Towing in different mountain grades
Discussion in 'Towing' started by OffsetPlayer2, Aug 3, 2015.
  1. Aug 3, 2015 at 10:08 AM
    OffsetPlayer2
    OffsetPlayer2 [OP] Cornbread fed
    In the woods and fields, NC
    17 DCSB Off Road 4wd
    Weather Tech floor mats
    What sort of grades are you guys towing in and what are you towing? I'm asking because mid September the wife and I are heading back to the mountains for the weekend. We normally go tent camping or stay in a cabin there. This time we are taking the travel trailer. It's a Rockwood A122S.
    The specs say it's about 2k dry. We aren't going to be filling the water tank since the campsite has water. There may be 100-150lbs in the trailer and maybe another 500 total (including people) in the cab of the truck. I don't expect mpg's to be all that great and that's ok. I'm just more concerned about making the grade. I've seen plenty of others do this no problem when traveling but it's always been someone else I pass, not me. The mountain pass is about a 5% grade for a mile. After that it levels off pretty good.
    I'm not too concerned with cross winds as the camper folds down. It has brakes and I've got a controller for it. I've also added a small helper spring to help reduce sagging. I normally just tow this about 30 minutes down the road on flats but this will be a new experience for us as this will be a six hour trip.
    Edit: Found a link that explains the ascend and descend of the mountain I'm talking about:
    http://www.crashforensics.com/blackmountain.cfm
  2. Aug 4, 2015 at 5:44 AM
    WHT.RUS
    WHT.RUS Well-Known Member
    You will be fine. I towed my 18 ft toy hauler loaded about 4500 total with 4 adults on 7 percent grades. Keep it in 4th and you are good to go. My rpms would hold around 3500 to maintain 55 going up hill.
  3. Sep 8, 2015 at 4:26 PM
    nagelg
    nagelg Well-Known Member
    George
    Northern Wisconsin
    2015 TRD Sport
    No worry. I hauled a 3000# camper over Vail pass (7%) last year with a 4cyl Taco. I was in the truck lane, 2nd gear and about 4500 rpm. You will do just fine.
  4. Sep 8, 2015 at 4:31 PM
    mountainwolfpup
    mountainwolfpup Ford Guy (Formerly known as a Toyota Guy)
    Vancouver, WA
    2015 Ford F150 Lariat FX4 3.5l Eco
    First month of ownership... This month I'm removing front air dam, and also Rhino lining the bed.
    X2, keep it in 4th gear. That prevents the truck from shifting into "overdrive" which is hard on the transmission when towing.
    I do a similar load to you and pull similar mountain passes on a pretty regular basis in summertime and have no problems. I don't even use my trailer brakes (they were too annoying) and the gearing on the Tacoma auto is so good on downhills I rarely miss them (note: they are required over 3500 lbs in most states).
  5. Sep 11, 2015 at 7:15 AM
    Indy
    Indy Master of all I survey.
    Don't be afraid of rpms. Your engine won't explode at 2200 as people seem to think. I live about 5 feet from the surface of the sun and go even higher when hunting. I run in pretty much third gear for an entire day towing a couple thousand pounds, over 4k rpm the entire time to stay 55-65 on the interstate. A 1 mile grade, it wouldnt even cause a moments thought.
    To get where im going, miles of 5% or worse at a time. Russia asks me to drop off care packages at the space station since im headed that way. You end up passing god you get so high (nice guy but has too many cat posters in his guest bathroom for some reason). Aliens pull over to ask where the hell you think youre going.
    I think youll be fine.
    TRDtacoHF and NMroamer like this.
  6. Sep 24, 2015 at 6:15 PM
    NMroamer
    NMroamer Well-Known Member
    Fred
    Albuquerque
    2015 TRD OR
    Indy pretty well summed it up. I start out at a little over 5400 feet ( a little lower than him) and can see 10 % grades going North pulling a 3100 lb travel trailer. Slow and easy works every time.
    Your route is kinds flat by Western standards
