Towing concerns
Discussion in 'Towing' started by Danceman, Sep 17, 2008.
  1. Sep 17, 2008 at 12:20 PM
    Danceman
    Danceman [OP] New Member
    Houston
    08 Double-cab 4x4 v6
    I have a 2008 Tacoma Double-cab V-6, 4 x 4, long bed with the factory trailer tow package, and I was wondering if I should install a transmission temperature guage on my truck. I pull a small travel trailer empty weight about 4500 lbs and with added gear of approximately 1000 lbs for a total of 5500 lbs. It appears to pull fine, usaully at 60 - 65 mph, the engine temperature guage is find, but I get concerned about the strain on the transmission. I hate to depend on a idiot light. I get lots of comments from other campers that can't believe my truck pull that much weight. By all the books I'm well below the tow rating of 6500 lbs. It makes me wonder if Toyota is over rating the Tacoma at 6500 lbs. Any thoughts from Tacoma owners about this rating or installing a transmission temperature guage?
  2. Sep 17, 2008 at 12:24 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    welcome to tw!!! good to have you here.:)
    honestly, i dont really think a tranny temp gauge is needed, but for peace of mind, it wouldnt be bad to have. these tacomas tow ratings are pretty accurate, and they can tow 6500 lbs pretty easily if the trailer is equipped right.
  3. Sep 17, 2008 at 12:26 PM
    TheMaster
    TheMaster Born to Ride
    Chicky Baby
    NY
    2007 DC TRD Sport
    Bug shield, window visors, skid plate, rust proofing, tonneau cover, paint & upholstery protection, side step bars, navigation system.
    Its up to you if it would make you feel better. I tow heavy loads from time to time, sometimes upwards of 10,000 pounds. I dont have a gauge to look at :eek:. Look at my picture gallery.
  4. Sep 17, 2008 at 5:02 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    The factory tranny cooler is a very small cooler. It wouldnt hurt to have a larger one installed if you are regularly pulling heavy loads. :)
  5. Sep 17, 2008 at 6:50 PM
    maverick491
    maverick491 Towing Guru
    South Jersey
    07 4x4 Access Cab, TRD off road, 6 cyl, 6 spd
    Activator III brake controller, Extang Fulltilt toneau, Factory bed mat, Extra D-rings in the bed, 2ndary air filter removed, Garmin Ique GPS, Eco-2, AFE Pro Dry-s filter, USASPEC PA12-toy, Pioneer 3-way speakers, SG II on Blendmount, Gulf States Alarm added.
    A temp guage is un-necessary, However, if you were inclined to put a larger tranny cooler in that would be fine as realistically the transmission can never really bee too cool. As for toyota fasly stating the tow rating of the truck, that is not the case, as there is no way the bragging rights of a mid-size truck with a 6500 lb tow rating would be worth the lawsuits and potential liability they'd incurr if it couldn't live up to it.
    You're good to go, enjoy the ride and keep the rubber side down.
  6. Sep 24, 2008 at 3:29 PM
    mvega1969
    mvega1969 Well-Known Member
    Laredo
    '17 Tacoma DC LB 4X4 TRD Off Road.
    I do have also a "towing setup" as yours, plus a LEER camp on mine, I have a Fleetwood Evolution 3 with 3,000 lbs dry and when traveling almost 1,300 lbs on gear and passengers no concerns on 65-70MPH when wind is not against you, but I have not installed any transmission temperature gauge (still waiting for Scangauge II to include it).
    Regards.
