Towing Advice: 3.3k LBs with a '12 4 Cyl 2x4 MT
Discussion in 'Towing' started by Vaerinox, Jun 8, 2019.
  1. Jun 8, 2019 at 1:30 PM
    Vaerinox
    Vaerinox [OP] New Member
    Nicky
    2012 4 Cyl 2.7L MT 2x4 Reg Cab Tacoma
    Hey everyone, Nicky here, just joined the forum. I am a track day junky who originally purchased my Tacoma with the intent of carrying a single sport bike in the bed, but I met a girl track day junky, and that changed. As of recently, we are now up to an estimated 3.3k lbs with the following in tow:
    • 6x12 v-nose cargo trailer
    • Honda Grom in the bed
    • 2x sport bikes in the trailer
    • All equipment in the trailer, including generator, tools, gas cans, etc.
    I am getting concerned about taking care of the transmission because of the weight, and we are located in KY where the speed limits are 70 MPH, extreme hills are common.
    So, my questions to the Taco pros:
    • Is it true I can't use a transmission cooler w/ a MT?
      • If so, would you still recommend purchasing a ScanGauge 2 to monitor fluid temps, or is it a non-issue?
    • Other than favoring the low side of the service intervals, what else can I do to prevent blowing my transmission?
    Appreciate any guidance!
  2. Jun 8, 2019 at 1:35 PM
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    You don’t need trans coolers with a MT. You should be fine.
  3. Jun 14, 2019 at 9:13 AM
    Cnasianfire
    Cnasianfire Well-Known Member
    Charles
    Wilmington, NC
    2015 Tacoma TRD off road DCSB
    BFG KO2 285/75/16 ~2" lift (5100s and block)
    I don't know a lot about MTs, so this might sound stupid, but do MTs ever have a heat issue like ATs?
  4. Nov 7, 2020 at 12:00 PM
    Toyotadilly
    Toyotadilly Well-Known Member
    Dillynn
    Sarasota,fl
    03 prerunner 2008 Toyota Sequoia limited w/tow package..01 echo 310k soon daily
    Bilstein 5100’s.eibach coils.stoptech cryogenic rotors.1.25in toytec blocks.tranmission cooler. Electric fan w/ relay.
    Scan gauge or ultra guage. With the manual your only concern should be service intervals like you mentioned. Ur just changing out the goop , so by watching ur temps ur trans will be happy.
