Towing experiences
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Robe30, Dec 9, 2024.
  1. Dec 9, 2024 at 7:23 AM
    Robe30
    Robe30 [OP] Active Member
    Pennsylvania
    Lunar Rock 23 DCSB, 1994 Landcruiser
    In the next week or so, I'm going to be buying and trailering home a 1960 VW Bug from Vermont, about 304 miles each way. Most likely, I will be renting a U-Haul car trailer and towing it home with my 23 Tacoma TRD Sport 4door short bed manual transmission. This is going to be an up and back trip, leave at 0400, get there around 930-10, load up and head home. IF things go smoothly, I should be home in time for dinner.
    The bug weighs about 1800 lbs and the trailer weighs approx 2210 lbs for a total of 4010 lbs. The truck is rated for 6400 lbs, so I'm under the max weight.
    My mom uses her 17 tacoma to pull her horse trailer and 2 horses which are around 13-1500 lbs each plus trailer weight of 2300 lbs. She has trailer brake setup etc which I do not have.
    I've towed things in the past but not really over a long distance like this. It sounds like my truck should be up to the challenge but want to be sure I'm not missing something here.
    Appreciate the input
  2. Dec 9, 2024 at 7:45 AM
    OvrlndBigAl
    OvrlndBigAl Well-Known Member
    Alex
    Some where in Idaho!
    Cement 2019 TRD OR DCSB
    Just a Snug Top with Sportsman’s package 1 inch lift and 265/75-16 Duratracs.
    Just do it and enjoy the ride, you’ll get so many mixed responses on here just don’t over analyze it. It’ll tow like a V6 and the MPG will be surprisingly crappy. Yes it’ll rev some but that’s it’s sweet spot. Just load it up, secure it well and as long as the tongue weight isn’t crazy for some reason just hit the road and have fun.
    Patch Barracks and Robe30[OP] like this.
  3. Dec 9, 2024 at 7:47 AM
    lbhsbz
    lbhsbz Well-Known Member
    U haul trailer has surge brakes...so you're good.
    It'll tow fine, just keep it in "S" mode or out of overdrive.
  4. Dec 9, 2024 at 7:49 AM
    Jesse H
    Jesse H Well-Known Member
    Jesse
    Texas
    '22 TRD Pro 6MT
    I've towed maybe 3k lbs with the U-Haul 12' trailer with my 6MT on flat areas. Keep it out of 6th and maybe 5th gear. I'd rather have a half ton but it'll do it. Have fun reversing with that tall gearing.
    Check the surge brakes. The one on my rental wasn't operating properly so it felt like I was getting lightly rear ended at each stop.
  5. Dec 9, 2024 at 7:52 AM
    Buggin112
    Buggin112 Well-Known Member
    Portland, Oregon
    2022 Tacoma TRD Off-Road
    You won't have any issues with the weight. I pulled the same trailer with my Mitsubishi on it, and recently picked up a Volvo Amazon that I towed home. Both weigh more than a bug. I barely knew it was back there. Keep it in S mode and use the ETC.
  6. Dec 9, 2024 at 7:52 AM
    Schlappesepple
    Schlappesepple Well-Known Member
    Joe
    2020 4Runner ORP
    The Uhaul car hauler has surge brakes, so you don't need any setup on your truck.
    Just make sure your hitch and ball are rated for the weight, and mainly just take your time. You'll notice the increased stopping distance pretty quickly, so you can adjust your following distance, etc.
    The biggest impacts will be emergency braking, lane changes, and the extra width of the trailer. Everything else is covered by managing your expectations of speed, etc. I wouldn't go above 65 (the trailer will probably suggest a 55 mph limit).
    Just realized you said you have some towing experience, so some of this is probably redundant. You know the drill: "no hurries, no worries".
  7. Dec 9, 2024 at 8:01 AM
    Bill0351
    Bill0351 Well-Known Member
    Bill
    2023 SR V6 4x4
    Tires/Cap
    That’s ballpark what my boat and trailer weigh. Like other posts say…. It’s working fairly hard to make it happen, but it doesn’t seem stressed by the experience.
    Patch Barracks likes this.
  8. Dec 9, 2024 at 8:14 AM
    Brikan
    Brikan Well-Known Member
    2018 Inferno Tacoma TRD Offroad
    B&M shifter Hood gas strut Injen Intake OSC catch can
    It'll pull 8k+ lbs pretty decently, although without a brake controller, definitely give yourself a bit more space for stopping, and you if you are going through hilly/mountain roads, follow semi truck rules. Use engine as the brake, and save your brakes as much as possible for when you need to stop, because you will only get one chance to come to a complete stop when going down hill.
