Towing Maintenance
Discussion in 'Towing' started by erm626, Aug 25, 2012.
  1. Aug 25, 2012 at 5:07 AM
    erm626
    erm626 [OP] Well-Known Member
    Ed
    Norfolk, Virginia
    Tacoma 4x4 SR5
    Access Tonneau Cover, EGR window Visors,Trail FX Step Bars
    Any thoughts on How often the Engine oil should be changed when doing a lot of towing? Should switching to a synthetic oil be advisable.
    Transmissions- How often should that be changed when towing. Also do they make a towing synthetic style fluid for towing ??
  2. Aug 25, 2012 at 5:33 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    There are recommended intervals in the book that you can start with. And then you can get the fluids analyzed (Blackstone Labs) to get a true idea about how your fluids are doing.
    Synthetic is a good call.
  3. Aug 25, 2012 at 5:37 AM
    bcm79
    bcm79 Member
    Brian
    Mesa, AZ
    07 DCSB
    OME 886, AAL, 33's, ARB, etc...
    I've changed engine oil every 5000 miles, always with synthetic
    Changed out the ATF every 30,000 with synthetic.
    82k and still going strong, with about 12k towing my travel trailer (~4200lbs loaded).
    I've never noticed a towing - specific formula of trans fluid, but I have seen plenty of synthetic trans fluid on the shelves. You may want to consider an additional transmission cooler if you'll be towing extensively.
