Towing/hauling heavy...the little engine that could
Discussion in '3rd Gen. Tacomas (2016-2023)' started by southwestorv, Aug 9, 2024.
  1. Aug 16, 2024 at 6:13 AM
    southwestorv
    southwestorv [OP] Well-Known Member
    2022 TACOMA TRD OFF ROAD 6-SPD
    We have the equipment on hand. Nice to see somebody else can speak the language.
  2. Aug 16, 2024 at 6:20 AM
    southwestorv
    Mostly flat, maybe a dozen decent hills, including a steep freeway on-ramp. But this motor makes such good power in the upper rpm’s that I can drop to 3rd at any highway speed and it is comfortable there until I clear the steep hill. Most hills are climbed in 4th. Gradual inclines in 5th.
  3. Aug 16, 2024 at 6:23 AM
    Calamity_taco
    Calamity_taco your friendly neighborhood weeb :3
    Jacob
    I have no idea. send help!
    2017 f-150, 23 Klx300R
    just a couple of things tbh
    incorrect it will be the trans that goes first lmao. i had a 22 ranger and it towed leaps and bounds better then a tacoma did or even could because of how it was built and setup. its trans thou was the weak point and they have since fixed the issue.
  4. Aug 16, 2024 at 6:33 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    I don't have a problem with the weight. The truck and drivetrain will PULL what you have and a lot more. I've PULLED 20,000 lbs with my Tacoma and as much as 30,000 lbs with an old 1968 IH Scout. But I was PULLING the weight, none was on my trucks. It's WHERE you have the weight that is the problem. Put everything in a bigger trailer and I don't have any problems with what you did.
    But the weight in your bed in addition to the tongue weight of the trailer makes this a dangerous situation. The more weight you put on the rear axle, the less you have on the front. And it is the front axle that does 100% of the steering and about 80% of the braking. It's going to take a lot more than this to actually get the front wheels off the ground, but your front wheels aren't firmly planted to the pavement; your steering and braking are compromised with that load.
    Yes, you can do it, you obviously did. And as long as everything goes right, and you drive carefully you can get by. But sooner or later we all have one of those "Oh Shit" moments where something unexpected happens. When that happens, you'll wish you had a bigger truck or a smaller load.
    Flori-duh Taco, Pwakchop and Chew like this.
  5. Aug 16, 2024 at 7:09 AM
    Arries289
    Arries289 Yo!
    Franklin TN
    2018 TRDOR DCSB BBP 6MT Tech & Prem
    I am going to tell you right now that all is well on flat ground towing with a manual trans. But, try being at a stop on a hill with that load. It will change your mind. 2GR-FKS has no torque to move that load below 3000 rpm. Clutch will take a beating.
  6. Aug 16, 2024 at 7:25 AM
    wfo479
    wfo479 Well-Known Member
    NE Ohio
    2020 TRD Pro
    Facepalm.
    BillF1564 likes this.
  7. Aug 16, 2024 at 12:59 PM
    Tacosauro
    Tacosauro Well-Known Member
    23 SR5 V6 & 24 TRD OR
    roof rack
    100K tundra turbo V6 replacements pending speaks otherwise
  8. Aug 16, 2024 at 4:45 PM
    Calamity_taco
    Jacob
    What does that have to do with the Ford engine? Oh right legit nothing...
  9. Aug 16, 2024 at 7:13 PM
    Tacosauro
    roof rack
    That ford engine is less reliable than this disaster
  10. Aug 17, 2024 at 7:01 AM
    Calamity_taco
    Jacob
    Sure bud..that's why there is so many with over 100k miles just fine
  11. Aug 17, 2024 at 7:03 AM
    Tacosauro
    roof rack
    100K is breaking in period for Toyota trucks
  12. Aug 17, 2024 at 8:57 AM
    Calamity_taco
    Jacob
    Not wrong but a lot of Ford turbos have lasted over that and still work fine... You are really some elitist of toyota ain't ya...
  13. Aug 17, 2024 at 9:16 AM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    That recall has absolutely nothing to do with the engine having a turbo. Don’t try to twist facts to fit a false narrative.
    ColoradoTJ likes this.
  14. Aug 17, 2024 at 9:42 AM
    Tacosauro
    roof rack
    Arent you same troll from other thread following me and other people around? ill just report and move on. Damn, some people really need to touch some grass
  15. Aug 17, 2024 at 9:48 AM
    #35
    crazysccrmd
    Alaska
    Aprilia Tuareg 660
    Definitely following you around, you’re just that important of a person to dedicate my time to. Have to make sure you feel special somehow.
    But seriously, what does a recall for shitty quality control on bottom end machining have to do with the turbo?
    iforceAZ likes this.
  16. Aug 17, 2024 at 9:55 AM
    #36
    iforceAZ
    iforceAZ Member
    And how many miles will the v6 go regularly towing all that weight?
  17. Aug 17, 2024 at 10:32 AM
    #37
    Tacosauro
    roof rack
    Spadi_5 likes this.
  18. Aug 17, 2024 at 11:34 AM
    #38
    Calamity_taco
    Jacob
    Pretty sure the one that needs to go and touch grass is you...
  19. Aug 17, 2024 at 1:22 PM
    #39
    GilbertOz
    GilbertOz Driver
    CA
    2014 AC V6 MT 4WD, 84K miles
    FOX 2.5, Deavers, ARB, OTT, 4xInnovations
  20. Aug 18, 2024 at 5:11 AM
    #40
    Spadi_5
    Spadi_5 Well-Known Member
    Wisconsin
    2019 DCSB TRD OR
