Towing Large Offshore Boat?
Discussion in 'Towing' started by hanahou7, Jul 14, 2020.
  1. Jul 14, 2020 at 10:25 AM
    hanahou7
    hanahou7 [OP] Well-Known Member
    2012 Tacoma DCLB 4x4
    Bilstein 5100s OME 885 2" AAL
    Hi Everyone,
    I'm asking for a friend who is looking into buying a boat to take into the Pacific Ocean (fishing mainly outside the Golden Gate Bridge and Northern CA coast).
    He has a 2018 v6 Tacoma with the tow package that's rated for 6800 lbs. He's looking at 20'+ aluminum boats which typically have dry weights of 2500 - 4000 lbs. That's not including trailer, 100 gallons of gas, and gear.
    That being said, do you think that his Tacoma would be able to tow his boat regularly over some pretty steep hills in CA?
    I tow a 15' Arima Sea Hunter that has a dry weight of 1,000 lbs and I think with the trailer and gear it's probably around 2,000-2,200 lbs and I don't have any issues but the engine does get up to 4,500 RPMs going up the hills. I feel like it's probably fine but it still makes me wonder what it's doing to the transmission haha (I tow the boat about 3-4 times per month and round trip is about 100 miles per trip).
    Any experience/ thoughts would be greatly appreciated!
  2. Jul 14, 2020 at 10:30 AM
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    Towing occasionally, maybe. Towing regularly, not a chance. He's in full size territory no doubt
  3. Jul 14, 2020 at 10:35 AM
    hanahou7
    Yea, that's what I was thinking...if you're fishing hard and towing the boat regularly (3-4 times a month) then I don't think the Tacoma could handle being stressed with over 50% of it's tow capacity.
    Thanks for the feedback!
  4. Jul 14, 2020 at 10:36 AM
    ToyoTaco25
    ToyoTaco25 Well-Known Member
    North Carolina
    09 Super-White DCSB 6-Speed
    ProComp 4" D-Bag, I mean Drop Bracket Lift, AMP Research Powersteps, 285/70-R17’s, Magnaflow, AFE CAI, Dipped Badges
    Full size boats require full size trucks to pull them with...
    Plus once you get rolling you are gonna have to stop eventually. Unless you are speed launching your boat lolol
  5. Jul 14, 2020 at 10:37 AM
    hanahou7
    Hahaha yea that is for sure
  6. Jul 14, 2020 at 10:39 AM
    Gunshot-6A
    Conner
    Everett, WA
    Plus it would be amusing watching a tacoma try and pull that up a steep boat ramp.
  7. Jul 14, 2020 at 2:32 PM
    Sprig
    Sprig Well-Known Member
    Ken
    N. Calif. The Twilight Zone
    Tacoma TRD double cab 4x4, Barcelona Red
    When you add the weight of the boat engine or engines, trailer, 60 to 100 gallons of fuel, and other equipment you’re looking at another 3500 lbs or more. Combined weight over the Taco max. You need a full sized truck
    hanahou7[OP] likes this.
  8. Jul 14, 2020 at 3:07 PM
    hanahou7
    Thanks for all the responses...you're basically confirming what I thought/ told him...hopefully he listens to all of us (he was skeptical of my advice haha).
  9. Jul 14, 2020 at 3:20 PM
    andrew61987
    andrew61987 Well-Known Member
    2008 Access Cab 4WD, 2.7L 5 speed
    I might use a Taco tow that thing at 2 mph just to move it around private property.
    In other words no way. It's too much. I'd even feel unsure in a full size half ton. That's probably getting towards F250 territory if you want to feel confident about it.
  10. Jul 15, 2020 at 4:26 AM
    varmintshooter
    varmintshooter Member
    tacoma
    none
    I have a friend that tows his 23' Steiger craft on a dual axle trailer, 200 hp OB and 120 gallons of fuel to the boat ramp a couple times a year. I told him he's crazy but he thinks his 2nd gen is up to it. I think his rig is just over 7000 lbs. All flat land here, except for the ramp. The taco may be able to do it but why would you want to.
  11. Jul 15, 2020 at 4:56 AM
    jethro
    jethro Master Baiter
    Geoff
    Southern NH
    2020 Ford F-150 Lariat 5.0L V8
    Large boats are kinda a misery to tow any distance. Big fuel tanks and odd weight distribution. I have a 21' aluminum with a 150hp outboard and tow it thousands of miles a year. It's sorta within the weight range of what a Tacoma can tow but no way I would have one as a full time tow vehicle.
  12. Jul 15, 2020 at 10:28 AM
    cctk2
    cctk2 GLACIERBIRD
    Chip
    NorCal and Alaska
    '68 FJ40, '16 TRD AC OR A/T WHITE
    Accessories: SnugTop Rebel canopy AVS Window Rain Deflectors TACOMA 6' Bed Mat Weathertech Mud Guards (4) Scanguage (re-installed from the '02) Tekonsha Voyager Brake controller (Chalet A frame pop-up.) Vinyl letter insets for tailgate. Garmin CS60 GPS mounting. Other misc décor in the form of decals.
    I searched for the best and most elegant way to answer. All I came up with is
    No.
    ToyoTaco25 likes this.
  13. Jul 15, 2020 at 10:50 AM
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
    Sure he can tow it. Is it safe, no, does it endanger everyone else on the road, yes.
    lock likes this.
