Towing an older Toyota pickup
Discussion in 'Toyota Trucks & SUVs' started by JoseywalesKFP, Aug 23, 2016.
  1. Aug 23, 2016 at 12:25 AM
    JoseywalesKFP
    JoseywalesKFP [OP] Well-Known Member
    Christian
    2016 Tacoma SR5 4x4
    3"/1" Lowrange off-road leveling lift kit (more to come!)
    ok so I am buying an older. Toyota pickup(1992) 3.0 5 speed 4wd.. And I'm hauling it from GA to Texas, and I was wondering if I could Tow bar tow tow it. I know I need to put the transfer case in neutral but will it still damage something? And the reason I'm doin this or thinking of doing this is for budget reasons.. If anyone has any better ideas let me know!image.jpgimage.jpg image.jpg
  2. Aug 23, 2016 at 2:55 AM
    Ch78
    Ch78 GBO!
    Tomball, TX
    25’ Landcruiser 1958
    Tuned By D3 Performance
    You should try posting these questions in other parts of the board rather than the marketplace. This is the area where people are trying to sell stuff not answer questions.
    You should try a trailer or tow dolly from u-haul. It would probably save you time & money.
  3. Aug 23, 2016 at 2:57 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    I'll still answer.
    I've got a lot of experience in towing vehicles. Pretty much done it all over the years.
    My favorite is to use a tow dolley. Put 2 wheels on the dolley and hook to your tow vehicle.
    You can use the tow bar you have shown, but I think the TD method is a bit easier.
    JoseywalesKFP[OP] likes this.
  4. Jan 21, 2017 at 12:05 PM
    Arctic Taco
    Arctic Taco Firefly, Serenity Ed. -Arctic Taco, a slow build
    Denali Park, Alaska
    98 Tacoma Xtra Cab DLX, 85 Toyota LWB 4x4
    dents and missing bits, built in the Gravel garage, hillbilly trained mechanic…
    Be sure to check your drivetrain fluids, and unlock the front hubs as well. Drink lots of water and check the truck wheels and hubs everytime you stop till you get a feel for how it's towing. I always check the hubs and chains everytime I stop, just a good habit to get into. Towing on the Alcan can teach you to pay attention, keep your speed down and go down hills a gear lower than you went up for safety. Towing with your Tacoma? Remember all you have is your tow vehicle brakes for stopping power.
  5. Jan 22, 2017 at 5:34 PM
    Catcrazed
    Catcrazed Love is Dogs and Toyotas
    Bryan
    Central Oregon
    3rd Gen Flatbed 3.4
    91 Flatbed, 4.88's, ARBs, SAS, 3.4 Swap, 35s, M8000, lots lights, Aux tank, Protech
    I own the same truck and have done some research. You have to take the rear driveline off.
    The reason being is transfer case has no true neutral position on the transfer case also on lubricates but slinging oil up by the gear as it being driven.
    I would be ok for a short distance 20 or less but if you tow it a long ways the tcase will run out of lube and explode.
    I'm going to weld an extra pinion flange under the truck so I just have to unbolt the very rear and then bolt it to the mount.
    Marlin Crawler did a write up I'll see if I can post a link.
  6. Jan 22, 2017 at 5:52 PM
    Catcrazed
    Bryan
    Central Oregon
    3rd Gen Flatbed 3.4
    Flat Towing a Toyota
    Originally Posted by Marlin Crawler
    On all auto chain driven and manual gear driven t/cases, if it is towed in two wheel drive, the output shaft will turn, but there will be no way for the oil at the bottom of the case to get to the top where the output shaft is. On the chain driven cases, the input shaft turns the planetary housing which drives the oil pump. Gear driven cases use the input gear and low range gears to throw oil on the inside of the housing that collects the oil via gutters and directs it to the rear of the case by gravity. Both style of cases, must have the input shaft spinning to lube the output shaft, speedo gears, and rear seal of the t/case. The rear driveshaft must be removed.
    Marlin
  7. Jan 22, 2017 at 6:00 PM
    windsor
    windsor Just a guy
    Homeless in Oregon
    2008 Tacoma Super Duty aka Tundra
    Canopy, fitted seat covers, OBA with self leveling air bags, 100w solar, dual Rhino Rack Pioneer platforms, side & rear LED work/FU lights, CB, cell booster. 7x16 cargo conversion, 3" lift, 7'x6.5' fold down aluminum rear deck.
    I see Toyotas flat towed on a regular basis. People come up from Mexico on a bus with tow bars. Buy 2 Toyota trucks, then flat tow one with the other back to Mexico. Top off diff oils, remove drive shafts, then go for it.
    Remember to increase braking distance since you won't have braking help from the towed vehicle as you would with a car trailer.
