Towing Capacity of Bumper Hitch
Discussion in '1st Gen. Tacomas (1995-2004)' started by 4Barrel, Mar 21, 2010.
  1. Mar 21, 2010 at 11:24 AM
    4Barrel
    4Barrel [OP] Active Member
    What is the maximum realistic towing capacity of a ball hitch mounted on a "tongue section" of the bumper of a 2004 Taco? I want to be able to tow a light aluminum trailer with a 650lb bike... probably a grand all total....
  2. Mar 21, 2010 at 11:26 AM
    Juggernaut
    Juggernaut Captain
    Sacramento
    18 PreRunner TRD OffRoad DCSB
    My 90 pickup is 3500lb, my 2010 tacoma is 3500 lb, I can only guess, but I would guess 3500 lb
  3. Mar 21, 2010 at 12:07 PM
    Jason'sLawnCare
    Jason'sLawnCare Prepared for Bambi
    Jacksonville Florida
    08 4x4 Double Cab TRD Rugged Trail
    CBI Moab 2.0, CBI Trail Rider 2.0, CBI sliders w/kickout, Superwinch EPi9.0S, OME sport shocks w/886 coils, OME n182, 1.5" aal, JasonBuilt 3/16th full belly skid, BuiltRight uca, Body Mount Chop, 285/75/16 km2's, Rear cat delete, exhaust crossover rerouted, Fog light anytime, Locker mod, Rear leaf tsb, Debadged, Uws Tool Box, Electric Exhaust Cutout, AFE Pro Dry S, Kiwi Wifi, Diff Breather Relocated, Grom Ipod Adapter, Dual Diehard platinum batteries isolated by BlueSea marine switch
    3500lbs for no tow package and 5000 with tow package for 1st gens. I think the tow package is only available on the v6's though. Your Taco should be able to handle 1000 lbs easy.
  4. Mar 21, 2010 at 1:53 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    On the bumper??
    OMG....I wouldn't tow anything with that.
    Did you look in the bumper itself? A lot of times, the capacity will be scribed on the plate near the ball mount.
    Be safe and get a hitch mounted to the frame!!
  5. Mar 21, 2010 at 2:11 PM
    gusotto
    gusotto gusotto
    Gary
    Iowa
    2001 Tacoma 4X4 SR5 Extended Cab
    Agreed!!!
  6. Mar 21, 2010 at 2:24 PM
    MAXTacoma
    MAXTacoma Well-Known Member
    Lexus GS 350
    You could get a real hitch like a class III for around $100. They are really easy to install. IMHO it would be worth the peace of mind knowing you aren't going to have any problems.
  7. Mar 21, 2010 at 2:30 PM
    Juggernaut
    Juggernaut Captain
    Sacramento
    I think a hitch would be overkill for 1k lb. Agreed the bumper doesn't look like much, but if it could not tow 3,500 lb I would think Toyota would be liable for a lot damage by now.
    Towed ~1800 lbs on my stock bumper in a 90 pickup, no problems.
  8. Mar 21, 2010 at 2:37 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    I towed a small steel trailer (maybe 400 lbs) with a '94 kawasaki stand up jet ski on it for a total of probably around 700lbs and it was fine. I would not do any more than that though until I get a hitch, just too scary.
  9. Mar 21, 2010 at 3:03 PM
    Jason'sLawnCare
    Exactly. Why would Toyota put themselves in a position like that if it weren't safe?
  10. Mar 22, 2010 at 8:19 AM
    4Barrel
    thanks for the posts! yes, i'm talking just about a ball on the bumper itself, not the overall capacity (i realize it's better with the frame mounted hitch). Ok, so I looked closer at my bumper, and it says 3,500# towing capacity, but then also says 350# ?? I'm assuming this means the ball hitch on the bumper tongue, and higher number is the max for the taco with a frame mounted hitch. 350 seems really low for the bumper... but if that's true, then i've got to get a frame mounted hitch.... any other input is welcome...
  11. Mar 22, 2010 at 8:47 AM
    Juggernaut
    Juggernaut Captain
    Sacramento
  12. Mar 22, 2010 at 9:01 AM
    4Barrel
    awesome info! thanks for the link!
  13. Mar 22, 2010 at 9:29 AM
    swendling12
    swendling12 Well-Known Member
    Sean
    Nebraska
    09 Reg Cab SR5 4 cyl 5spd 4x4
    I've personally maxed out the tongue weight and towing capacity of a bumper without any problems. I towed a tandem axle car hauler, with a 1980's Cadillac on it without any problems. I assume that my Toyota's bumper wouldn't be different if they say 3500lbs/350 tongue weight, then that should be what it can safely handle. If you look at the bumper it's self, the center section which would handle the load is pretty solid/reinforced.
  14. Mar 22, 2010 at 3:52 PM
    Jason'sLawnCare
    As already said 350 is the tongue weight. With the hitch bolted to the frame the 1st gens are rated for 500. Typically tongue rating is 10% of the towing capacity.
