towing capacity
Discussion in '2nd Gen. Tacomas (2005-2015)' started by cfran3, Jul 6, 2021.
  1. Jul 6, 2021 at 6:19 PM
    cfran3
    cfran3 [OP] New Member
    2015 Toyota tacoma limited Edition
    What is the towing capacity for the 2015 Toyota tacoma with the factory towing package? I purchased a horse trailer and the truck seems to be sitting low at the back... The horse trailer is 3500 lb without horses
  2. Jul 6, 2021 at 6:20 PM
    crackedmirror
    crackedmirror Well-Known Member
    make the horses tow their own trailer
  3. Jul 6, 2021 at 6:30 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    6400# trailer weight
    640# tongue weight
    jpmorrisvb and TnShooter like this.
  4. Jul 6, 2021 at 7:31 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Ideally you want 10% of the combined trailer weight on the tongue.
    This rarely happens in the real world.
    The answer to your problem is likely with a load distributing hitch.
    Whether of not the horse trailer is compatible with one? I don’t know.
    There are other options, none that are “totally correct”.
    Better leafs spring or a helper springs would help.
    Possibly even air bags. ( can be adjusted according to load )
    Dm93 likes this.
  5. Jul 6, 2021 at 7:37 PM
    Bishop84
    Bishop84 Well-Known Member
    Honestly its good to do homework but you need to do more than just asking a question online.
    See your mechanic and see whats up. Also they will explain the tow capacity of the truck properly to you.
    A tacoma is not ideal for a horse trailer
  6. Jul 6, 2021 at 7:52 PM
    TnShooter
    Deogee
    STOCK
    That’s probably the best answer.
    I hesitated to say it. Mostly because of all the people that will chime in with what they’ve pulled.
    And how it’s just fine.
    I have pulled “a lot”. But I won’t say how. :D
    Dm93 and Bishop84[QUOTED] like this.
  7. Jul 6, 2021 at 7:53 PM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    hope you only have one horse
    ToyoTaco25 likes this.
  8. Jul 6, 2021 at 7:59 PM
    Bishop84
    My record is 1100kg of dirt in my F150 8ft box. Huuuuuuuuuuuuuuuuuuuuuuuuuge mistake, but the air ride compensated for the weight and I didnt realize it until we got to the scale haha.
    TnShooter[QUOTED] likes this.
  9. Jul 6, 2021 at 7:59 PM
    blu92in99
    blu92in99 Hates everyone, equally
    Justin
    Elk Grove, Ca
  10. Jul 6, 2021 at 8:10 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Don't forget the rated tow capacity is for a truck equipped with a trailer brake controller and a trailer with brakes, if your not using trailer brakes your tow capacity is much less.
    6 gearT444E and Oerski like this.
  11. Jul 6, 2021 at 8:20 PM
    TnShooter
    Deogee
    STOCK
    Same here except it was a long bed Ford Ranger.
    Just over 1 Ton. I think it was 1.06 to be exact.
    I was young. Maybe 19 at the time. It was my Fathers truck. He is a Truck Driver, so I used his truck for the bigger bed. The front tires would squeal around curves. No weight on the front end. I will never forget it. And yes, I did bust the right rear shock.
    I called to tell him how the ride home was sketchy.
    He asked how much it was I had gotten. Needless to say, He wasn’t too happy.
    But he didn’t get mad either. He’s the one that found the busted shock.
    He still has the truck. Last time I drove it it had 267k on it.
  12. Jul 6, 2021 at 10:21 PM
    Gr8rSherman8r
    Gr8rSherman8r OKLA•YOTA
    Owasso
    2015 MGM TRD Sport Longbed
    Done by me: decals, plastidip, and vinyl. More to come. Not done by me: Icon front/rear suspension; Total Chaos UCA’s; Method wheels/34” Falken tires; Prinsu cab rack/LED light bar; V1Air compressor piped to a 2.5 gallon underbed tank; Pelfreybilt front/rear bumpers; Smittybilt front winch.
    I’m dumb enough to attempt stuff but smart enough to try to learn from it, does that count? The bottom ones definitely weren’t just fine though.
    I’d be more comfortable pulling a 3500# horse trailer than two of the loads I have, but I definitely don’t think I’d put a/horses in on top of that. Animals aren’t static loads after all.
    Easy loads I’ve pulled on a tandem axle 14’ flat bed:
    -Multiple loads of hardwood lumber, probably 2500-3000# combined average, no problems; one of them a 200 mile trip, side roads/interstate up to 70mph, max grade 3-4% for less than a mile or two.
    Middling load I’ve pulled on the same trailer:
    -3500# combined of woodworking tooling, no problems there; side roads/interstate up to 70mph, max grade 3-4% for less than a mile or two.
    Retarded loads that were out of necessity at the time, but would never do again, on the same trailer:
    -roughly 3500# by itself milling machine, head/ram separated and close to the tongue; not horrible
    -roughly 4500# by itself milling machine, head/ram separated and close to the tongue, body over the axles; sketchy as fuuuu even nice and slow.
    Both of the last were side roads and max speeds of 25-30, max grade 3-4% for less than a mile, on a total trip of about 25 miles. The axles struggled more than the trailer itself. Unloading them was even more fun.
    It seems like growing up on/around poorish farms, we just learned to make due with what we had available, and drive more cautiously if need be. If something was definitely too much, we’d find someone to help us.
  13. Jul 7, 2021 at 5:59 AM
    Spindifferent
    Spindifferent Well-Known Member
    Central Texas
    2013 PreRunner 4.0 v6
  14. Jul 7, 2021 at 7:13 AM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    You can tow as much as you want.
  15. Jul 7, 2021 at 7:18 AM
    Oldewing1800
    Oldewing1800 Well-Known Member
    2006 Double Cab
    Dog hair, lost happy meal parts from Grandkids....
    My 4000lbs RV is more than my truck want's, it will do it , but not nicely.....
  16. Jul 7, 2021 at 7:24 AM
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
    And reality sets in, it’s going to suck with just one horse on board, 2 horses is asking for trouble.
  17. Jul 7, 2021 at 11:24 AM
    erikshift
    erikshift Well-Known Member
    Asheville, NC
    12 TRD Offroad PreRunner
    5100's, TE37's, KTM in the back
    I've towed a 2 horse trailer with one horse in it a couple of times and I don't think i ever will again. Just feels like too much for the truck.
  18. Jul 7, 2021 at 11:31 AM
    ToyoTaco25
    ToyoTaco25 Well-Known Member
    North Carolina
    09 Super-White DCSB 6-Speed
    ProComp 4" D-Bag, I mean Drop Bracket Lift, AMP Research Powersteps, 285/70-R17’s, Magnaflow, AFE CAI, Dipped Badges
    Oohhh yay another towing thread:deadhorse:
  19. Jul 7, 2021 at 7:21 PM
    lynlan1819
    Tacoma
    Lifted
    Yeap,every Tacoma owner hoping their little Tacoma can tow what a full size 1 ton truck can pull,lol
    ToyoTaco25[QUOTED] likes this.
