Towing in OD
Discussion in 'Towing' started by IamJorgeEdward, Jun 18, 2010.
  1. Jun 18, 2010 at 7:58 PM
    IamJorgeEdward
    IamJorgeEdward [OP] Well-Known Member
    Jorge Edward
    Orlando, FL
    2015 Toyota Tacoma TRD Sport
    Completely stock
    I will be embarking on a journey from Orlando,FL to Las Vegas, NV. I will be towing a 6x12 Trailer with my Tacoma. What are the rules about using OD while towing and using the ETC button? Will i harm the transmission if I use OD with ECT? Any help would be appreciated. Thanks
  2. Jun 19, 2010 at 12:01 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Read the manual. ALL of the other trucks I had with an auto with OD said NO OD while towing.
    Aluminum carrier in the geartrain was the reason.
    Get your info from a toyota master tech if you like it straight from the horses mouth. I know there's at least one on here.
  3. Jun 19, 2010 at 9:39 PM
    Black Taco
    Black Taco Well-Known Member
    Rob
    WPB, FL
    TOYOTA
    No mods whatsoever!
    It depends on the weight also. You towing empty or loaded?
  4. Jun 22, 2010 at 8:50 PM
    F-125Racer
    F-125Racer Well-Known Member
    Arkansas
    09,DC,TRD Sport, 4WD, TRD S/C
    The local Toyota Master Tech tells me it's no issue towing in OD, even when the converter is unlocked. He says you only need to drop to 4th if it's hunting for a gear.
    I've got about 8,000 towing miles with a 4,500lb enclosed trailer with no issues. See the thread " 6 cylinder towing review".
  5. Jun 22, 2010 at 9:00 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    The gears use a steel carrier.
    Not towing when in OD was started back in the 70's or 80's when OD's were a weak planetary gear set. Modern trannys have a much stronger OD, and are fine towing as long as the tranny isnt hunting between 4th and 5th.
    In the OP's case, 3rd and 4th.
  6. Jun 23, 2010 at 7:50 PM
    sixdoubleseven
    sixdoubleseven Well-Known Member
    Dave
    Boston
    14 DC 4x4
    I've been towing with the tranny in 4, but if I find myself on the highway going a constant speed, then I'll move it to D. Back to 4 as soon as I'm off the highway though.
  7. Jun 23, 2010 at 8:09 PM
    Silver 10
    Silver 10 Well-Known Member
    Joe
    Valparaiso, Indiana
    10 SR5 DBL Cab 4x4
    Nitto Terra Grapplers, Leer XL100 cap , Cabelas Bug shield , Tinted windows, Bed Mat, Husky Floor Liners front and rear, seat belt mod, Rear TSB, K&N Air filter
    Im just wondering where you got this info about older trucks not towing in OD and now it is ok with newer vehicles? Im not being a smartass but I have had several full size trucks F 150s, 250s and GMCs and have always been told to take out of OD when towing. I would love what your saying cuz it can save some gas over the long haul. I was just curious as to where you heard this.
  8. Jun 23, 2010 at 8:31 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    When I tow the boat I use "D" but like already stated if it hunts for a lower gear I'll drop it down to 4th for just a couple minutes until the road evens out. Staying in a lower gear while towing according to the owners manual will put increased wear and tear on the tranny and added heat. I mainly use the lower gears for engine braking when towing down steep descents...saves the brakes.
  9. Jun 23, 2010 at 8:35 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Well...aside from seeing how the newer OD's are made, and being around other people in the know, Popular Mechanics had an article about this very thing, back in 2000 or so, as did Trailor Life. Trailor Life has also responded in Tech articles regarding this very question in multiple issues. I have been towing things of varying size for over a decade, and have never had an OD related issue. Neither has anyone I know.
  10. Jun 23, 2010 at 8:41 PM
    Silver 10
    Joe
    Valparaiso, Indiana
    10 SR5 DBL Cab 4x4
    Thanks for the info
  11. Jun 23, 2010 at 8:53 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    See if you can dig up the articles. They had great info. IIRC, manufacture began makeing the OD's more sound around 1988.....
  12. Jun 24, 2010 at 3:13 AM
    sixdoubleseven
    Dave
    Boston
    14 DC 4x4
    I'd worry less about saving break pads and more about transmissions. Not saying that what you're doing is bad for either..
  13. Jul 10, 2010 at 12:08 PM
    Isthatahemi
    Isthatahemi Well-Known Member
    TRD OFF ROAD
    BFG AT's, Weathertechs, Hoppy's brake controller.
    It saves the brakes so you can use them to stop, as in not overheating them. Ride them and they quite working.
  14. Jul 10, 2010 at 12:36 PM
    larryde09
    larryde09 Well-Known Member
    Larry
    Boston, MA
    2019 TRD Sport, White Double Cab "Yeti"
    Current: DR750S-2CH Dash Cam, USB Fast Charger in stock blank, Hondo Garage phone mount Previous: 2006 Black 2.7L 5-spd SR5 4x4 Access Cab - K&N Cold Air Intake, Modified Magnaflow Cat-back Exhaust, Altezza Tail Lights, Pop&Lock Tailgate Lock, Extang Trifecta Tonneau Cover, PIAA foglights with stock switch, DrawTite Hitch, OBX Shift Knob, Hood Protector, Vent Visors, DIY step bars, DIY Bed Lights, DIY Ground Lights, DIY Tailgate Electrical Box, Aftermarket switches in stock dash blanks, Sony Head Unit, Illuminated 4x4 switch mod
    It's a matter of safety/control too. Particularly for manual trans: if you're in 4th gear you'll begin engine breaking the moment you take your foot off the gas. If you're in 5th (OD), you'll just keep coasting. This is true for going down hills...more control.
    You can probably put it in OD if you're on level ground with little traffic and if the trans isn't hunting for gears. If you anticipate hills or traffic, shift out of OD.
  15. Aug 11, 2010 at 3:26 AM
    Jimsc
    Jimsc Well-Known Member
    Jim
    Greenville, SC
    10 PreRunner Double Cab
    Aries Nerf Bars, Cargo Seperator
    The manuel for the 2010 says do not tow in OD! I would go with the factory recomendation.
  16. Aug 11, 2010 at 7:36 PM
    Isthatahemi
    TRD OFF ROAD
    My manual does not say anything about not towing in OD. What page are you referring to? There is a comment with regard to engine braking, but I read the manual cover to cover, and did not see a thing.
  17. Aug 13, 2010 at 6:50 PM
    Isthatahemi
    TRD OFF ROAD
    bump for my question to Jimsc.......
  18. Aug 13, 2010 at 6:59 PM
    Jason'sLawnCare
    Jason'sLawnCare Prepared for Bambi
    Jacksonville Florida
    08 4x4 Double Cab TRD Rugged Trail
    CBI Moab 2.0, CBI Trail Rider 2.0, CBI sliders w/kickout, Superwinch EPi9.0S, OME sport shocks w/886 coils, OME n182, 1.5" aal, JasonBuilt 3/16th full belly skid, BuiltRight uca, Body Mount Chop, 285/75/16 km2's, Rear cat delete, exhaust crossover rerouted, Fog light anytime, Locker mod, Rear leaf tsb, Debadged, Uws Tool Box, Electric Exhaust Cutout, AFE Pro Dry S, Kiwi Wifi, Diff Breather Relocated, Grom Ipod Adapter, Dual Diehard platinum batteries isolated by BlueSea marine switch
    :laugh: Sounds like a magazine about living in trailers.
  19. Aug 13, 2010 at 7:03 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    LOL!! Its a pretty good RV mag. :eek:
