towing and supercharger.
Discussion in 'Towing' started by EdgeR6, Nov 11, 2008.
  1. Nov 11, 2008 at 3:34 AM
    EdgeR6
    EdgeR6 [OP] Member
    Hampton VA
    trd off road
    What are you thoughts. I'd like to supercharge my truck with the TRD supercharger. would the supercharger be good or bad for towing a toyhauler?
  2. Nov 11, 2008 at 8:13 AM
    MyTaco
    MyTaco Well-Known Member
    Az
    08 Prerunner
    BLHM, Grillcraft grill, painted grill and eyelids. 285/70/17 BFG's on 17x9 Pro Comps 5100's all corners
    Don't see any downside to it. More Torque & HP would be great for towing.
  3. Nov 11, 2008 at 8:18 AM
    HerNameIsLucy
    HerNameIsLucy I miss Lucy. :-(
    Equador. Don't know why.
    RIP Lucy.
    She's gone but not forgotten.
    Might want to consider a tranny cooler (assuming it's an auto) and maybe even an oil cooler.
  4. Nov 11, 2008 at 1:06 PM
    EdgeR6
    EdgeR6 [OP] Member
    Hampton VA
    trd off road
    Factory tow package, and I'm a 6 speed.
  5. Nov 11, 2008 at 3:22 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Get a Pyrometer and keep an eye on your exhaust temps. Factory is only good for short periods of 800 to 900* temps.
  6. Nov 11, 2008 at 4:48 PM
    EdgeR6
    EdgeR6 [OP] Member
    Hampton VA
    trd off road
    Please explain?
  7. Nov 11, 2008 at 4:53 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Under a load, with a supercharger, or a turbo charger, your exhaust gasses can run a bit hotter than normal. You can run into problems if your EGT's (Exhaust Gas Temps) get to high. High EGT's are more prevalent in Diesels, but I ran my EGT's to high on my Dodge Dakota and cracked one of my headers. Mind you, it was an 6% grade that was about 4 miles long, and I was hauling about 1000# of crap. But, its something to keep in the back of your mind.
  8. Nov 11, 2008 at 5:30 PM
    wushaw
    wushaw Well-Known Member
    Texas
    08 AC TRD 4x4 6sp
    I know with the turbo you can damage the turbo with excessive EGTs. I had not heard you need to worry about your standard exhaust also.
    If it is a Toyota supercharger then wouldn't Toyota have the EGTs in mind?
  9. Nov 11, 2008 at 6:42 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    You could be right. Also, My issue was with my POS Dodge, so the Toyotas may be ok.
  10. Nov 11, 2008 at 7:13 PM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    i dont see why the TRD supercharger would have any negative effects.... more power/torque and at around 3000+ RPMs where the downshift going up a grade would put you it seems like it could only help. curious.... how big of a toyhauler and what 'toys' do you put in it?
  11. Nov 13, 2008 at 4:04 AM
    EdgeR6
    EdgeR6 [OP] Member
    Hampton VA
    trd off road
    I don't have the toy hauler yet. But teh one I wan to get is a KZ MXT 20
    I guess its about a 25 foot trailer, weighs about 4300 dry. and has a 7k Carrying capacity. Of couse I will not be able to load it fully but.
    Two bikes and gear. 07 Yamaha FZ1 (street) 05 Yamaha FZ6 (track) and associated gear and tools. two pedal bikes. one is an 07 Trek 7000 MTB. The other is the pepsi fila bike that pepsi rewards thing. thats the G/F's she is looking to upgade in the future there may be some dirt bikes to.
  12. Nov 13, 2008 at 5:12 AM
    jasonh
    jasonh tossed salad anyone?
    Dallas, TX.
    2007 Pre Runner SR5
    Billy 5100's
    thats a beast of trailer. probably to big
  13. Nov 13, 2008 at 1:45 PM
    RelentlessFab
    Eric
    Sparks, NV
    +1. we have a 24' Carson Fun runner super-light toy hauler for taking our quads to the dunes. Its rated for 7000lbs and we use my moms '03 Silverado 1500 to tow it and its even a bit big for the 1/2 ton rated at 7800 towing. If you expect to tow a trailer that big you're better off with a Tundra or a 3/4 ton pickup. If the Taco is the only option, dont get bigger than a 21 footer i'd say. Its not just the weight of the trailer thats the issue, its the frontal area bucking head wind at highway speeds, and the weight of the truck. you'd get blown around alot if it got windy.
  14. Nov 13, 2008 at 10:42 PM
    canadiankid
    canadiankid Well-Known Member
    Langley BC Canada
    09 DC LB TRD SPORT
    If you have a DC LB like mine then you are "OK" to pull up to about 27.5'. If you want to check the "max" length for your trucks wheelbase then look here
    www.rvtowingtips.com/how-long.htm As far as the weight goes I would be careful not to go over the GCVW for your truck.
    Good luck and I hope it all works out.
  15. Nov 13, 2008 at 11:24 PM
    sonjay
    sonjay Well-Known Member
    Get a temp gauge on the tranny, bigger cooler too. I've seen alot of crazy things on the hi-ways, the truck will be fine... its up to you to keep it on the road!
  16. Nov 13, 2008 at 11:45 PM
    TRD4x4858
    TRD4x4858 Taco Traitor!
    San Diego
    95 Jeep XJ
    BONE STOCK! lol
    ^^^ second that, Dont let that tranny get too hot
  17. Nov 14, 2008 at 12:01 AM
    MyTaco
    Az
    08 Prerunner
    Guys, it's a 6 speed......
  18. Nov 14, 2008 at 12:03 AM
    TRD4x4858
    San Diego
    95 Jeep XJ
    BONE STOCK! lol
    Oh haha nevermind then. oops haha
  19. Nov 14, 2008 at 9:04 AM
    sonjay
    haha sorry... little bit stoned last night.
