Towing a travel trailer
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Beach Bob, Aug 31, 2017.
  1. Aug 31, 2017 at 5:28 PM
    Beach Bob
    Beach Bob [OP] Member
    2014 TRD Sport with tow package
    Hi all.
    I have done a bit of searching info about towing a TT with my 2014 V6 Taco w/towing pack. Little confused. Here is what I want to do. Pull a TT with dry wt of 3060# and Max cargo of 820#. Tongue wt is 420#. I figure to have maybe 600# passengers and stuff in truck. That's a lot of numbers all adding up to I am not sure if this is a good match or not. Any help greatly appreciated. Oh and yes I plan to pull in mountains sometimes. Thanks in advance.
  2. Aug 31, 2017 at 6:09 PM
    ABNFDC
    ABNFDC Well-Known Member
    Granite State
    2008 4WD Access Cab TRD OR "Rugged Trail"
    265/75/16 Wildpeaks, Dakar rear, HS 2.5" front coils
  3. Sep 1, 2017 at 1:35 AM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
  4. Sep 1, 2017 at 11:26 AM
    edm3rd
    edm3rd Well-Known Member
    Duke
    Memphis TN
    09 PreRunner AC 6sp
    hard tonneau,scangauge
    I believe you are good weight-wise with tow pkg rated at 6400-6500 lbs. Would be concerned with height of the trailer - tall trailer can add a lot of drag. Check tongue weight fully loaded, you may be border-line on needing a weight-distributing hitch. Is it a single or dual axle trailer?
  5. Sep 1, 2017 at 11:39 AM
    stickyTaco
    stickyTaco Fuck Cancer
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Fox/Dakar with Relentless goodies and stuff
    Get a brake controller and a weight distribution hitch and you'll be fine. If you have an auto, don't use D when towing. I'd also recommend an ultragauge or scangauge to monitor transmission temp.
    When packing, put as much in the trailer as possible instead of loading up your truck.
    My trailer is about 5k lbs loaded and I tow it in the mountains. The truck will maintain 55-60mph going up the passes if you're not afraid to make it work.
    bluezzy likes this.
  6. Sep 1, 2017 at 11:49 AM
    bluezzy
    bluezzy Love My SuperCharged 07 Sport!
    Monty
    Eugene, Oregon
    Incredible!
  7. Sep 1, 2017 at 12:35 PM
    road2cycle
    road2cycle Well-Known Member
    Sonoma County, CA
    2014 Tacoma DCLB 4x4 Limited
    What gradient mountains are you planning to tow that trailer over? I'm guessing that will have significant impact if of the Taco can safely handle it going up . . . And down too. For the record I don't tow but if I did that would be one of my initial considerations.
  8. Sep 1, 2017 at 1:36 PM
    Harry
    Harry Science, Bitches
    Santa Fe NM
    15 TRD Off Road DCSB
    I pull about the same amount of weight.
    This is our setup - probably around 5,200 pounds with two bikes + Ruckus, gear and a full tank of fresh water. It was dog slow until I installed a supercharger - now it's just slow. But even before the S/C we could get over the 12,000 foot Colorado passes - in 2nd gear at 23 mph :anonymous: Trailer brakes are a must and my clutch is living on borrowed time.
    I have Dakars and airbags - if I didn't I would definitely get a W/D hitch but with the heavier springs and airbags I don't need it.
    BillsSR5 likes this.
  9. Sep 1, 2017 at 1:43 PM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    cool setup!
