Towing in my 2014 tacoma?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by taxidermist, Jun 27, 2015.
  1. Jun 27, 2015 at 9:25 AM
    taxidermist
    taxidermist [OP] Member
    north Carolina
    12 access cab 4x4 5spd base
    Hi guys,
    im relatively new to owning this tacoma. Last august, I purchased a new 2014 tacoma 4 door, 4.0, automatic. It has the factory towing package with the 7 prong plug. I recently bought a 14ft lowe jon boat.
    My owners manual doesn't say anything about what gear to tow in.
    It has low,2,3,4,and D on the shifter, but no OD OFF SWITCH! ?
    I've always drove fords and Chevy and they all had OD off switches.
    Should I just tow in 4? (It runs very high rpm) .
    May sound like a dumb question. A friend of mine had a 2013 that had an OD off switch beside the A-Trac switch. Did they do away with that in the 14's.
    Thanks
  2. Jun 27, 2015 at 9:33 AM
    S and J
    S and J Well-Known Member
    Scott
    Las Vegas
    2015 AC SR5 Off Road Package
    I left my in drive and just took it easy and eased into everything. Had no problem except my mpg was shot in the face. I have the 2015 4.0 auto so similar trucks.
  3. Jun 27, 2015 at 9:35 AM
    js312
    js312 Well-Known Member
    Joe
    New England
    23 F150 PowerBoost Lariat 502a
    Husky Weatherbeaters, OEM Mud Guards, Wheel Well Liners, Bullet Spray-In Bed Liner, Gator Soft Tri-Fold Cover, Michelin LTX M/S2 (Summer), Blizzak DM-V2 (Winter)
    4 is exactly the same as other makes OD off switch.
    ...and yes, you generally should tow in 4th.
    taxidermist[OP] likes this.
  4. Jun 27, 2015 at 9:38 AM
    S and J
    Scott
    Las Vegas
    Good to know...
  5. Jun 27, 2015 at 3:20 PM
    taxidermist
    north Carolina
    10-4 thanks guys
  6. Jun 27, 2015 at 8:35 PM
    smd3
    smd3 Well-Known Member
    Unless they changed the manual it says to tow in 4.
