Towing in 3.5L vs 4.0L
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Kanween, Jun 2, 2020.
  1. Jun 3, 2020 at 7:28 PM
    #61
    CaptainBart45
    CaptainBart45 Well-Known Member
    Bart
    2017 Tacoma Sport 4x4
    Work in progress...
    We need to hook a 2nd gen and a 3rd gen up and have a tug of war.
  2. Jun 3, 2020 at 7:39 PM
    #62
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    Fuck yea, that would be the ultimate challenge.
    Although the 4.0 will win due to the mega torque down low.
  3. Jun 3, 2020 at 7:42 PM
    #63
    MDFM31
    MDFM31 Well-Known Member
    Chester Co, PA
    16 DCSBOR
    OP, with a growing family and regularly towing that kind of weight, maybe you should consider a Tundra. If you get a double cab Taco, you will probably trade it in on a Tundra when your kid(s) get bigger. I would personally not buy a Tacoma planning to tow 5k regularly. They are rated to 6800, but I just would not ask it to work that hard. These trucks were really not made to tow like that.
    I had a 2006 V6/6 speed before my 16 V6/auto. That manual trans was terrible. The 1-2 drop was terrible, my 3rd gear synchros we're about done by 80k and the whole throw out bearing issue. That's why I got the auto, and it is a better transmission. The programming leaves something to be desired, but we have OV Tune for that.
    As others have said, the 3.5 likes to sing. My manual 4.0 was peppy down low but ran out of steam pretty quick. The 3.5 just pulls harder and harder the more you wind it up. Even so, I would not buy this truck while planning to tow that much weight. Even if you add forced induction or change the R&P ratio, you have just moved the weak spot around. Add the power to pull the weight, now you need to keep the (auto) trans cool...now you need better brakes to stop it and suspension to carry it...
    The lower, wider and heavier Tundra will always be significantly better at towing.
    VanGo3, Keggaward and Chew like this.
  4. Jun 4, 2020 at 5:32 AM
    #64
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    The thing about the 4.7 i had only made 245 hp opposed to the v6 3.5 tacoma's 278. That 4.7 would spin around 2200 rpm at 70 mph towing my 2000 lbs like childs play. With the 3.5 i have to run it in 4th gear in the ect mode just to meet/keep the 65mph highway speeds with the same load. Took me some time to get use to the higher rpm this 3.5 is capable of. I guess thats what you get when you put a car motor in a truck.
  5. Jun 4, 2020 at 6:14 AM
    #65
    Taco1701
    Taco1701 Well-Known Member
    William
    GA
    2020 DCSB TRD Sport 4x4 Cement
    Those are peak numbers though. The 3.5 makes 278 hp at 6,000 RPM. Cruising at 2,000-2,500 RPM, I would bet the 4.7 is making more power and torque in that range. There are some dyno charts floating around and if I remember correctly, there's a pretty decent drop in power below the 3,000-3,500 RPM range in the 3.5. It would be interesting to see the power curve for all of these different engines.
    AKGSD and zoo truck[QUOTED] like this.
  6. Jun 4, 2020 at 9:07 AM
    #66
    Keggaward
    Keggaward New Member
    Kev
    2008 Toyota Tacoma Off-Road
    4” lift
    I’m have the same problem with my 3rd gear. What did you have to get done to fix the issue?
  7. Jun 4, 2020 at 9:13 AM
    #67
    Gen3TacomaOBX
    Gen3TacomaOBX Well-Known Member
    S
    2018 Tacoma DCSB SR 4x4
    Bilstein 6112 front / 5100 rear (extended) shocks, Headstrong AAL, Firestone airbags, 4.88 gears, OME Carrier bearing drop kit, Aluminum 1/4" skids (engine to transfer). Custom sliders (1.75" HREW tube w/ 3/16" base plates). Custom front bumper and high clearance rear bumper (1/4" steel plate, 1.75" tube.) Apex 5500 winch w/synthetic line (36lbs) and required accessories for an underpowered winch (snatch blocks and extra line.) Tekonsha P3 brake controller, remote start, any-time-backup camera w/ front facing camera, Leer 100R shell (w/e-track single slot tie-down mounts for removable Yakima EasyTop.) Cat shields by CaliRaised. Husky liners, window tint, heated seat (passenger only.) Relentless bed rail brackets with QuickFists (shovel/axe/fire extinguisher.) Hondo Garage Un-holey vent mount. Anytime rear with front facing camera. Billet front seat risers. Viair 88p. 265/75r16 Goodyear Ultra-terrain tires.
    Are you asking about the 2nd gen manual shifting issue he mentioned? If so, it sounds like they sold it to 'fix' the issue.
  8. Jun 4, 2020 at 9:19 AM
    #68
    MDFM31
    Chester Co, PA
    16 DCSBOR
    Rev matched until I sold it
  9. Jun 4, 2020 at 9:20 AM
    #69
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    Same way I solved the same problem with my FJ.
