Towing a travel trailer that is 27'6" and weighs 4546 lbs
Discussion in 'Towing' started by canadian rockies, Mar 19, 2018.
  1. Mar 19, 2018 at 10:20 AM
    canadian rockies
    canadian rockies [OP] New Member
    new to this site,just need everybody's opinion if the tacoma will be able to tow this trailer coz the dealer said that their will be no problem but we are kind of unsure if we will go with this travel trailer or go with the lighter one. waiting for verybody's advise
  2. Mar 19, 2018 at 10:27 AM
    Clearwater Bill
    Billy
    Largo Florida
    Able to tow and able to tow safely and comfortably in all conditions are two different things.
    So what truck do you have, and how is it rigged for towing?
    How experienced are you at towing?
    What would your normal towing conditions be like?
    Is the wt you mentioned dry/empty or wet/loaded? I assume dry.
    When you say the 'dealer said', is that the dealer selling the trailer, or the dealer you bought the truck from?
    Just because something falls under the wt rating of the tow vehicle doesn't mean it's a dream tow.
    First blush says that while the wt may be ok, the bulk would be a killer. That's a pretty long trailer. And I assume it's fairly high? Acting like a parachute behind the truck...........
  3. Mar 19, 2018 at 10:30 AM
    rodrigger
    rodrigger Active Member
    Canada, BC
    2017 Tacoma TRD Sports Upgrade
    Clearwater Bill is right.
    Keep on Truckin' and Vbpiper like this.
  4. Mar 19, 2018 at 10:36 AM
    canadian rockies
    i have the 2017 toyota double cab,actually it's my first time to tow these travel trailer,
    that's the dry weight,and it was the dealer selling the trailer who said it's ok
  5. Mar 19, 2018 at 10:41 AM
    FlyFisherCJ
    FlyFisherCJ Well-Known Member
    Cameron
    Twin Falls ID
    2017 TRD OR DCLB
    I would be hesitant to tow a trailer that size behind my truck. I used to own a ford f250 diesel and it would pull the trailer you mentioned in half, but i bought that truck specifically to tow. I would suggest looking at a lower profile trailer like a pop-up, or something closer to the 3.5klbs rating that way you have wiggle room to load it down.
    just my 2 cents. Good luck!
    Vbpiper, hiPSI and shakerhood like this.
  6. Mar 19, 2018 at 10:42 AM
    musher
    musher Well-Known Member
    Alabama(born) >(the world)>Alaska(now)
    2017 Tacoma
    I'd rather not think of all the $ spent :(
    I agree with the two above. Thats alot to take on, it wouldn't be fun for me
    Vbpiper likes this.
  7. Mar 19, 2018 at 10:45 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    If you plan on towing it long distances then a larger truck would make it much easier.
  8. Mar 19, 2018 at 10:46 AM
    Clearwater Bill
    Billy
    Largo Florida
    So, just remember, he gets paid when you buy.
    Your ultimate satisfaction with the purchase isn't part of his career plan.
  9. Mar 19, 2018 at 10:46 AM
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    If you are going to tow that long travel trailer, invest in anti sway bars linking the trailer to the truck. That length it becomes very easy for the tail to wag the dog, depending on how the trailer is loaded, and its very frightening if you ever have that happen to you. I'd say for two or three trips a year on flat terrain, and you're okay with the slow acceleration etc. it will work, but if you plan to tow that through mountain passes, you would be far better off with a smaller trailer, or a better tow vehicle.
    Clearwater Bill likes this.
  10. Mar 19, 2018 at 10:55 AM
    Metallikatz3
    Metallikatz3 Well-Known Member
    SLC, UT
    2017 DCLB OR
    Always in process
    Can the truck tow that - yes
    Will you enjoy towing, and be comfortable - no
    I'd look at a minimum of a Tundra/1500 to tow something that size.
  11. Mar 19, 2018 at 10:58 AM
    cory02taco
    cory02taco Well-Known Member
    Cory
    Maine
    2013 trd super sport
    V6 with the towing package has a 6400 lb rating
  12. Mar 19, 2018 at 11:02 AM
    SR5 BRI
    SR5 BRI Brian Good Sport
    Brian
    Albany n.y.
    2023 Sport Quadcab
    Alot
    Bill is spot on . Way to much trailer for these trucks. It can do it bit not as well as a full-ize truck
    na8rboy and Vbpiper like this.
  13. Mar 19, 2018 at 11:03 AM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    You have 1500 -2000 lbs of weight to add before breaking the bank. Not much after you include water, gear, people and fuel. Also add the extra difference in weight you added to your truck since it was stock - any new wheels and tires, sliders, skids and bumpers, winch, rack or cap?
    Can you trade back for a Tundra? I try to keep my weight around 4500-5000 lbs max, and even that uses gas like a V10 so I double my fuel capacity by carrying 15gals extra - a lot of extra weight!
  14. Mar 19, 2018 at 11:04 AM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    I've towed 6400 lb many times. I would never tow close to that with the Tacoma. 4K would be my limit and that's everything including passengers and fuel.
    tracker366, na8rboy, Pella and 4 others like this.
  15. Mar 19, 2018 at 11:13 AM
    cory02taco
    Cory
    Maine
    As have I. It isn't something I'd want to do on a regular basis for sure.
    Op fwiw I was looking at the forest river wolf pup 18to. Decent sized for my family of 3 plus the dog, and I think it was like 3700lbs. Might be easier to enjoy the camping trip if you don't have to white knuckle it the whole way there.
    musher, shakerhood and FlyFisherCJ like this.
  16. Mar 19, 2018 at 11:15 AM
    Rowdymoon
    Rowdymoon Well-Known Member
    Courtice Ontario
    2017 Inferno OR SB Canada
    6112's and 5160's
    Have to agree with everyone else on this......thats empty weight...what is the total weight going to be once you add passengers/cargo/full tank etc etc....if your just going across the city once or twice and you take it easy maybe but for prolonged use then yes go with a bigger ride.
    musher and shakerhood like this.
  17. Mar 19, 2018 at 11:55 AM
    Woodrow F Call
    Woodrow F Call Kindling crackles and the smoke curls up...
    Colorful Colorado
    16 DCSB SR5 4X4 "ikea furniture haulers" edition.
    Sometimes, I think people are just overly conservative. You could probably tow it fine, but you will probably want to take every precaution you can to do it safely..... trailer brakes, mirror extensions, weight distribution hitch, drive slow.... etc. Spend a good amount of time learning before you're doing. Check out the 3rd Gen Tow thread too.
    But everyone is right, it'll be easier with a bigger truck.
    stickyTaco and musher like this.
  18. Mar 19, 2018 at 11:59 AM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    That weight and length behind a Tacoma is getting to the territory of "you had better know how to tow." Not a good place to learn.
  19. Mar 19, 2018 at 12:15 PM
    Woodrow F Call
    Colorful Colorado
    I agree. I just feel that in general, there is too much "Oh you can never make that work!" when people ask for advice.
    I've been getting irritated when someone asks a question about how to do something and you get 45 answers about how not to do whatever the OP asked. Maybe I've been online too long.
  20. Mar 19, 2018 at 12:22 PM
    YotaDriver631
    YotaDriver631 Well-Known Member
    '18 Taco
    It will tow it no problem as long as you have proper tongue weight.
