Towing enclosed trailer
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Frankenstein09, Apr 17, 2019.
  1. Apr 17, 2019 at 10:54 AM
    FletchLax
    FletchLax Well-Known Member
    Kyle
    Greenville, South Carolina
    2020 Cement SR5 DCSB
    It belongs to my work company, but the guys that gave me the trailer gave me no information on it. Just told me to link up and take it one day. I have no idea if this trailer has any sort of brake system, how can I find that out?
    Rock Lobster[QUOTED] likes this.
  2. Apr 17, 2019 at 11:04 AM
    Shellshock
    Iowa
    is it a 7 pin or 4 pin connector from the trailer? 4 pin is just lights, 7 pin has power plus brakes in addition to the lights.
    Rock Lobster likes this.
  3. Apr 17, 2019 at 11:04 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    Easiest way is to get underneath and look at where the wheel meets the axle. A brake looks like a car brake, there's an 8-10 inch drum behind the wheel with two electrical wires leading to it. If there isn't a brake, it looks like a small axle tube leading straight to the wheel stud mounts
  4. Apr 17, 2019 at 11:07 AM
    Shellshock
    Iowa
    Trailer brakes make a huge difference, especially if you have to stop quickly. The brake controller connects to the truck and when you apply the brakes in the truck, it applies the brakes in the trailer. If you slam on the brakes in the truck with no trailer brakes, theres a good chance something bad happens like the trailer passing you.
    You can adjust the braking for the various loads (more or less braking) and it takes a good bit of load off your truck brakes. They also have a manual switch you can use for testing or if you get into a situation where you need to operate the trailer brakes separately from the truck brakes in special situations.
  5. Apr 17, 2019 at 11:08 AM
    FletchLax
    Kyle
    Just four wires in that connector. So I'm guessing a brake controller does me no benefit?
  6. Apr 17, 2019 at 11:09 AM
    Shellshock
    Iowa
    it really depends on the load and tongue weight. The tacoma suspension is soft for sure, but I've had more issues with oscillation than anything. Swapping to a better shock in the rear made a huge difference in how it rides when towing, especially at highway or interstate speeds.
  7. Apr 17, 2019 at 11:09 AM
    Shellshock
    Iowa
    you've got to have a 7 pin for trailer brakes.
  8. Apr 17, 2019 at 11:11 AM
    Shellshock
    Iowa
    looks like your trailer is 6x10 ish? usually on the smaller trailers, they don't put brakes on by default since the load is usually not much. From what I've seen, its 7x12 is the smallest that usually has brakes.
  9. Apr 17, 2019 at 11:12 AM
    Rock Lobster
    Dee Eff Dub
    I drive a Miata.
    That's surprising, but yes. You need a 7pin round connector to power the brakes, if equipped.
    4 pin flat connectors either indicate no brakes were equipped or someone did a shade-tree modification to the trailer.
  10. Apr 17, 2019 at 11:14 AM
    Tigerian
    Tigerian Well-Known Member
    Iowa, unfortunately
    2024 GR Corolla
    That switch should only be used for testing the brakes. It is a point of emphasis in CDL training that using it in emergencies will result worsening the situation instead of helping.
    Frankenstein09[OP] likes this.
  11. Apr 17, 2019 at 11:25 AM
    Shellshock
    Iowa
  12. Apr 17, 2019 at 11:27 AM
    Muddinfun
    Muddinfun Well-Known Member
    You also need to consider what kind of door(s) you want on the rear. If you are regularly hauling things with wheels (ATVs, motorcycles, riding mower, etc), definitely get a ramp door and a side man door.
  13. Apr 17, 2019 at 2:56 PM
    Frankenstein09
    Frankenstein09 [OP] Well-Known Member
    Russ
    NE Ohio
    06 TRD 4.0 SB
    Freshly stock
    So I work Sub for a guy now who has basically a rolling workshop. 8x16x7 with a drop gate. There are days where we have a hard time getting the space to get the door down. I like the idea of barn doors and heard they might be lighter. Then again sliding a heavy ass door up the ramp might be easier than lifting it up into the back.
  14. Apr 17, 2019 at 2:58 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    Most Tacoma's have ABOUT 6500 lbs tow rating, but the payload is what kills us. A 6500 lb trailer will have 950 lbs tongue weight after you add a required Weight distribution hitch. While theoretically possible to tow it, that would only leave ABOUT 250 lbs in the truck for the driver, passengers and other cargo in the truck. The truck won't have any issues PULLING 6500 lbs. The weak link is that the trucks suspension won't handle the weight. A more realistic limit is 4000-4500 lbs. And I think you can make that happen if you don't go crazy loading the trailer.
  15. Apr 17, 2019 at 2:58 PM
    #35
    Frankenstein09
    Russ
    NE Ohio
    06 TRD 4.0 SB
    Freshly stock
    So in conclusion. Should I worry about towing a 12-14' with some saws and a brake on a bench and a couple hundred pounds of stuff?
  16. Apr 17, 2019 at 3:07 PM
    #36
    Shellshock
    Iowa
    you'll be fine. no worries.
  17. Apr 17, 2019 at 3:16 PM
    #37
    Shellshock
    Iowa
    When you are towing significant weight, weight distribution becomes very important. Too much tongue weight and the truck will be squatting like a mofo, ride like crap and have light steering. Too much in the rear and the tail will wag the dog and you'll probably crash.
