Towing a utility trailer with 2 pallets of sod
Discussion in '3rd Gen. Tacomas (2016-2023)' started by InfernoTacoCO, Jul 27, 2025 at 10:20 PM.
  1. Jul 29, 2025 at 2:46 PM
    #61
    tak1313
    tak1313 Well-Known Member
    2013 Base 2WD
    I don't water our lawn - ever. It lives and dies by the water nature provides it. Most times it does OK, sometimes not, but it is reborn every year. It's like a green Avatar the Last Airbender, always coming back as a new and different Avatar.
    Barsoom, MagicToolbox and ace_10 like this.
  2. Jul 29, 2025 at 3:18 PM
    #62
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    Hey you kids, get off of my "rocks" :)
  3. Jul 29, 2025 at 6:16 PM
    #63
    InfernoTacoCO
    InfernoTacoCO [OP] Well-Known Member
    Hannah
    Denver, CO
    2017 Inferno Orange Toyota Tacoma TRD Offroad
    Westcott Design 0° Sliders, Falken Wildpeak AT3’s, OTT Tune, Interior/Exterior LED lighting, Raptor Lights, WeBoost 4G-M Signal Boost Amp, Trail Grid Pro Front/Rear Anytime Camera, OEM Tailgate Actuator & Wiring, 20% Ceramic Tint.
    It's a tail wagging the dog issue.
    HOA says you have to keep your lawn green. The city says there's water restrictions in place and you can't water at certain times of certain days.
    Shame on the Colorado Legislature for allowing these builders to push KBG and other water intensive grasses here. The entire premise is nuts in my opinion.
  4. Jul 29, 2025 at 8:44 PM
    #64
    Schlappesepple
    Schlappesepple Well-Known Member
    Joe
    2020 4Runner ORP
    Yeah, the local planning department should be advocating for less water-intensive landscaping. That's who could influence the developer/ HOA from the get go.
    tonered likes this.
  5. Jul 29, 2025 at 9:59 PM
    #65
    2021SR5V64WD
    2021SR5V64WD Well-Known Member
    2021 SR5 V6 4WD ACCESS CAB
    Within one week I'd be doing 25 to life if I lived in an HOA.
  6. Jul 29, 2025 at 10:43 PM
    #66
    Suarezabraham
    Suarezabraham Well-Known Member
    Monterey, CA
    2014 Tacoma double cab 4x4
    Yeah that’s a risk loading the trailer n truck heavy haul at ur own risk
  7. Jul 30, 2025 at 3:25 AM
    #67
    Groan Old
    Groan Old Well-Known Member
    Ken
    Newton NC
    Black 2011 SR5 4X4,Double Cab, V6/auto
    Six-lug hubs indicate at least 4500 pound axle capacity, but I agree, with a small single axle trailer I wouldn't try hauling both pallets even with brakes on the trailer axle. A tandem flatbed with a 10K capacity and brakes on both axles would be more appropriate
    Mushrooms mean decaying matter in the soil, not necessarily healthy or fertile. They also propagate from spores, which is one reason you see "fairy rings" of mushrooms in a lawn and the visible mushroom is only 5% of the total plant, most of which is a fine matrix under the surface. Treat the lawn in early summer before the heat really gets started to control fungus. Both KBG and fescue are prone to "blue spot", a fungus that grows on the grass blades when it is hot and dry, and browns the grass.
    Good point. I'm not that familiar with soil types in the Rockies or along its borders but I imagine it is sandier and rockier than here in the Southeast. To hold the root structure and enough water to feed either KBG or fescue you should have 8 inches minimum and preferably a foot or more of quality topsoil. This is one reason the turf rolls may seem to do better, but once placed they will need as much or more water to keep the grass healthy. I have one customer, for instance who has a drainage culvert running through her lawn parallel to the street about 15 feet in from the curb. Midsummer, once the regular Spring rains have stopped and summer T-storms are all we get for water, the grass dies over the top of the culvert because it only has about 8-10 inches max of soil over it (wasn't buried deep enough). Rest of the lawn stays pretty green until it gets really dry.
    What Boomer says below is truth. I've seen a bag of seed that was damp germinate and sprout inside a closed metal garbage can, which is what I keep partial bags of seed in to keep mice from munching on it while stored in my barn.
    From the looks of some of the other lawns I can see in your pictures, you seem to pay more attention to the HOA rules than your neighbors do. I agree, it's a stupid policy to have to follow. You can have green grass, but not without adequate water. Of course there is always spray paint, lol.
  8. Jul 30, 2025 at 4:18 AM
    #68
    tak1313
    2013 Base 2WD
    We rented a townhouse in a dev with an HOA once...once is all we needed to know when we looked to buy a house. Living with an HOA is like living in a police state.
    tonered, 44-16 Taco, Chew and 3 others like this.
