Towing dilemma!! major trailer sway
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Topdogdad1, Sep 26, 2020.
  1. Oct 26, 2020 at 8:43 AM
    mike1056
    mike1056 Member
    Load the blue Quad closest to the tongue, and put the bigger quads over the axles. Looks like your tongue weight might be too much as its loaded right now. WDH will help.
    Muddinfun likes this.
  2. Oct 26, 2020 at 8:51 AM
    Muddinfun
    Muddinfun Well-Known Member
    That looks really good, but I’m guessing you have too much tongue weight for a Taco. Possibly look at switching up the loading order.
    Edit. ^Mike was typing the same thing as I was.
    LoveableWerewolf likes this.
  3. Oct 26, 2020 at 7:24 PM
    Topdogdad1
    Topdogdad1 [OP] Member
    Andrew
    Philadephia
    2007 Tacoma TRD Sport double cab
    Alarm/Remote start (Viper), Pioneer double din 7", Xm direct connect
    Im glad the two of you bring this up. I was always told to load all the heaviest things forward the axle with the old trailer i used (12’ single axle same type). You think the blue one should go first which is the lightest one?
  4. Oct 26, 2020 at 8:03 PM
    Muddinfun
    If you have a bad ass truck, plenty of tongue weight is great. Hauling a really heavy trailer with lots of tongue weight with a Tacoma is bad. The general consensus is that 10% of the trailer weight should be on the ball. A little more than 10% is OK. You probably have 20% or more. Go to a weigh station that’s not being used. Weigh the trailer by itself. Then weigh the tongue weight. Juggle things around till you get it right. Just don’t try to load or unload without the trailer attached to the truck.
  5. Oct 26, 2020 at 11:44 PM
    ICECOLDBEER
    ICECOLDBEER Well-Known Member
    2006 Tacoma 2.7L SR5
    I wonder how much the quads, bike, and trailer weigh? What's max towing for a Tacoma 6000 pounds? Im gonna go ahead and say that is a hefty load for a Tacoma. Can it do it yeah. Is it ideal maybe not. I have a 14 foot I pulled with my 4cylinder a few times and it didn't like it too much haha. It didn't like my 5x8 trailer too much either tbh.
    I agree though too much tongue weight. I would try to put the big quads over the trailer axles. Put the little one upfront and leave the bike at the back.
  6. Oct 27, 2020 at 12:00 AM
    windsor
    windsor Just a guy
    Homeless in Oregon
    2008 Tacoma Super Duty aka Tundra
    Canopy, fitted seat covers, OBA with self leveling air bags, 100w solar, dual Rhino Rack Pioneer platforms, side & rear LED work/FU lights, CB, cell booster. 7x16 cargo conversion, 3" lift, 7'x6.5' fold down aluminum rear deck.
    Just something to check. Looks like your shackle flipped.
    Topdogdad1[OP] likes this.
  7. Oct 27, 2020 at 1:58 AM
    Topdogdad1
    Andrew
    Philadephia
    So i did notice this situation, but i figured it was because of my driveway being on an incline. I will have to check when its hooked and on flat service. I am going to purchase a WDH as well as trying to load the blue machine first which is considerably lighter then the other two. If the blue one is first, all the weight, 80% or more will still be on or forwards if the rear axle on the trailer.
    Very appreciative of all your imput from everyone here. I love my taco and want to get this straightened out rather then going back to a 1/2 ton
  8. Oct 27, 2020 at 5:30 AM
    windsor
    windsor Just a guy
    Homeless in Oregon
    I'll recommend an Anderson No Sway hitch. WD hitch with anti+sway properties built into it. Easy to set up, easy to use, excellent customer service.
  9. Oct 27, 2020 at 5:50 AM
    jake72
    jake72 Well-Known Member
    Jake
    N.E. PA
    2019 trd off-road dcsb mt
    Switch the blue atv with the first one on the trailer and you should be balanced pretty close. If you had an adjustable ball set up like an Andersen , you could fine tune it even better yet.
