Towing in OD...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 1of7627, Jul 30, 2014.
  1. Jul 30, 2014 at 4:16 PM
    1of7627
    1of7627 [OP] Well-Known Member
    Mark
    Post Falls, ID
    '14 DCLB Ltd, '63 Corvair Spyder
    Things I need to tow.
    Searched and found a couple of old threads that mentioned it, but wanted to get a current consensus.
    Those of you with V6 auto Tacomas with the tow package who tow trailers of mid-range weight (say 2,500 lbs), do you tow in 4th or OD 5th? The old consensus was to use 4th (direct) and I'm okay with that. I tow in mountains, flatland and rolling hills and generally keep the speed under 65. Thanks in advance.
  2. Jul 30, 2014 at 4:33 PM
    AEmedic
    AEmedic Well-Known Member
    Boise, ID
    2014 DCLB 4X4 TRD Sport Supercharged
    TRD Supercharger, Toytec Adj. Coil-Overs, Bilstein 5100's, JL Audio system w/Kenwood DNX9980HD HU
    I tow in 5th until it starts to hunt for the right gear. If the RPMs start to fluctuate, I shift to 4th.
  3. Jul 30, 2014 at 4:41 PM
    1TUFFTRD
    1TUFFTRD WTF
    out and about building powerlines
    06 AC with a skewp
    06 With a Skewp.
    I always tow in 4th
  4. Jul 30, 2014 at 4:42 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    5th here, unless I want/need it to hold 4th.
  5. Jul 30, 2014 at 4:45 PM
    ajohnson
    ajohnson Glamour Shot
    Andy
    Charlotte, NC
    07 DCLB TRD Sport Prerunner 4x4
    Things and stuff and such
    You can try overdrive, but if it keeps shifting, put it in 4. If you are towing through mountains/hills, you will want to use 4 IMO. The tranny can heat up pretty quick if the torque converter unlocks with a load on a steep hill.
  6. Jul 30, 2014 at 4:56 PM
    oldracer
    oldracer Well-Known Member
    1of7627, Your towing in 4th and keeping the speed down; is good practice.
    It is not only safer; but it puts less strain on the truck's, engine, transmission and brakes , just to name a few things.
    I've put thousands of miles on a wide variety of vehicles and different trailers. You should always give yourself a cushion, if something unexpected happens.
    The Tacoma will pull your 2500 lbs with no problem; but a lot of and most small trailers that would normally be pulled with Tacoma sized trucks, don't have brakes. Of course some do.
    The average, 6' x 12' enclosed trailer does not usually have brakes; just as an example.
    I just checked Wells Cargo site and looked up specs on a 6' x 12' single axle cargo trailer. It lists the weight of that trailer as 1400 lbs; and a GVWR at 2900 lbs. And no brakes.
    You could find yourself in a situation, towing at the max of 2900 lbs; that you may not be able to stop your Tacoma as quickly as you may like.
    Just try to be safe.
    oldracer
  7. Jul 30, 2014 at 5:12 PM
    mountainwolfpup
    mountainwolfpup Ford Guy (Formerly known as a Toyota Guy)
    Vancouver, WA
    2015 Ford F150 Lariat FX4 3.5l Eco
    First month of ownership... This month I'm removing front air dam, and also Rhino lining the bed.
    X2
    Always use 4th gear. Much safer, and better for the transmission (heat).
    I have 80k+ on my Taco and tow several times monthly, always use 4th. Using a little more gas is cheaper then a new transmission.
  8. Jul 30, 2014 at 5:13 PM
    1 Bored Clerk
    1 Bored Clerk Well-Known Member
    Vancouver, WA
    '13 4x4 AC TRD OR
    My buddy with a 5th gen 4 runner watched his trans temp and found it run much hotter when towing in OD. Plus, as far as I know, the manual says to tow in 4th. I think the issue may be with the torque converter slipping more when in OD and having to drop in and out and operating at lower rpm. ??
  9. Jul 30, 2014 at 5:17 PM
    1of7627
    Mark
    Post Falls, ID
    I have a 7X14 tandem axle trailer cargo trailer with brakes and I totally agree on the need for brakes. I think the trailer weighs 1,500 lbs or so empty and I carry two ATV's and gear so I know it's closing in on 3,000 lbs loaded. I'm using a Hopkins Agility brake controller that I find quite satisfactory and it connected easily to the Tacoma harness with one of their plug and play cables.
    I've tried a few long (12 to 14 foot) single axle trailers and didn't like the way they handled at all. The tandem is far more stable, but of course is harder to muscle around in close quarters. I can do it gradually if I wet down the pavement first so the tires slip a little, but it's still a job and I don't know how many more years I'll be able to handle it myself.
  10. Jul 30, 2014 at 5:17 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    there should be no difference in temps if you are in 4th lockup vs 5th lockup.
    That stated holding 5th lockup while towing on anything other than the flats isnt going to happen... so as soon as it pops out of 5th lockup and i know it will hunt, drop it to fourth and you will be good.... then once you get back to the flat or downhill back to 5th.
  11. Jul 30, 2014 at 5:20 PM
    1of7627
    Mark
    Post Falls, ID
    Thanks everyone for your feedback.
  12. Jul 30, 2014 at 9:18 PM
    Fordidipower
    Fordidipower Well-Known Member
    Sin city
    2011 4door 4x4 4L auto-sold
    lockup is lockup but if it regularlyhas to break lockup thats where heat is made. heat is generated from fluid shearing and mechanical friction so pulling on a flat road in 5th isnt going to change anything. once you hit the grade pop it down into 4 and keep on going.
  13. Jul 31, 2014 at 2:56 AM
    savedone
    savedone Well-Known Member
    Gerald
    Texas
    TRD off-road 6speed manual
    3 inch lift by dealer at purchase
    Another good reason for a standard. ;)