  9. Jul 30, 2025 at 5:11 PM
    #69
    SomeTacoDude
    SomeTacoDude Well-Known Member
    I have a little time on my hands so I'm going to respond a little more in depth for what it's worth. I've been a golf course superintendent all my life. As such I don't necessarily understand why sod will work and seed won't. I can germinate seed on asphalt, getting it to grow is another story. If I had to guess, if you had problems starting from seed it was more likely sight prep and follow through. Out of necessity we've had to sod places on the courses I've worked at. Years after I can still see which areas were sodded. It looks weaker and doesn't perform as well. The other problem is, there is just a big difference between varieties of grass. A sod farm is not going to spend the extra money on the better performing varieties. That's the main reason I would go seed. As I think others may have stated a blend of three or four of the top performing varieties should be used.
    https://www.google.com/search?q=Nat...ndroid-google&sourceid=chrome-mobile&ie=UTF-8
    BoomerGVNG and Chew like this.
  10. Jul 30, 2025 at 5:15 PM
    #70
    1994SR54x4
    1994SR54x4 Well-Known Member
    Forget the sod and use native plants. The birds, bees and butterflies will love you for it and you can sell the lawn mower.
  11. Jul 30, 2025 at 5:18 PM
    #71
    Phlogiston
    Phlogiston There are no victims, only volunteers.
    A@!#$@$%#$%
    The wild west
    2016 SR5 DCSB
    Drink lots of beer daily and pee on the lawn
    BoomerGVNG likes this.
  12. Jul 30, 2025 at 5:18 PM
    #72
    SomeTacoDude
    I'm sure the HOA would love that.
    InfernoTacoCO[OP] likes this.
  13. Jul 31, 2025 at 4:56 AM
    #73
    1994SR54x4
    Screw the HOA! They don't pollinate crops that provide food, do they? Death to HOA's. Pollinators forever!
    Phlogiston and tak1313 like this.
  14. Jul 31, 2025 at 5:41 AM
    #74
    tak1313
    2013 Base 2WD
    HOAs will be the death of themselves. There has been so much bad press and anecdotal videos about HOAs over the last few years, it's doing the opposite of the intended purpose - to maintain and improve the value of properties within the HOA by maintaining the quality and consistency of the group.
    These days, people are more likely to NOT purchase a property within and HOA because of the unreasonable requirements and demands. The sad thing is not all HOAs act like police states - much depends on how egotistical and power hungry the board members are - but the bad ones make them all look bad.
    tonered likes this.
  15. Jul 31, 2025 at 5:55 AM
    #75
    jwctaco
    jwctaco Retired, going slow in the fast lane
    Jim
    SW Michigan
    23’ T4R
    Trying to grow grass in aired places is stupid. I kinda understand golf courses because of the popularity/ profit. But neighborhoods in the desert with green lawns is completely unsustainable. Just my opinion.o_O
    Barsoom likes this.
  16. Jul 31, 2025 at 6:21 AM
    #76
    Taco Paige
    Taco Paige Well-Known Member
    21 Trd Sport
    Lift, wheels, rack, storage, air bags
    The Tacomas are great trucks but they in no way can haul what they say they are rated for! I had mine and it struggled to pull my 16 ft aluminum fishing boat at 3500 pounds. I had air bags and a a trans tune and you could feel every bit of it the entire time plus the 10 mpg.. If you want to haul loads by a full size truck I went to a super duty so now I don’t worry about what I can or can’t haul…
    Chew likes this.
  17. Jul 31, 2025 at 8:02 AM
    #77
    RockBunny
    RockBunny Well-Known Member
    Northern NH
    22 LunarTRD DCLB Sport
    I'd be buying rolls of plastic grass. No idea how long it lasts but between the irrigation system, water bill and price of a lawn mower and the time to use it, it sure seems like a person would come out ahead.
    Then again, no way in hell I'd live in an HOA situation.
    Barsoom likes this.
  18. Jul 31, 2025 at 12:29 PM
    #78
    SomeTacoDude
    I would wonder what the climate is where the OP lives. I understand it's Colorado but what would the highs and lows be and how much of a warm growing season they would see? I doubt it would be the case , but I asked because I would wonder if zoysia grass would be a possibility. Purdue University had a test plot at the golf course I worked at recently east of Indianapolis where it would see sub-zero temperatures almost every winter and experienced no winter kill. The question would be if the temperatures would remain high enough throughout the year to keep it out of dormancy. Of course you'd also need to switch over to a reel mower and incorporate airification to reduce thatch levels. Probably not worth it but it would address the limited irrigation aspect.
  19. Jul 31, 2025 at 3:39 PM
    #79
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    That trailer might cut it if you separate the grass from the dirt, leave the dirt behind, and replant the grass
    Barsoom likes this.