  18. Apr 17, 2019 at 3:22 PM
    #38
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    get a half ton
  19. Apr 17, 2019 at 3:33 PM
    #39
    VT_TACOMA
    VT_TACOMA Well-Known Member
    2015 Tacoma DCSB TRD Sport
    This was the day I got my new (to me) trailer. 7X16 tandem, one axle with brakes. With a brake controller in the truck it does fine even when loaded. I purchased it because I'm rebuilding a house and put the house contents in it and it's now parked storage until the house it done. I've towed it several hundred miles (loaded) without any problems. Several thousand with a 7x12 tandem enclosed trailer, and another thousand with my 8X20 flatbed. I've pushed the truck up to the towing limit numerous times with minimal discomfort. Just a note, if your truck has a towing package it should have the wiring up under the dash already for a brake controller. You just need to get a controller and the right wiring to mate with the Toyota plug. Otherwise, plug and play.
  20. Apr 28, 2019 at 5:25 AM
    #40
    Yamaha_TacoR1
    Yamaha_TacoR1 Very slow racer
    NJ/NY, USA
    2015 Black TRD Sport 4x4 Limo
    - 5100/885's, 5100/Icon 3leaf progressive AAL with overload left in, 1/4" Taco lean spacer - ARE Z Series camper shell with Yakima rack system - Tepui Ayer Rooftop Tent - Prinsu Design Cabrac with heavy duty anadized bars - WeatherTech window deflectors/floor liners/bug deflector - Ultragauge MX1.3 - PopnLock codable locking tailgate handle - TRD shift knob - 3M tint - Extang solid fold2.0 tonneu cover - OEM Tacoma muffler tip - OEM Tacoma side steps - OEM Tacoma bed mat - OEM Tacoma roof rack - OEM TRD PRO front grille in matte black - OEM TRD PRO headlights - Fastway FLASH "Solid-Tow" adjustable aluminum ball mount hitch - Reese dual hitch ball covers - Masterlock locking J pin - GoPro windshield mount - Door trim protectors - Side mirror 'fish eyes' - Thule T2 hitch mount 2 bike carrier - LEDs: Map/Dome, 3rd brake, license plate, parking lights, reverse CREE's - SEMA TRD PRO 17" black matte wheels - 265/70/17 BFG A/T KO2s - Black Widow 40" x 95" 3 piece powder-coated folding bed ramp - Mobtown Offroad ribbed tailgate reinforcement skin - GRIDiT center console organizer - Salex center console organizer - Marco Extreme Blast black premium train air horn - 'ImmrYo' Rearview mirror relocate bracket - Mattgecko's Sliding window security bar - Rigid tow rear hitch shackle - Plasti-dipped gunmetal emblems - Blacked out ACEkraut's front license plate relocate bracket - De-flapped (OEM mud flaps gone) - Uniden XL520 CB Radio - Shmellmopwho's CB antenna bed mount - 3ft Firestik II CB antenna - BirdDawg Industries Tech Deck Extreme version w/ 3 Ram 1" ball mounts - Ram Mounts: iPhone6/iPad Mini4 X Grips with 1" dual ball sockets - Garmin GLO portable GPS & GLONASS receiver - Depo LED tail lights with blacked-out inner housing - Various Velcro backed patches on the headliner - 3D-Cell LED Maglite mounted to the driver seat - 4XInnovation DOM weld on sliders with kickouts (welded at 20degree angle) - 4XInnovation Hi Lift bed mounting system - Hi Lift All cast 60" jack with optional handle holder - Lotus Development Hi Lift slider adapter - Relentless Fabrifacfions dual bed rail mounts with dual Quick Fists - Salex glovebox organizer system - YETI vintage bottle opener mounted to the bed - TRD Sport style aftermarket epoxy resin decals for WT front mats - Rigid Industries LED D2 spot lights (Midnight edition) - CBI spot light hood mounts - Air on Board "Zombie Lights" switch - Rebadged WeatherTech floor liners with custom TRD Sport emblems - GoPro Hero 3+ windshield mounted - Mattgecko's cool white LED bedlight kit v2 - 1.25" Spidertrax wheel spacers - Maxsa Escaper Buddy traction boards (mounted on top of Prinsu Cabrac) - 42" Plano Weatherproof gun case (mounted on top of Prinsu Cabrac) - 2gal Rotopax gasoline can, mounting plate, DLX pack mount (mounted on top of Prinsu Cabrac) - Bestek 150W power inverter DC 12V to 110 V - DBPower 600A car jump starter/booster - SOS Off-road Concepts Factory recovery replacement mount - ARB 30' Recovery strap - ARB EZDeflator - Smittybilt receiver hitch D ring with 3/3" shackle - Bosch Icon wiper blades - RCI IFS steel skid plate - Trasharoo trash bag - mounted on tailgate - Lamin X yellow fog lamp covers - Aftermarket illuminated air conditioning/heater/vent knobs - Toyota full frame replacement - Spring 2023 ================================ Future mods: - Rear diff breather relocate - Foglights anytime - Install external speaker for CB - Install mattgecko bedlight kit
    Pulled my 6x12 vnose loaded with race bikes up and down the east coast without issues. Keep and eye on trans temps though during hot months.
    MadDaddy and FletchLax like this.
