towing a trailer with a 6 speed pointers anyone?
Discussion in 'Towing' started by xrricky, Apr 5, 2013.
  1. Apr 5, 2013 at 4:46 AM
    xrricky
    xrricky [OP] Member
    Rick
    05 tacoma trd off road
    3 inch leveling kit, 33" bfg mud terrain on black american racing wheels
    hello i recently bought a new 24' travel trailer that is 44900lbs dry, i have the electric trailer brake hooked up also the weight distribution bars, i bought it all from the dealer where i purchased the trailer and they gave me all that stuff that is made for the proper weight and set the truck up (with the bars) to tow this trailer.
    i never towed it yet im picking it up this Tuesday,
    my question is, i have the 05 taco trd off road with the Manuel trans, do you guys have any tips or upgrade suggestions (and not upgrade to tundra joke) that i need or should do??
    is there any differences/pros/cons/ to using a manuel trans truck to tow??
    the tongue weight is 390lbs do i/should i put a extra leaf in the back??
    auto trans have trans coolers is there nothing for manuel trans??
    any help will be greatly appreciated
    thank you
  2. Apr 5, 2013 at 4:55 AM
    jake72
    jake72 Well-Known Member
    Jake
    N.E. PA
    2017 trd off-road dcsb
    well a tundra wouldnt help you any way, get a peterbuilt.
  3. Apr 5, 2013 at 5:16 AM
    exploringcarolina
    exploringcarolina Well-Known Member
    Bill
    North Carolina
    2003 Tacoma 2016 Tundra
    Is the TT weight 4490lbs?
  4. Apr 5, 2013 at 5:17 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    I tow one that is about 3,000 loaded to me that's about max for a comfortable tow. 4490# empty is about the same weight as the truck add propane,water, gear etc. you got a hand full. It will pull it but-- if you don't have the 4 leaf spring pack you'll need it maybe air bags the WD hitch will help. The trans does not have a cooler if you have the tow package it does have an engine oil cooler if you don't have the package your tow is rated only 3500#
  5. Apr 5, 2013 at 5:28 AM
    nj636
    nj636 Hub Master General
    Kev
    Jersey
    OME lift 4x sliders 4x skids
    respirator for the clutch smell
    no cooler for a manual trans because the gear oil just lubricates the internals of the transmission (clutch takes the abuse)
    I tow a 3200lb car on an open two axle trailer with my 4 cylinder access cab, with the stock 2 leaf spring I was sagging something awful but now with the dakars it barely squaks. All I can advise is be easy on the clutch.
  6. Apr 5, 2013 at 6:54 AM
    Robertgeejr1
    Robertgeejr1 Well-Known Member
    Robert
    Aorora, Ill, yeah!
    1996 Toyota Tacoma SR5 4x4
    I have done all the hi-pro mods for a life time, since I got this truck at a great price, I will be happy with showroom new.
    Take it easy. no fast starts, or stops.
  7. Apr 5, 2013 at 7:21 AM
    emelianenkov
    emelianenkov Alex Emeliahoweveryouspellhislastname
    Alex
    Holbrook, NY
    Fuck you, it's a Toyota regardless :D
    URD Stage III clutch, URD short throw kit. Radflo 2.0 coilovers. Rear MetalTech progressive springs. Pioneer Audio all around. 600w sub amp
    I would recommend not downshifting when you want to slow down, just use your brakes. That sounds like a HEAVY trailer. No need to put so much strain on your engine and trans. Downshifting with just the truck is fine, but with a big trailer, I'd avoid it
  8. Apr 5, 2013 at 7:26 AM
    xaqori
    xaqori Grammer knotsy
    Zac
    Marietta, Georgia
    '06 4x4 Limo
    ARB lockers and 4.88s front and rear, OME 886s, Dakars, etc., Safari Snorkel, 17"Fuel Revolvers w/ 35x12.50r17 KM2s, fenders cut 3" all around, Pioneer AVH-P4400BH w/ Backup cam, CB/PA (PA Installed), Weathertech Digis, Foglight anytime, AP: front bumper, skids, and pack rack, custom sliders, Warn 9.5XP, dual VIAIR 480Cs with a 2.5gal tank, OTRATTW switches galore, URD y-pipe, RCI skids, LF 240s, etc.
    22 ton trailer? Not with a tacoma...
  9. Apr 5, 2013 at 7:27 AM
    emelianenkov
    Alex
    Holbrook, NY
    Yeah I know right? I was hoping that was a typo...
  10. Apr 5, 2013 at 7:29 AM
    xaqori
    Zac
    Marietta, Georgia
    '06 4x4 Limo
    Wait for it...
    :worthless:
    :cool:
  11. Apr 5, 2013 at 11:15 AM
    12DblCab
    12DblCab I don't know what to write here
    South
    2012 DCSB TRD Sport "Pyrite Mica"
    Ahhh, don't listen to these naysayers. I do it every day.
  12. Apr 5, 2013 at 7:05 PM
    evanmb31
    evanmb31 Well-Known Member
    evan
    connecticut
    09 trd off road
    Satoshi'd grill. blacked out badges. aftermarket sound system. De-chromed and color matched. OME 885s + Dakars with 3rd leaf removed. LR UCAs. Scs stealth 6 with 285 duratracs. BAMF sliders
    Pixels
  13. Apr 5, 2013 at 10:26 PM
    xaqori
    Zac
    Marietta, Georgia
    '06 4x4 Limo
    :cookiemonster:
  14. Apr 6, 2013 at 6:26 AM
    xrricky
    xrricky [OP] Member
    Rick
    It has 3 leafs And I bought a New Reese pro WD
  15. Apr 6, 2013 at 6:34 AM
    xrricky
    xrricky [OP] Member
    Rick
    2 ton
  16. Apr 6, 2013 at 6:37 AM
    xrricky
    xrricky [OP] Member
    Rick
    Thank you this helps a lot. I never thought of it because I Down shift normally with no load. And the trailer has electric breaks and the truck has a New electric break module installed so I won't need to Down shift. Thanks for the heads up
  17. Apr 10, 2013 at 11:41 AM
    Chris24
    Chris24 Well-Known Member
    Greensboro, NC
    09 Black DCSB TRD Sport, V6, 6sp
    Anytime fog light mod Bed mat LED Map and Dome LED bed lights Red LED floor lighting in cab Westin Bull Bar Westin Side Steps Treklights 18" LED Spot bar 2 Blitzpro 6D 2 Blitzpro 6LZ as rear aux lighting Flyzeye V2 Anytime rear camera mod Extang Trifecta tonneau Extra d-rings in the bed Pop n Lock Tailgate Handle
    Towing with my 09 6sp is a pain in the ass...clutch will def smell with a heavy trailer...
  18. Apr 10, 2013 at 12:06 PM
    emelianenkov
    Alex
    Holbrook, NY
    For that I would do the 2wd low range mod. Get started in 2lo and switch to 2hi on the fly if possible
  19. Apr 10, 2013 at 12:23 PM
    MJonaGS32
    MJonaGS32 MJ on a GS
    MJ
    SF Bay Area (East)
    07 Mid-Travel 4x4 DCSB 6spd
    Kings Mid Travel, BAMF bed rack, RTT, dual battery, OBA, ARB locker, 4.56 gears
    2nd gen tacos dont have 2lo or the option to mod it for 2lo
  20. Apr 10, 2013 at 12:42 PM
    Chris24
    Greensboro, NC
    Was wondering what he was talking about, lol
