see a lot of damage.
    If you drop the drive lines. There's nothing spinning except the axles and diff gears which still be fine.
    Generally if the manual says no flat towing, it's for a reason.
    Cnasianfire[QUOTED] and whatstcp like this.
