Towing in 3.5L vs 4.0L
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Kanween, Jun 2, 2020.
  1. Jun 16, 2020 at 8:05 AM
    #181
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    Agreed on the rear suspension. I have Dakar HD's and it tows much better than stock. I originally just had sumosprings and that was probably good enough for most. I found my SBDC liked to porpoise with a load and stock OR setup on undulating roadways. I do run just SL tires though and have had no issues there. Like yourself I ended up lifting my truck and now looking at replacement tires, I find E load sizes to be about my only real option to fill the wheel wells. I/ve run 265/70-17 for 48k miles or so, but I lifted after buying tires which is dumb of course. So I might end up E load as well eventually. My other ride is also a rav4 lol.
    As or towing, my 3rd gen at speeds and RPM's you have listed is pretty much the same. I'll make a note to check it out next time I tow.
    Cheers mate. Hope all is going well for you.
  2. Jun 16, 2020 at 8:18 AM
    #182
    RX1cobra
    RX1cobra Well-Known Member
    19 OR
    You claiming your loaded down truck spins the tires if you lay into it is what's funny.
  3. Jun 16, 2020 at 8:21 AM
    #183
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    1st one compares same load same terrain
    same tyres .........same gearing
    no less over time the manufacturers attempt to appease the EPA rears its ugly head
    flat /level no grade........weight only affects acceleration
    grades will pull down an engine dramatically................even in a 6litre V8
    a large camper will add essentially more drag than a compact weight oriented structure
    the top gears stick/auto dont provide much advantage
    no less are EPA dominated
    iv towed Flat Florida with the weight U described far faster
    i would think something the matter with any Taco that couldnt run faster than 55mph
    AKGSD likes this.
  4. Jun 16, 2020 at 8:22 AM
    #184
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    :notsure:
    Tongue load works in both directions, esp with a high CG load.
    Junkhead and Lt. Dangle like this.
  5. Jun 16, 2020 at 8:27 AM
    #185
    Lt. Dangle
    Ohio
    I'm at 1700 rpm @ 55 in 5th. I just checked lol.
    tonered likes this.
  6. Jun 16, 2020 at 8:30 AM
    #186
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Note that ATs and MTs, 2.7l and 3.5l, and 2nd Gen and 3rd Gen all have different gearing. I'm sure that you know, but it all factors in.
    I wish I had the 2nd Gen chart. I think the 4.0l MT was 4.56 gears with 5th at 1:1?
    In general, this site helps me quite a bit:
    http://www.grimmjeeper.com/gears.html
  7. Jun 16, 2020 at 8:33 AM
    #187
    Lt. Dangle
    Ohio
    Of course. Mines auto, MT guys are probably at 2k or so.
    tonered[QUOTED] likes this.
  8. Jun 16, 2020 at 8:34 AM
    #188
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Right around there.
    shakerhood likes this.
  9. Jun 16, 2020 at 9:05 AM
    #189
    Steadfast
    Steadfast Well-Known Member
    Thane
    S.W. Ontario Canada
    2013 Limited
    I think your 3rd gear ratios are likely the same ish as my 4th so yah your speeds and rpm would be similar.
    Junkhead and tonered like this.
  10. Jun 16, 2020 at 9:18 AM
    #190
    Lt. Dangle
    Ohio
    3.73 to 3.91 AT or 4.3 MT I think.
    Corrected MT ratio
    tonered and Steadfast[QUOTED] like this.
  11. Jun 16, 2020 at 9:36 AM
    #191
    Steadfast
    Thane
    S.W. Ontario Canada
    2013 Limited
    Thank you Mr. Dangle. Does that amount to much rpm difference you think?
  12. Jun 16, 2020 at 9:37 AM
    #192
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    4.30 on the 3rd Gen 3.5l MTs, but you need to add in the tranny ratio and tire diameter. That is why I like that website. Like you did, I mainly check it for top gear RPMs, and also 1st gear crawl speeds.
    Lt. Dangle[QUOTED] likes this.
  13. Jun 16, 2020 at 9:41 AM
    #193
    Steadfast
    Thane
    S.W. Ontario Canada
    2013 Limited
    Why do you find that funny? The trailer is heavier than the truck so naturally when I accelerate from a stop it wants to spin the tires if I'm to heavy on the peddle.
  14. Jun 16, 2020 at 11:24 AM
    #194
    Lt. Dangle
    Ohio
    Few hundred based on users feedback and gear ratio calculators.
    tonered likes this.
  15. Jun 16, 2020 at 11:26 AM
    #195
    Lt. Dangle
    Ohio
    Fixed that, thanks. That's what I get for posting while doing my physical therapy I guess.
    shakerhood and tonered[QUOTED] like this.
  16. Jun 16, 2020 at 11:27 AM
    #196
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Pfft! No big deal.
    Good discussion here!
  17. Jun 16, 2020 at 11:34 AM
    #197
    NV_Spencer
    NV_Spencer Well-Known Member
    2020 CREWMAX / 2017 OR DCSB
    Great advice on suspension & E rated tires (just had ko2s installed). Should one considering re-gearing also or does that not really apply here?
    Steadfast[QUOTED] likes this.
  18. Jun 16, 2020 at 12:08 PM
    #198
    Steadfast
    Thane
    S.W. Ontario Canada
    2013 Limited
    I also have KO2s on my truck. I find the gearing in my truck to be perfect. I can’t speak for the 3rd gens.
  19. Jun 17, 2020 at 12:32 PM
    #199
    ROAD DOG
    FEW
    wrong gear .........
    Junkhead likes this.
  20. Jun 17, 2020 at 4:35 PM
    #200
    Lt. Dangle
    Ohio
    No, at 55 I am at 1700 RPM in 5th gear.
