Towing an RV... it is possible believe it or not!
Discussion in 'Towing' started by BML84, Jan 6, 2021.
  1. Jan 30, 2021 at 6:13 PM
    #41
    openspace4x4
    openspace4x4 Well-Known Member
    SF Bay Area
    2017 TRD OR DCSB
    OV Tune
    Hey Sam, That is more than I would go for. I went from a 3,700 lb (dry) trailer to 4,500 lb (dry) trailer and than has made me much more weight conscious. Aim for 4,000 lb if you can, much more enjoyable towing experience.
    ScrippsRanch67 likes this.
  2. Jan 31, 2021 at 2:31 PM
    #42
    Dansly56
    Dansly56 Well-Known Member
    Dan
    Valencia, California
    2013 Toyota Tacoma Baja Edition 4WD
    Light bars, electronic side steps, bed cover, light bars, grills, roof rack, falken tires, method racing rims
    Is this for a E brake controller?
    Cruser711 likes this.
  3. Jan 31, 2021 at 4:51 PM
    #43
    rblalliance
    rblalliance let the wookie win
    08 TRD OR DCSB 4X4
    It looks like this and it's usually located towards the bottom of the kick panel closer to the floor. At least that's where mine was.
  4. Feb 1, 2021 at 5:34 PM
    #44
    a2lowvw
    a2lowvw Well-Known Member
    Justin
    Bothell, Wa
    2019 DCSB Limited
    Stuff and things
    Since I'm in the market for a WDH how do you like the BlueOx? Wondering how loud it is? I was looking at the BlueOx SwayPro but their hitch requires I use the 9 hole receiver and running it 1 hole up from the bottom put's me around 3/8 of an inch higher than their recommended ball height but the next step either direction is 1 1/2 inches.
    Squam_Taco likes this.
  5. Feb 2, 2021 at 3:47 AM
    #45
    BML84
    BML84 [OP] Active Member
    Houston, Texas
    2018 Cement Tacoma TRD OR 4x4
    We haven’t had any issues with our blueox setup or noise but we have the TrackPro, not the SwayPro. Regardless of the brand you go with, I would highly recommend a solid bar & bracket style WDH versus a chain style. I’m sure chains would introduce more noise but ours at speed is silent and even at slow speed and sharp turns (backing into a camp slot or our storage unit) there is minimal noise if any.
    Everyone’s setup will obviously be different based on taco year, trim, mods, and trailer setup but I’m able to only need their 7-hole ball.
  6. Feb 15, 2021 at 2:39 PM
    #46
    jdurk
    jdurk Member
    '16 SR5 4dr 4x4 LB
    Nice looking trailer. Wife and I had our eye on that as well. Purchased a NuCamp T@B320S Boondock last year.
    123552034_1435651889964178_1277254035059_e9d273da400a0c3acf1d48381ed1e70d7c6d3a3e.jpg
  7. Feb 15, 2021 at 6:08 PM
    #47
    ScrippsRanch67
    ScrippsRanch67 Well-Known Member
    Bob
    06 Tacoma Pre-Runner 2wd Quad Cab short bed
    Fiberglass shell
    Are you mainly towing on flat roads? Not too many long grades? I recently made my first trip from San Diego to the Yuma area via Hwy 8 east. (Imperial Dam) I have a 2021 Jayco 154 BH Baja, dry weight 2,800lbs. I was blown away how poor the gas mileage was. Coming back to San Diego from the Yuma side of the Laguna Mtns. is a steeper grade. Really had to push my 2006 Toyota Tacoma Pre-Runner Quad Cab 4.0 V-6 a bit hard to make the grade. I am looking to upgrade to a 2021 TACOMA PRE-RUNNER QUAD CAB 2WD with the 3.5 V-6. What is your experience hauling with your Tacoma? Still tough?
  8. Feb 15, 2021 at 6:23 PM
    #48
    BML84
    Houston, Texas
    Our first four trips have all been around Texas so yes, mostly flat highway driving. I can definitely tell that in my 2018 there is a sweet spot for MPG but unfortunately it isn’t where I want it to be. Because Toyota doesn’t recommend using the adaptive cruise control while towing I’m kind of all over the place. Driving 60 I’ll run around 2500RPMs and MPGs are 12-15 but at 65 it jumps to 3500RPMs and I’ll get 9-11. It’s a battle to keep it consistent using your foot and not cruise so I’m averaging around 11 overall. I could see how driving at grade and higher elevations it could be even worse.