    I do recommend the Redac brake controller though, and the mounting plate you can get for it on etsy (it does need to be hard-mounted to the vehicle to work properly, get the mounting plate). About an hour to install clean and neatly.
    Although u-hual trailers do come with their own hydralic surge brakes, if you do use u-hual, you shouldn't need the controller as another person above mentioned.
  9. Dec 9, 2024 at 8:19 AM
    Clearwater Bill
    Billy
    Largo Florida
    Chew, Hogleg918 and atc250r like this.
  10. Dec 9, 2024 at 8:20 AM
    jmneill
    jmneill Well-Known Member
    SE
    2018 Tacoma Sport ACC CB Inferno
    :rofl::rofl:
  11. Dec 9, 2024 at 8:27 AM
    atc250r
    atc250r Recovering Ram Owner
    Orange County, NY
    2022 Tacoma SR5 - DC/LB
    LED interior, license plate, and fog lights. More to come.
    Wait. WHAT???
    :eek: :eek: :eek: :rofl::rofl::rofl:
    Chew likes this.
  12. Dec 9, 2024 at 8:28 AM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
  13. Dec 9, 2024 at 8:33 AM
    Brikan
    Not that I would recommend it, especially without a weight distribution hitch or higher capacity suspension, a sway bar or RAS system would be highly reccommended.
    With a manual and mostly stock it will still happily cruise along at 65mph pulling that much. Just pulled 1500 Sierria that weighs even more a couple months ago as well, was just as happy as a peach.
    I tow those around IRL as well.
    JaiOME likes this.
  14. Dec 9, 2024 at 8:36 AM
    jmneill
    SE
    ^^ Yea, like a fucking football field.
    This post is absolutely going to take 1st prize for the worst (and most dangerous) advice given this week on TW.
    And that's a tall order..
  15. Dec 9, 2024 at 8:37 AM
    Gen3TacomaOBX
    Gen3TacomaOBX Well-Known Member
    S
    2018 Tacoma DCSB SR 4x4
    Bilstein 6112 front / 5100 rear (extended) shocks, Headstrong AAL, Firestone airbags, 4.88 gears, OME Carrier bearing drop kit, Aluminum 1/4" skids (engine to transfer). Custom sliders (1.75" HREW tube w/ 3/16" base plates). Custom front bumper and high clearance rear bumper (1/4" steel plate, 1.75" tube.) Apex 5500 winch w/synthetic line (36lbs) and required accessories for an underpowered winch (snatch blocks and extra line.) Tekonsha P3 brake controller, remote start, any-time-backup camera w/ front facing camera, Leer 100R shell (w/e-track single slot tie-down mounts for removable Yakima EasyTop.) Cat shields by CaliRaised. Husky liners, window tint, heated seat (passenger only.) Relentless bed rail brackets with QuickFists (shovel/axe/fire extinguisher.) Hondo Garage Un-holey vent mount. Anytime rear with front facing camera. Billet front seat risers. Viair 88p. 265/75r16 Goodyear Ultra-terrain tires.
    @Robe30,
    Congrats on the VW bug. Your truck is fully capable.
    Make sure you position the car appropriately on the car trailer so that more weight is on the tongue (front of the trailer.) You ~may~ not want to pull all the way forward on the car trailer as that could put too much weight on the hitch. Also.. be prepared to climb out the window of the bug as the uhaul car trailer fenders frequently block the doors from opening.
  16. Dec 9, 2024 at 8:38 AM
    Gen3TacomaOBX
    S
    I have AAL and air-bags in the rear.. otherwise the truck would've had major squat in this picture (aka the carolina croutch.)
    Robe30[OP] likes this.
  17. Dec 9, 2024 at 8:43 AM
    Brikan
    Just becuase It will pull 8k decently with perfect weight distribution, doesn't mean I recommend pulling 8k, I do tow trailers and cargo for a living. Anything below 6k will ride just fine with good weight distribution is the point I'm making, especially for someone asking about 4.5k
  18. Dec 9, 2024 at 8:44 AM
    IownSomeSubarusAndTacomas
    IownSomeSubarusAndTacomas Active Member
    steve
    2017 AC LB OR
    Same as everybody else. I've towed a number of cars on car trailers, sometimes with too much tongue weight, but never had any issues. My 2017 rear leafs are flat at this point.
  19. Dec 9, 2024 at 8:46 AM
    jmneill
    SE
    You actually said 8,000 PLUS, pretty decently, just give yourself a little extra space if you don't have trailer brakes.
    Just wondering where it would get sketchy for you. Towing all proper like, and sans the brakes, of course.
    Dammit man... :rolleyes:
    atc250r likes this.
  20. Dec 9, 2024 at 8:49 AM
    jmneill
    SE
    No, it fucking A plus won't.
    atc250r likes this.
