towing increase
Discussion in 'Towing' started by 1997tacomashortbed, Aug 17, 2016.
  1. Aug 17, 2016 at 11:01 AM
    1997tacomashortbed
    1997tacomashortbed [OP] Well-Known Member
    Chase
    1997 red Tacoma single cab
    31 inch tires
    Is there anyway i could increase my suspension or torque/power to be able to tow more. I own a 1997 tacoma regular cab 4x4.
  2. Aug 18, 2016 at 4:48 AM
    DestroyerLite
    DestroyerLite Well-Known Member
    DFW
    04 Tacoma SR5 V6 4X4 Auto
    What are you trying to tow? Without knowing if you have the 2.4, 2.7 or 3.4 (I see single cab, I am assuming either a 2.4 or 2.7). If I am not mistaking properly equipped you could tow 3500# with the I4 or 5000# with the V6 (again, properly equipped). Maybe gives us some more info on what you are trying to tow.
    --Dan
  3. Aug 18, 2016 at 4:50 AM
    1997tacomashortbed
    Chase
    31 inch tires
    Im rocking a 2.7l and i tow livestock and hay wagon trailers.
  4. Aug 18, 2016 at 9:07 AM
    Lord Humongous
    Lord Humongous The Ayatolah Of RockNRolla
    AZ
    Inferno 3rd gen trd offroad 4x4
    https://www.tacomaworld.com/threads/lord-humongous-gigahorse-build.436524/
    Yes and no. Theoretically if you were to add a blower,lower diff gears, bigger brakes and a set of airbags to the suspension you'd have increased power and a better handling suspension and your truck would be a more capable tow vehicle. Unfortunately that won't increase the actual rating your truck came with from the factory meaning your still legally limited to the number that toyota deemed safe.
  5. Aug 22, 2016 at 10:13 AM
    Indy
    Indy Master of all I survey.
    Towing is easy. It's the steering/stopping part that's hard.
  6. Aug 22, 2016 at 10:17 AM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Tow better, yes, the suggestions above. Tow more than the truck is rated for, no. You need a different/bigger truck.