  9. Feb 22, 2021 at 7:25 PM
    #49
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    Yep that’s the one.
  10. Mar 25, 2021 at 1:59 PM
    #50
    adampudliner
    adampudliner New Member
    Adam
    Central Virginia
    2016 Silver Off Road Double Cab
    Bestop Supertop
    I am in the market for a small travel trailer (thinking about the Sunset Park Sun-lite 16bh). The more I read online the more nervous and overwhelmed I became about weights and etc. After reading this post, I feel confident and excited about the prospects of towing a TT that is on the smaller side.
    Thanks for the info and confidence booster!
  11. Mar 25, 2021 at 6:18 PM
    #51
    BML84
    Houston, Texas
    Don’t want to give you a false sense of confidence but with a dry weight of 2,500 I’d say you’re definitely good to go with that trailer. We actually went to a CAT Scale at a Flying J on our last trip to get true weights and our Winnebago with food, gear, and 2 full 20lb propane tanks was right at 4,000 and we’ve had no trouble!
  12. Mar 26, 2021 at 1:00 AM
    #52
    mosccat
    mosccat Well-Known Member
    Mark
    Currently in Bend, OR
    2020 OR
    EDIT: Just read they discontinued it mid 2020. mine is a 19/2020 so hopefully I have one, will check in the morning... Thanks for mentioning!
    I understood all 3rd gens with tow package have a trans cooler no?
    https://www.toyotaofclermont.com/blog/features-youll-love-new-2020-toyota-tacoma/
    "Standard on all V6 grade models of the new Toyota Tacoma is a tow package. This engineering feature includes an engine oil cooler, automatic transmission fluid cooler, Trailer Sway Control, 4 & 7 pin converter, a 130-amp alternator, and a Class IV receiver hitch."
  13. Mar 26, 2021 at 4:49 AM
    #53
    RushT
    North Texas
    It no longer contains an ‘auxiliary transmission cooler’. It only has the one integrated into the radiator.
  14. Mar 26, 2021 at 4:55 AM
    #54
    JC34X4
    JC34X4 Well-Known Member
    J
    Minneapolis
    96 Tacoma 5spd 4x4 single cab.
    This!
  15. Apr 6, 2021 at 6:21 PM
    #55
    drock73
    drock73 Member
    Dan
    PM sent to OP with question on set-up.
    BML84[OP] likes this.
  16. Apr 7, 2021 at 8:44 AM
    #56
    BML84
    Houston, Texas
    Just sent PM reply, let me know if you have any other questions?
  17. Apr 7, 2021 at 11:15 AM
    #57
    BML84
    Houston, Texas
    We took our first trip this month to a TX State Park (Martin Dies Jr.) that wasn’t a full hookup site. Before we left, I added the Roll-N-Lock “QuikRak” to my M-Series cover and 2 Yakima FrontLoader mounts. We also bought a Camco auxiliary tank for easier dumping. Highly recommend all of it for anyone looking for a bike rack solution and the tank was a breeze to use.
    Even with all the additional weight of our new gear, CAT verified weights are still well within ratings!
  18. Apr 7, 2021 at 9:47 PM
    #58
    TacoManOne
    TacoManOne YotaWerx Authorized Tuner
    Paul
    Liberty Lake, WA
    2018 Blazing Blue TRDOR DCLB Premium JBL
    YotaWerx Tuned, Meso stuff, JBL upgrades, Bilstein 6112/5160, RAS
    We just picked up that same tote tank for our Grand Design 17MKE. Great option!
  19. Apr 7, 2021 at 9:57 PM
    #59
    Mr. Excitement
    Mr. Excitement Well-Known Member
    J
    Custom floormats, fuzzy dice
    You guys don’t have issues going up hills? I have a vintage canned ham and I’m always downshifting and flooring it just to maintain speed (60-70mph). Then again maybe the part of CA I’m in is just more mountainous. The trailer is only supposed to be about 1500#. Weird. I think I’m going to have it geared lower, otherwise it’s just a pig.
  20. Apr 8, 2021 at 2:13 AM
    #60
    Mikotaco
    Mikotaco Member
    2017 inferno Tacoma offroad
    Hello all. I’m new to the forum. Just bought my taco in January. New to me 2017 trdor inferno. I’m going to be picking up my new camper(2021 Gulf Stream vintage cruiser 19erd) in a few weeks. I bought an eaz lift WDH and was wondering if I need a sway controller or if the WDH is adequate. Appreciate any input. I should mention the trailer is just over 3000lbs