    Junkhead likes this.
  10. Jun 4, 2020 at 9:27 AM
    #70
    Keggaward
    Kev
    4” lift
    Same thing I’ve been been doing. Been to much of a hassle to just do anything with it
  11. Jun 4, 2020 at 9:31 AM
    #71
    MDFM31
    Chester Co, PA
    16 DCSBOR
    Wasn't worth fixing, to me anyway. I know the 3rd gen trans is a different unit, but I did not have the faith in Toyota's selection of manual trans anymore
    Lt. Dangle likes this.
  12. Jun 4, 2020 at 9:37 AM
    #72
    Wyckedan
    Wyckedan Well-Known Member
    Dan
    Woodinville WA
    2014 Stormtrooper AC 2009 Ducati Hypermotard 1100s.
    1 fully operational Death Star
    If I wanted more room AND the ability to tow often and comfortably, a Tacoma definitely wouldn't be what I was looking at. Ecoboost F-150.
  13. Jun 4, 2020 at 9:44 AM
    #73
    Keggaward
    Kev
    4” lift
    I agree, my next purchase will be automatic 3rd gen taco. I lost faith in the manual when it started doing this at 90,000 and the 1st gear drops are the worst I’ve ever had. My 1st gen was great so I though I’d go 6 speed. Never again
  14. Jun 4, 2020 at 9:48 AM
    #74
    Hal_XIII
    Hal_XIII Well-Known Member
    Chicagoland
    19 Tacoma Trd O/R 4x4 S/B 6spd auto cav-blue
    Bilstein shocks & springs. Method 16in wheels Rigid led fogs 265/75 16 BFG KO2s
    The 3.5 without ECT activates drives “heavy” on purpose. The 2013 benz I had would feel the same way unless I put it into sport mode.
    it makes the throttle less sensitive to improve mpgs and cut down heavy acceleration.
    point I’m trying to make is that if you’re towing I recommend ect activated. The throttle response will be better since the electronic throttle will take less force to open up.
    if you have a manual, I say use whatever gear you need to get yourself going. More weight, more power and lower gear.
    I personally hated the manual trans on the 3rd gen so I went back to an auto.
    don’t be afraid of the higher rpms, the Atkinson motor doesn’t open your valves all the way until after 3000rpms.
  15. Jun 4, 2020 at 9:51 AM
    #75
    kmmn
    kmmn Member
    Martin
    I love it when people say "can't tell it's back there." I've never not felt a trailer's drag, even with my Yukon XL 2500 with 4.10 gears... it pulled, but you knew something was back there. Tow with a Tacoma and you can pretty much feel it before it moves... nice truck, but it's just not a towing machine
  16. Jun 4, 2020 at 10:46 AM
    #76
    MDFM31
    Chester Co, PA
    16 DCSBOR
    It's not an Atkinson cycle engine; it's an Otto cycle engine with enough variance in the valve timing that it can simulate the Atkinson cycle. It only goes into "Atkinson mode" at light load, so you probably wouldn't get into it while towing. And the valve lift is the same no matter the mode or the rpm. The timing is what changes.
    The 3.5 is very oversquare, meaning the bore is larger than the stroke. This is the primary reason it likes the high end. An F1 car that idles at 4000 rpm is extremely oversquare, where a class 8 diesel that redlines at 2200rpm is extremely undersquare. The 4.0 was undersquare by 1mm.
  17. Jun 4, 2020 at 10:54 AM
    #77
    Gen3TacomaOBX
    S
    That's your take and your experience.
    Here's my CSB:
    I have a single axle smooth rollin' aerodynamic travel trailer that weighs only 2600 lbs and can easily forget it's back there. Sometimes when I get to my destination and disconnect the trailer I continue taking corners and pulling into lots like it's still back there. :)
  18. Jun 4, 2020 at 11:01 AM
    #78
    RX1cobra
    RX1cobra Well-Known Member
    19 OR
    Spot on. The 3.5 and 4.0 share the same bore. 4.0 gets the extra displacement from stroke and explains the better low end. But the 4.0 was no TQ monster either despite what 2nd gen owners yap on about.
  19. Jun 4, 2020 at 11:07 AM
    #79
    CanadaToy
    CanadaToy Well-Known Member
    Greg
    Toronto
    17 DCSB TRD OR Alpine
    TRD Pro grille & skid, OEM tonneau and roof racks
    4.0 felt alot more torquey because of the tuning. with the OVT the 3.5 doesn't feel too much less torquey at low rpm. however, the 4.0 stock was out of breath by 4500 rpm where the 3.5 (with the OVT) revs to 6800 no problem.
  20. Jun 4, 2020 at 1:07 PM
    #80
    Masterofnone
    Masterofnone 140.85
    Bobby
    Kansas
    2017 TRD Sport AC MT
    I'm still trying to figure out how to drive my truck without having to slip the clutch going from 1st to 2nd
    Kanween[OP] likes this.
