Towing an RV... it is possible believe it or not!
Discussion in 'Towing' started by BML84, Jan 6, 2021.
  1. Dec 21, 2021 at 6:40 PM
    #101
    MTB58
    MTB58 Well-Known Member
    Marty
    Prescott, Az
    2022 TRD Offroad DCSB Army Green
    Redar TBC, Window Tint, 265x75x16 Wildpeak, OEM TRD LIft, Soft Tonneau Cover, RCI Full Steels Skids, RCI Sliders
    The round trip Mpg was around 14.5, however I did not tow anything down the hill, just up. The climb up to Prescott is about 4,500' so Mpg took a big hit. We are planning on heading up to the Oregon coast in May of this year, so we will be booking the campgrounds soon. Arizona is a big Snow Bird state, lots of upper midwest campers come here to get out of the cold. Campgrounds can be very difficult to get, especially if you want hook ups. Lots of dispersed camping available though. Start looking asap for late Jan or Feb. I am going to Tucson in Jan and was able to find a state park spot with just electric. Campground has a dump station and water just not at my camp spot.
    Stick to the state park system, less expensive. You might even try Army Corps of Engineers campgrounds. https://www.rv-camping.org/coecampgrounds/
    Be safe and enjoy, lots of beautiful coast line to see.
  2. Dec 21, 2021 at 10:06 PM
    #102
    mosccat
    mosccat Well-Known Member
    Mark
    Currently in Bend, OR
    2020 OR
    Thanks for the tips… Unfortunately we are doing this trip the wrong time of year but will be thankful of getting to a warmer and dryer climate. We’ve seen soo much rain these last 3 weeks, so much… the only good thing about the rain is that CA needs it!
  3. Dec 22, 2021 at 7:16 AM
    #103
    MTB58
    Marty
    Prescott, Az
    Once you get to So Cal and Arizona you will get better weather. Have Fun!!!
  4. Apr 4, 2022 at 7:25 AM
    #104
    mic_sierra
    mic_sierra Toshiba HDDVD is the future
    Elsewhere
    '21 DCSB TRD Sport 4x4 Auto
    This may mislead some. They redesigned the trans cooler; the old external cooler was scrapped for a trans cooler within the radiator. The newer Tacomas have a transmission cooler, it shares space with the radiator. You can follow your transmission fluid lines to the radiator to see where the cooler within a cooler sits in the radiator. I am not a fan of the design and will be adding an oil cooler for my trans in the coming months.
    I think this is what you meant in your post. They discontinued the separate oil cooler that sat in front of the radiator, newer Tacos now have the cooler within a cooler.
  5. Apr 4, 2022 at 7:53 AM
    #105
    mosccat
    Mark
    2020 OR
    Toyota literally removed the transmission radiator from the mid 2020 onwards.
    the coolant radiator is the same for the 2018 and 2022 tacoma. The coolant radiator helps to regulate the trans oil temps. In the 2018 model the coolant radiator (transmission portion) is primarily used to warm up the transmission oil and the transmission radiator is used to cool the trans oil. the same coolant radiator in the 22 it’s used as double duty to warm and cool the oil.
    The 2022 Tacoma uses exactly the same radiator part number as the 2018.
    they did this with the Tundra too.
    Canadian Caber likes this.
  6. Apr 20, 2022 at 1:27 PM
    #106
    PipsTaco
    PipsTaco Well-Known Member
    Jarrod
    Central Valley, Ca
    2020 TRD Off Road
    2020 TRD Off-Road and Minnie Winnie 2100BH with approx. loaded weight of 4500lbs, tongue weight around 470. Like the OP said, do your research and make sure you have an appropriate set up and the Tacoma will do just fine. I have a CURT 6k WDH and Timbren SES bump stops. Redarc brake controller and had my ECU flashed with the CVC tune. Last round trip through rolling foothills I averaged 10mpg, Ca speed limit is 55 with a trailer and I maintained 55-60mph. I would feel safe traveling anywhere with this set up, understanding of course there are limitations and you have to be mindful of how you set up your load for traveling. I wont be passing anyone, but it definitely gets the job done safely
  7. Apr 25, 2022 at 1:38 PM
    #107
    BarcelonaTom67
    BarcelonaTom67 Lost in Translation....
    Tom
    Laurel County, Kentucky
    2017 Barcelona Red Off-Road DCSB M/T
    This is the brand new toy my wife and I brought home this weekend.
